5 Replies Latest reply on Apr 2, 2012 3:52 PM by GurtnamonaIE
    Flex accessing bound variables prematurely
    GurtnamonaIE Level 1
      Trying to instantiate variables only when first accessed but Flex accesses everything, even before the referencing component is created. In below example, I wouldn't expect titleForScreen2 to be called immediately, yet it is. Is this a bug?
      xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
      <fx:Script>
          <![CDATA[
              private var _titleForScreen1:String;
              private var _titleForScreen2:String;
              public function get titleForScreen1():String {
                  if(_titleForScreen1 == null){
                      //Server Request
                  return _titleForScreen1;
              public function get titleForScreen2():String {
                  if(_titleForScreen2 == null){
                      //Server Request
                  return _titleForScreen2;
      </fx:Script>
      <mx:ViewStack>
      <s:NavigatorContent label="Screen 1">
      <s:Label text="{titleForScreen1}"/>
      </s:NavigatorContent>
      <s:NavigatorContent label="Screen 2">
      <s:Label text="{titleForScreen2}"/>
      </mx:ViewStack>
      </s:Application>
        • 1. Re: Flex accessing bound variables prematurely
          pauland Level 4
          http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf69084-7cb8.html
          It says:
          Single-view containers
          Single-view containers by default create all their children when the application first starts. You can use the
          creationPolicy property to change this behavior.
          • 2. Re: Flex accessing bound variables prematurely
            Thanks for the response however the issue is not regarding component creation. If you set creationComplete handlers throughout, you'll see that the label on the second screen is never created (as it shouldn't). The entire issue is that Flex is accessing the variable titleForScreen2 even though <s:Label text="{titleForScreen2}"/> is never created and that variable is not used anywhere else. This seems to me to be erroneous behavior.
            • 3. Re: Flex accessing bound variables prematurely
              Flex harUI Adobe Employee
              It is not a bug.  The binding code is pretty eager about evaluating expressions.
              • 4. Re: Flex accessing bound variables prematurely
                It does seem odd to me that binding is evaluated before the component is created but I guess that's just how Flex works. To acheive the desired behavior, I moved the binding code to actionscript inside a creationComplete handler. Hopefully this will not have adverse effects.
                • 5. Re: Flex accessing bound variables prematurely
                  BTW, for anyone interested here is the sample code modified for my current approach. For what it's worth, I fail to see the value in Flex registering bindings prior to the creation of the binding component but I'll be the first to admit I'm not the most knowledgable about this stuff; there could be a perfectly valid reason. Critiques more than welcomed.
                  <fx:Script>
                      <![CDATA[
                          import mx.binding.utils.BindingUtils;
                          import mx.binding.utils.ChangeWatcher;
                                  //Server Request
                                  //Server Request
                          public function updateLabel1(value:String):void {screen1Label.text = value;}
                          public function updateLabel2(value:String):void {screen2Label.text = value;}
                          public function bindLabel1():void {
                              var changeWatcher:ChangeWatcher = BindingUtils.bindSetter(updateLabel1,this, "titleForScreen1");
                          public function bindLabel2():void {
                              var changeWatcher:ChangeWatcher = BindingUtils.bindSetter(updateLabel2,this, "titleForScreen2");
                  </fx:Script>
                  <mx:ViewStack>
                  <s:Label id="screen1Label" creationComplete="bindLabel1()"/>
                  <s:Label id="screen2Label" creationComplete="bindLabel2()"/>
                  </mx:ViewStack>
                  </s:Application>
