10 Replies Latest reply on Apr 4, 2012 3:48 PM by angieclark
    Overdrive activation error 256
    waikikimo
      I keep getting activation error 256 whenever I attempt to log on to Overdrive on my ipad2.  I uninstalled and reinstalled the app to no avail.  Is this just a server issue on your end or is there something that I am doing wrong?  Any help that you can give me would be very appriciated.  Thanks a bunch.
      Maureen
        • 1. Re: Overdrive activation error 256
          safaricat2
          I'm getting the same error message. I originally had the error message "ASC4 License Initialization Error:-1001 an unexpected system error occurred while trying to contact the Adobe server" so I deauthorized my iPad then tried to Reauthorize it to which I am now getting the 256 error message. I'm wondering if I should delete Overdrive and reinstall it to my iPad to see if that will help...
          Have you had any luck getting yours working?
          Cheryl
          • 2. Re: Overdrive activation error 256
            angieclark
            I've had exactly the same issues this is now day 3, I did remove overdrive and re install but no luck.
            • 3. Re: Overdrive activation error 256
              safaricat2 Level 1
              Did you post in the App store in the Overdrive Review you were having issues since the update in case this is an issue from their end? I did, figured it wouldn't hurt...
              Did you have the same first error message I had, the Error 1001?
              • 4. Re: Overdrive activation error 256
                angieclark Level 1
                I actually had problems before I reinslled the app I just thought getting rid of it then re installing it might fix it.  I did have the error 1001 first as well, are you able to access adobe .com?
                • 5. Re: Overdrive activation error 256
                  Level 4
                  I tried to help you in another post, but ......
                  This forum deals with Adobe Digital Editions, not Overdrive.  So, there
                  aren't any technical gurus here who are likely to help you with the problem
                  you've stated.  Also, iPads do not interface with Digital Editions.
                  • 6. Re: Overdrive activation error 256
                    angieclark Level 1
                    It works!!!  I was playing with the settings of overdrive and turned the automatic download off and now it works. Not sure if this is a coincidence or not but now I can 'magically' access adobe.com!  Strange indeed, thanks to all who had suggestions.
                    Angie
                    • 7. Re: Overdrive activation error 256
                      angieclark Level 1
                      Oh crap, I spoke too soon.  I downloaded 2 books but now it's back to the 1001 error
                      • 8. Re: Overdrive activation error 256
                        safaricat2 Level 1
                        I'm pretty sure this is in part an Adobe problem as I'm trying to Activate my Adobe Authorization with my Adobe ID on my iPad. This has worked before, for the last year. Yes it is in the Overdrive program but it still has to access Adobe's servers to verify I have an Adobe ID so I can read Adobe ebooks. This is just very frustrating as it doesn't seem there is support for authorizing an Adobe account. I tried chat and was told to create and submit a web case so hopefully I will get some help soon. My next option might be to create a new Adobe ID and password and try to see if that works...
                        Also the error that comes up is Adobe Activation Error:256 An unexpected system error occured while trying to contact the dobe Servers
                        Thanks for all the help I appreciate it!
                        • 9. Re: Overdrive activation error 256
                          safaricat2 Level 1
                          Angie ( I feel like I know you now since we've chatted all day!)
                          I got my Authorization to work I don't know if Adobe did something or what, but this is what I did... In settings I turned off Auto play, Cellular download, automatic downloads and auto check messages. I then tapped clear deleted titles even though there weren't any, then I tapped check for messages.clicked ok when it said there were none. Then clicked Authorize, tried two times with everything off then when it didn't work I turned on all the settings I had turned off ,did the Authorization again and it worked! I was able to download the books from the library directly from my iPad. I am able to open and read a book!
                          I hope this works for you!
                          Cheryl
                          • 10. Re: Overdrive activation error 256
                            angieclark Level 1
                            Thanks Cheryl, it seems to work if I turn the auto download off then it doesn't ask for adobe user and password, weird but whatever.
                            Angie
