0 Replies Latest reply on Apr 3, 2012 4:23 AM by AlbertoCasanova01
    My Windows 7 is in spanish and Premiere starts in spanish too: i get an error.
    AlbertoCasanova01
      I'm using Windows 7 SP1 x64. I have Premiere Pro CS5.5 installed and up to date. Windows 7 is running in spanish (using a Language Pack).  Every Master Suite application installed runs in english except for Premiere. When i try to open a project, i get the error that you can see in the attached image:
      And, even when i can continue using Premiere, i can't do much after that (can't add transition, render, or whatever).  My temporal solution is to change Windows 7 language back to english. This cause Premiere to run in english too and I don't get the error and can work with out problems.
      My questions are:
      1) Why does Premiere change its language without asking?
      2) How can I force premiere to start in english even if my OS is in spanish?
      Note: i *do* want Premiere to run in english (even if i can run in spanish with no problem, which is not the case).
      Thanks in advance for any insight.
