0 Replies Latest reply on Apr 3, 2012 7:09 AM by lee704
    Date/Time Picker Output Help
    lee704
      In my Flex 3.6 app, I have a set of controls that allow the user to pick the date/time.  The user does this by selecting a date from a DateInput, an hour, minutes and AM/PM through three ComboBox.  I then combine the selections into a string and output in a Label control.
      I now need to compare the date/time selected to a set of date/times that are allowed.  I keep running into the error "1067: Implicit coercion of a value of type String to an unrelated type Date."
      How can I convert my date/time string into a valid date object so I can compare it with other date objects?
      Thanks!
      Lee
      Below is the code:
      DateTimePicker.mxml
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                                              layout="absolute"
                                              minWidth="955"
                                              minHeight="600">
                <mx:Script>
                          <![CDATA[
                                    [Bindable]
                                    private var todayDate:Date=new Date();
                                    [Bindable]
                                    private var earliestTime:Date=new Date(todayDate.getTime() + 3 * 60 * 60 * 1000);
                                    [Bindable]
                                    private var latestTime:Date=new Date(todayDate.getTime() + 12 * 60 * 60 * 1000);
                </mx:Script>
                <!--Data-->
                <mx:XML id="hoursXML"
                                    source="assets/hours.xml"/>
                <mx:XMLListCollection source="{hoursXML.hour}"
        id="xmllcHours"/>
                <mx:XML id="minutesXML"
                                    source="assets/minutes.xml"/>
                <mx:XMLListCollection source="{minutesXML.minute}"
        id="xmllcMinutes"/>
                <mx:DateFormatter id="dfd"
                                                          formatString="MM/DD/YYYY"/>
                <mx:Label x="10"
                                      y="10"
                                      text="Date/Time"/>
                <mx:DateField x="82"
                                                y="10"
                                                id="dfExpectedDate"
                                                text="{dfd.format(todayDate)}"
                                                selectableRange="{{rangeStart: this.earliestTime,rangeEnd: this.latestTime}}"
                                                visible="true"
                                                width="100"/>
                <mx:ComboBox x="200"
                                               y="10"
                                               id="cbExpectedHour"
                                               fontWeight="normal"
                                               width="80"
                                               text="Hour"
                                               selectedIndex="-1"
                                               dataProvider="{xmllcHours}">
                </mx:ComboBox>
                <mx:ComboBox x="300"
                                               y="10"
                                               width="80"
                                               id="cbExpectedMinute"
                                               fontWeight="normal"
                                               selectedIndex="-1"
                                               text="Minute"
                                               dataProvider="{xmllcMinutes}">
                </mx:ComboBox>
                <mx:ComboBox x="400"
                                               y="10"
                                               width="80"
                                               id="cbExpectedTimeRange"
                                               fontWeight="normal"
                                               selectedIndex="-1"
                                               text="AM/PM">
                          <mx:ArrayCollection>
                                    <mx:Object label="a.m."
                                                           data="AM"/>
                                    <mx:Object label="p.m."
                                                           data="PM"/>
                          </mx:ArrayCollection>
                </mx:ComboBox>
                <mx:Text x="10"
                                     y="38"
                                     text="{this.dfExpectedDate.text} {this.cbExpectedHour.text}:{this.cbExpectedMinute.text}:00 {this.cbExpectedTimeRange.selectedItem.data}"
                                     id="tExpectedLandingDateTime"
                                     visible="true"/>
      </mx:Application>
      hours.xml
      <hours>
                <hour>12</hour>
                <hour>01</hour>
                <hour>02</hour>
                <hour>03</hour>
                <hour>04</hour>
                <hour>05</hour>
                <hour>06</hour>
                <hour>07</hour>
                <hour>08</hour>
                <hour>09</hour>
                <hour>10</hour>
                <hour>11</hour>
      </hours>
      minutes.mxml
      <minutes>
                <minute>00</minute>
                <minute>01</minute>
                <minute>02</minute>
                <minute>03</minute>
                <minute>04</minute>
                <minute>05</minute>
                <minute>06</minute>
                <minute>07</minute>
                <minute>08</minute>
                <minute>09</minute>
                <minute>10</minute>
                <minute>11</minute>
                <minute>12</minute>
                <minute>13</minute>
                <minute>14</minute>
                <minute>15</minute>
                <minute>16</minute>
                <minute>17</minute>
                <minute>18</minute>
                <minute>19</minute>
                <minute>20</minute>
                <minute>21</minute>
                <minute>22</minute>
                <minute>23</minute>
                <minute>24</minute>
                <minute>25</minute>
                <minute>26</minute>
                <minute>27</minute>
                <minute>28</minute>
                <minute>29</minute>
                <minute>30</minute>
                <minute>31</minute>
                <minute>32</minute>
                <minute>33</minute>
                <minute>34</minute>
                <minute>35</minute>
                <minute>36</minute>
                <minute>37</minute>
                <minute>38</minute>
                <minute>39</minute>
                <minute>40</minute>
                <minute>41</minute>
                <minute>42</minute>
                <minute>43</minute>
                <minute>44</minute>
                <minute>45</minute>
                <minute>46</minute>
                <minute>47</minute>
                <minute>48</minute>
                <minute>49</minute>
                <minute>50</minute>
                <minute>51</minute>
                <minute>52</minute>
                <minute>53</minute>
                <minute>54</minute>
                <minute>55</minute>
                <minute>56</minute>
                <minute>57</minute>
                <minute>58</minute>
                <minute>59</minute>
      </minutes>
