0 Replies Latest reply on Apr 3, 2012 11:23 AM by cybertek23
    CFC including
    cybertek23
      Hi
      We are currenlty trying to implement some API's which we haev downloaded there sample files which are all .cfc files.  I have never used CFC so am unsure how to use them . I am trying look at tutorials but at the moment it is still not making any sense to me.  Can someone please explain how to view them /Invoke them or let me know a tutorial that will help me.
      Some of the examples i have are
      application.cfm
      component displayname="Application"
       public void function onRequestStart() {
        application.ccUsername = "username";        // Username
        application.ccPassword = "password";       // Password
        application.apiKey = "ourAPI key";         // API Key
        application.optInSource = "ACTION_BY_CUSTOMER";
        optInSource - How are these contacts being added.
        ACTION_BY_CUSTOMER - Used for internal applications. Contact did not take the action to add themself to your list.
         This will not generate a 'Welcome Email'.
        ACTION_BY_CONTACT - Used for sign up boxes where the customer is directly subscribing to your newsletter.
         This will send a 'Welcome Email' when the user subscribes.
        /* set to true to use errorMessaging function in Utility.cfc to provide http error messaging */
        application.debug = true;
        application.path = "https://api.constantcontact.com";
        application.apiPath = "#application.path#/ws/customers/#APPLICATION.ccUsername#";
        application.doNotInclude = "Active,Do Not Mail,Removed";
       public void function onError(required exception, required string eventName) {
        new Utility().errorMsg('#Arguments.Exception.rootcause.message#');
      then campaigncollection
       public CampaignsCollection function init() {
        return this;
      *@hint Creates a Campaign in Constant Contact using the properties of the Campaign object
      *@campaign Campaign to be added to Constant Contact
       public Campaign function addCampaign(required Campaign campaign) {
        local.campaignXml = createCampaignXml(arguments.campaign);
        local.httpResponse = CTCTRequest('post', '#application.apiPath#/campaigns', local.campaignXml);
        local.campaignStruct = createCampaignStruct(local.httpResponse);
        local.newCampaign = new Campaign(argumentCollection = local.campaignStruct);
        return local.newCampaign;
      *@hint Updates a Campaign in Constant Contact using the properties of the Campaign object
      *@campaign Campaign to be updated
       public string function updateCampaign(required Campaign campaign) {
        local.httpResponse = CTCTRequest('put', '#arguments.campaign.getCampaignLink()#', local.campaignXml);
        return local.httpResponse;
      *@hint Deletes a Campaign in Constant Contact using the properties of the Campaign object
      *@campaign Campaign to be deleted in Constant Contact
       public void function deleteCampaign(required Campaign campaign) {
        local.httpResponse = CTCTRequest('delete', '#arguments.campaign.getCampaignLink()#');
      *@hint Gets a list of 50 Campaigns, and a link to the next page of campaigns if one exists
      *@page Optional URL if performing this function on a page other than the first
       public array function getCampaigns(page='#application.apiPath#/campaigns') {
        local.campaignsXml = xmlParse(CTCTRequest('get', page));
        local.fullArray = arrayNew(1);
        local.campaignsArray = arrayNew(1);
        local.linkArray = arrayNew(1);
        local.nextAddress = '';
        for(i=1; i LTE arrayLen(local.campaignsXml.feed.entry); i=i+1) {
         local.campaign = {
          campaignLink = application.path & local.campaignsXml.feed.entry[i].link.xmlattributes.href,
          campaignId = local.campaignsXml.feed.entry[i].id.xmlText,
          campaignName = local.campaignsXml.feed.entry[i].title.XmlText,
          updated = local.campaignsXml.feed.entry[i].updated.XmlText,
          status = local.campaignsXml.feed.entry[i].content.Campaign.status.xmlText};
         local.newCampaign = new Campaign(argumentCollection=local.campaign);
         arrayAppend(local.campaignsArray, local.newCampaign);
        arrayAppend(local.fullArray, local.campaignsArray);
        local.nextLinkSearch = xmlSearch(local.campaignsXml, "//*[@rel='next']");
        if(!arrayIsEmpty(local.nextLinkSearch)) {
         local.nextAddress = application.path & local.nextLinkSearch[1].xmlattributes.href;
        local.linkArray[1] = local.nextAddress;
        arrayAppend(local.fullArray, local.linkarray);
        return local.fullArray;
      *@hint Searches for campaigns based off of their status
      *@status Status to search for. Valid options are:  DRAFT, RUNNING, SENT and SCHEDULED
       public array function searchCampaigns(required string status) {
        local.searchUrl = application.apiPath & '/campaigns?status=' & arguments.status;
        local.foundCampaigns = getCampaigns(local.searchUrl);
        return local.foundCampaigns;
      *@hint Returns an updated Campaign object containing all details that exist in Constant Contact
      *@campaign Campaign to retrieve details for
       public Campaign function getCampaignDetails(required Campaign campaign) {
        local.campaignXml = xmlParse(CTCTRequest('get', '#arguments.campaign.getCampaignLink()#'));
        local.campaignStruct = createCampaignStruct(local.campaignXml);
      *@hint Creates XML to be used for sending Campaign information to Constant Contact
      *@campaign Campaign to create XML for
       private Xml function createCampaignXml(required Campaign campaign) {
        savecontent variable="local.campaignPart1" {
        writeOutput('<entry xmlns="http://www.w3.org/2005/Atom">
          <link href="/ws/customers/#application.ccusername#/campaigns" rel="edit" />
          <id>#arguments.campaign.getCampaignId()#</id>
          <title type="text"></title>
          <updated>#dateformat(now(), "yyyy-mm-dd")#T#TimeFormat(now(), "HH:mm:ss:l")#Z</updated>
          <author>
            <name></name>
          </author>
          <content type="application/vnd.ctct+xml">
            <Campaign xmlns="http://ws.constantcontact.com/ns/1.0/" id="#arguments.campaign.getCampaignId()#">
              <Name>#arguments.campaign.getCampaignName()#</Name>
              <Status>#arguments.campaign.getStatus()#</Status>
              <Date>#dateformat(now(), "yyyy-mm-dd")#T#TimeFormat(now(), "HH:mm:ss:l")#Z</Date>
              <Subject>#arguments.campaign.getSubject()#</Subject>
              <FromName>#arguments.campaign.getFromName()#</FromName>
              <ViewAsWebpage>#arguments.campaign.getViewAsWebpage()#</ViewAsWebpage>
              <ViewAsWebpageLinkText>#arguments.campaign.getViewAsWebpageLinkText()#</ViewAsWebpageLinkText>
              <ViewAsWebpageText>#arguments.campaign.getViewAsWebpageText()#</ViewAsWebpageText>
              <PermissionReminder>#arguments.campaign.getPermissionReminder()#</PermissionReminder>
              <PermissionReminderText>#arguments.campaign.getPermissionReminderText()#</PermissionReminderText>
              <GreetingSalutation>#arguments.campaign.getGreetingSalutation()#</GreetingSalutation>
              <GreetingName>#arguments.campaign.getGreetingName()#</GreetingName>
              <GreetingString>#arguments.campaign.getGreetingString()#</GreetingString>
              <OrganizationName>#arguments.campaign.getOrganizationName()#</OrganizationName>
              <OrganizationAddress1>#arguments.campaign.getOrganizationAddress1()#</OrganizationAddress1>
              <OrganizationAddress2>#arguments.campaign.getOrganizationAddress2()#</OrganizationAddress2>
              <OrganizationAddress3>#arguments.campaign.getOrganizationAddress3()#</OrganizationAddress3>
              <OrganizationCity>#arguments.campaign.getOrganizationCity()#</OrganizationCity>
              <OrganizationState>#arguments.campaign.getOrganizationState()#</OrganizationState>
              <OrganizationInternationalState>#arguments.campaign.getOrganizationInternationalState()#</OrganizationInternationalState>
              <OrganizationCountry>#arguments.campaign.getOrganizationCountry()#</OrganizationCountry>
              <OrganizationPostalCode>#arguments.campaign.getOrganizationPostalCode()#</OrganizationPostalCode>
              <IncludeForwardEmail>#arguments.campaign.getIncludeForwardEmail()#</IncludeForwardEmail>
              <ForwardEmailLinkText>#arguments.campaign.getForwardEmailLinkText()#</ForwardEmailLinkText>
              <IncludeSubscribeLink>#arguments.campaign.getIncludeSubscribeLink()#</IncludeSubscribeLink>
              <SubscribeLinkText>#arguments.campaign.getSubscribeLinkText()#</SubscribeLinkText>
              <EmailContentFormat>#arguments.campaign.getEmailContentFormat()#</EmailContentFormat>
              <EmailContent>#xmlFormat(arguments.campaign.getEmailContent())#</EmailContent>
              <EmailTextContent>#xmlFormat(arguments.campaign.getEmailTextContent())#</EmailTextContent>
              <StyleSheet></StyleSheet>
              <ContactLists>');
        savecontent variable="local.campaignPart2" {
         for(i=1; i LTE arrayLen('#arguments.campaign.getContactLists()#'); i=i+1) {
          writeOutput('<ContactList id="#local.campaign.getContactLists()[i]#"/>');
        savecontent variable="local.campaignPart3" {
          writeOutput('</ContactLists>
              <FromEmail>
                <Email id="#arguments.campaign.getFromEmailId()#">
                </Email>
                <EmailAddress>#arguments.campaign.getFromEmail()#</EmailAddress>
              </FromEmail>
              <ReplyToEmail>
                <Email id="#arguments.campaign.getReplyToEmailId()#">
                </Email>
                <EmailAddress>#arguments.campaign.getReplyToEmail()#</EmailAddress>
              </ReplyToEmail>
            </Campaign>
          </content>
          <source>
            <id>http://api.constantcontact.com/ws/customers/#application.ccUsername#/campaigns</id>
            <title type="text">Campaigns for customer: #application.ccUsername#</title>
            <link href="campaigns" />
            <link href="campaigns" rel="self" />
            <author>
              <name>#application.ccUsername#</name>
            </author>
          </source>
        </entry>');
       local.fullXml = local.campaignPart1 & local.campaignPart2 & local.campaignPart3;
       return xmlParse(local.fullXml);
      *@hint Creates a structure representing a Camapign from XML returned by CTCT
      *@xml XML to create a structure out of
       private struct function createCampaignStruct(required any campaignXml) {
        local.campaignXml = xmlParse(campaignXml);
        local.tempStruct = local.campaignXml.entry.content.Campaign;
        local.campaign = {
         campaignName = local.tempStruct.name.xmlText,
         campaignId = local.campaignXml.entry.id.xmlText,
         campaignLink = application.path & local.campaignXml.entry.link.xmlattributes.href,
         updated = local.campaignXml.entry.updated.xmltext,
         status = local.tempStruct.status.xmltext,
         sent = local.tempStruct.sent.xmltext,
         opens = local.tempStruct.opens.xmltext,
         clicks = local.tempStruct.clicks.xmltext,
         optOuts = local.tempStruct.optouts.xmltext,
         bounces = local.tempStruct.bounces.xmltext,
         forwards = local.tempStruct.forwards.xmltext,
         spamReports = local.tempStruct.spamreports.xmltext,
         subject = local.tempStruct.subject.xmltext,
         fromName = local.tempStruct.fromname.xmltext,
         fromEmail = local.tempStruct.fromemail.emailaddress.xmltext,
         replyToEmail = local.tempStruct.replytoemail.emailaddress.xmltext,
         campaignType = local.tempStruct.campaigntype.xmltext,
         viewAsWebpage = local.tempStruct.viewaswebpage.xmltext,
         viewAsWebpageLinkText = local.tempStruct.viewaswebpagelinktext.xmltext,
         viewAsWebpageText = local.tempStruct.viewaswebpagetext.xmltext,
         permissionReminder = local.tempStruct.permissionreminder.xmltext,
         greetingSalutation = local.tempStruct.greetingsalutation.xmltext,
         greetingString = local.tempStruct.greetingstring.xmltext,
         organizationName = local.tempStruct.organizationname.xmltext,
         organizationAddress1 = local.tempStruct.organizationaddress1.xmltext,
         organizationAddress2 = local.tempStruct.organizationaddress2.xmltext,
         organizationAddress3 = local.tempStruct.organizationaddress3.xmltext,
         organizationCity = local.tempStruct.organizationcity.xmltext,
         organizationState  = local.tempStruct.organizationstate.xmltext,
         organizationInternationalState  = local.tempStruct.organizationinternationalstate.xmltext,
         organizationPostalCode = local.tempStruct.organizationpostalcode.xmltext,
         organizationCountry = local.tempStruct.organizationcountry.xmltext,
         includeForwardEmail = local.tempStruct.includeforwardemail.xmltext,
         forwardEmailLinkText = local.tempStruct.forwardemaillinktext.xmltext,
         includeSubscribeLink = local.tempStruct.includesubscribelink.xmltext,
         subscribeLinkText = local.tempStruct.subscribelinktext.xmltext,
         archiveStatus = local.tempStruct.archivestatus.xmltext,
         archiveUrl = local.tempStruct.archiveurl.xmltext};
        if(isdefined('local.tempStruct.LastEditDate.xmltext')) {
         local.campaign.lastEditDate = local.tempStruct.lastEditDate.xmlText;
        if(local.campaign.CampaignType EQ "CUSTOM") {
         local.campaign.greetingName = local.tempStruct.greetingname.xmltext;
         local.campaign.emailContentFormat = local.tempStruct.emailcontentformat.xmltext;
         local.campaign.emailContent = local.tempStruct.emailcontent.xmltext;
         local.campaign.emailTextContent = local.tempStruct.emailtextcontent.xmltext;
         local.campaign.styleSheet = local.tempStruct.stylesheet.xmltext;
        if(local.campaign.CampaignType EQ "Sent") {
         local.campaign.urls = arrayNew(1);
         local.tempUrl = structNew();
         for(i=1; i LTE arrayLen(local.tempstruct.urls.url); i=i+1) {
          local.tempUrl.value = local.tempStruct.urls.url.value.xmltext;
          local.tempUrl.clicks = local.tempStruct.urls.url.clicks.xmltext;
          local.tempUrl.id = local.tempStruct.urls.url.xmlattributes.id;
        return local.campaign;
      Thanks for your help in advance
