16 Replies Latest reply on Apr 11, 2012 10:20 AM by lrosenth
    Get location of an annotation
    tyerlv123
      I am looking at getting the location/coordinates of an annotation and printing them.
      I can get the annotation and appear to even get the coordinates but can't print them.
      This is what i am trying:
      ASFixedRect box;
      PDAnnotGetRect(annot, &box);
      ptr = (char *) &box.left;
      sprintf(buf, "The annotation's location is %s", ptr);
      AVAlertNote(buf);
      Tyler
        • 1. Re: Get location of an annotation
          lrosenth Adobe Employee
          You can’t print them because you are trying to treat an ASFixed value as a char*.  Clearly that’s wrong.
          You should convert them from ASFixed to something standard like a float (ASFixedToFloat is your friend!) and then use the %f for sprintf.
          • 2. Re: Get location of an annotation
            tyerlv123 Level 1
            As a follow up question:
            I am trying to use this method as well:
            ASBool PDRedactionGetProps(PDAnnot redactionAnnot, PDRedactParams redactionProps)
            I can get it to return true therefore to the best of my knowledge redactionProps is filled out.
            How do I pull the data out of redactionProps ie in oder to get the value of the overlayText? or the pageNum? it also looks like this method will also get me the location of the annotation...by geting the redactQuads.
            • 3. Re: Get location of an annotation
              It’s a structure, so just reference the members.  (props.size, etc)
              • 4. Re: Get location of an annotation
                tyerlv123 Level 1
                I believe that is what I am trying:
                PDRedactParams redactionProps;
                PDRedactionGetProps(annot, redactionProps);
                ASText overlay;
                overlay = redactionProps.overlayText
                But it doesn't like redactionProps.overlayText...isn't that how you would reference the members?
                • 5. Re: Get location of an annotation
                  Sounds like you are having C/C++ development issues, not related to our SDK.
                  • 6. Re: Get location of an annotation
                    tyerlv123 Level 1
                    The error that comes tells me
                    Error: expression must have class type
                    I can do this although what gets returned is null.
                    PDRedactParamsRec redactionProps;
                    PDRedactionGetProps(annot, &redactionProps);
                    but then when i get my redactionProps.overlayText the returned result is null? when I do have overlay text.
                    • 7. Re: Get location of an annotation
                      And the annotation you have is indeed of Subtype Redaction??
                      • 8. Re: Get location of an annotation
                        tyerlv123 Level 1
                        Yup the sub type is redact.
                        Because I do this to test:
                        if(PDAnnotGetSubtype(annot) == ASAtomFromString("Redact") and it goes into the if statment
                        And when I do this atom = PDAnnotGetSubtype(annot);
                        ptr = (char *) ASAtomGetString(atom);
                        sprintf(buf, "The subtype is %s", ptr);
                        AVAlertNot(buf);
                        returns the ptr as Redact.
                        • 9. Re: Get location of an annotation
                          tyerlv123 Level 1
                          An Update:
                          As above the PDAnnotGetSubtype returns the subtype as Redact so it should indeed be a Redaction annotation.
                          My PDRedactionGetProps(annot, redactionProps); ;returns false
                          My PDRedactionGetProps(annot, &redactionProps); also returns false
                          My question is why doesn't this work.  Is it something wrong with my PDF.  I just create a blank PDF.  Then I go to Advanced -> Redaction- > Mark for redaction and draw my box somewhere on the page and give it an overlay text and then save the PDF.
                          I then run my plugin against this PDF and the about returns false.
                          Is my variable annot wrong?  I get it by going:
                          PDAnnot annot;
                          annot = PDGetAnnot(page, i2++)
                          Full code is this:
                          #include "PDExpT.h"
                          #include "PIHeaders.h"
                          #include "redax.h"
                          #include <functional>
                          #include <iostream>
                          void RedaxReports( TCHAR * path ) {
                               PDDoc myPDDoc = getDocument(path);
                               PDPage page;
                               ASInt32 i,i2;
                               PDAnnot annot;
                               char* ptr;
                               char buf[200];
                               ASAtom atom;
                               //Iterate through the PDF document page by page
                               for (i = 0; i < PDDocGetNumPages(myPDDoc); i ++)
                                    //Get each page within the document
                                    page = PDDocAcquirePage(myPDDoc, i);
                                    //Get each annotation on the page
                                    for (i2 = 0; i2 < PDPageGetNumAnnots(page); i2++)
                                         //Get a specific annotation
                                         annot = PDPageGetAnnot(page,i2);
                                         if (PDAnnotIsValid(annot))
                                              //Display subtype information about the annotation
                                              if(PDAnnotGetSubtype(annot) == ASAtomFromString("Redact")){
                                                   //Cast the ASAtom object to a character pointer
                                                   ptr = (char*) ASAtomGetString(atom);
                                                   sprintf(buf, "The annotation’s subtype is %s", ptr);
                                                   AVAlertNote (buf);
                                                   try{
                                                        PDRedactParamsRec  redactionProps;                     //Have also tried PDRedactParams redactionProps
                                                        if(PDRedactionGetProps(annot, &redactionProps)){     //Then put PDRedactionGetProps(annot, redactionProps) still returns false
                                                             sprintf(buf, "Returns True");
                                                             AVAlertNote (buf);
                                                        else
                                                             sprintf(buf, "Returns False");
                                                             AVAlertNote (buf);
                                                   catch (std::exception &cException){
                                                        AVAlertNote("ERROR");
                                                        AVAlertNote (cException.what());
                          }//RedaxReports
                          • 10. Re: Get location of an annotation
                            You have to fill in the redactionProps.size member to the sizeof(PDRedactParams)
                            • 11. Re: Get location of an annotation
                              tyerlv123 Level 1
                              Sorry thought the rest would be simple but alas another question relating to the initial question about the location of the box.
                              How do I use the redactQuads? and numQuads members?
                              More specially get the data out of the redactQuads.
                              ASFixedQuad *rect;
                              rect = redactionProps.redactQuads;
                              • 12. Re: Get location of an annotation
                                You have the data right there – now use them as coordinate sets on the page.  Not sure what you are missing?
                                • 13. Re: Get location of an annotation
                                  tyerlv123 Level 1
                                  Im trying to print the coordinate sets.
                                  • 14. Re: Get location of an annotation
                                    Remember to convert Fixed to something that you can print (like a float).
                                    • 15. Re: Get location of an annotation
                                      tyerlv123 Level 1
                                      But I can't access the members of rect? ie rect.bl
                                      • 16. Re: Get location of an annotation
                                        Top, left, bottom, right.
