4 Replies Latest reply on Apr 9, 2012 7:35 PM by maxr2012
    script to calculate the hypotenuse of a page and place a picture box
    maxr2012
      I'm wondering if someone can help me with a script.
      It needs to get the size of an open document, calculate the hypotenuse (diagonal), divide this by 10 and place a square picture box on the page at that size in the top left corner.
      I found this javascript to calculate the hypotenuse but don't know how to use it or integrate it.
      function hypotenuse(a, b) {
         function square(x) { return x*x; }
         return Math.sqrt(square(a) + square(b));
      function secondFunction(){
         var result;
         result = hypotenuse(1,2);
         alert( result );
      Yes I'm a total newbie and would appreciate anyones help.
      maxrus2012
        • 1. Re: script to calculate the hypotenuse of a page and place a picture box
          Marc Autret Level 5
          Hi maxrus,
          It sounds so simple that no one has found it necessary to answer you! Indeed, we can easily retrieve the height and the width of a page, then calculate the diagonal, then create a square based on that length.
          Anyway, let's try to make such routine work in any context, supporting any custom measurement units, rulers settings, rotated spreads and/or even scaled/skewed pages! To do so we need to avoid usual methods based on "geometric bounds". Interesting challenge!
          Here is my attempt:
          // Create a square based on the active page's diagonal length (10%)
          function measureDiagonal(/*Page*/page)
          // Ret. the page's diagonal in pts (relative to the page CS)
              var CS_INNER = CoordinateSpaces.innerCoordinates;
              var wh = page.resolve(AnchorPoint.bottomRightAnchor, CS_INNER)[0],
                  w = wh[0],
                  h = wh[1];
              return Math.sqrt(w*w + h*h); // Pythagorean theorem
          function createTopLeftCornerRectangle(/*Page*/page, /*num[2]*/wh)
          // wh: width and height of the rectangle in pts (relative to the page CS)
              // Some const shortcuts
              var    CS_SPREAD = CoordinateSpaces.spreadCoordinates,
                  CS_INNER = CoordinateSpaces.innerCoordinates,
                  RM_REPLACE = ResizeMethods.replacingCurrentDimensionsWith,
                  AP_TOP_LEFT = AnchorPoint.topLeftAnchor;
              var spread = page.parent,
                  // Create a rectangle (in the spread CS--the page CS is not relevant yet)
                  rec = spread.rectangles.add({fillColor:'Black'}),
                  // Page transformation values (relative to the spread)
                  pageMxValues = page.transformValuesOf(CS_SPREAD)[0].matrixValues;
              // Normalize the rectangle in the spread
              // (the size does not matter here)
              rec.reframe(CS_SPREAD, [[0,0],[10,10]]);
              // Apply the page transfo to the rectangle
              // so that its inner space fits the page space
              rec.transform(CS_SPREAD, [[0,0], CS_SPREAD], pageMxValues);
              // Finally, resize the rec
              rec.resize(CS_INNER, AP_TOP_LEFT, RM_REPLACE, wh.concat(CS_INNER));
              return rec;
          var    FACTOR = .1, // 10%
              win = app.layoutWindows.length && app.activeWindow,
              page = win && (win instanceof LayoutWindow) && win.activePage,
              size = page && page.isValid && FACTOR*measureDiagonal(page);
          size && createTopLeftCornerRectangle(page, [size,size]);
          Not sure this is exactly what you were looking after.
          Anyway...
          Marc
          • 2. Re: script to calculate the hypotenuse of a page and place a picture box
            John Hawkinson Level 5
            I think you might have scared him. Someone should demonstrate the easy way (I'll get to it...tomorrow?).
            • 3. Re: script to calculate the hypotenuse of a page and place a picture box
              maxr2012 Level 1
              Thanks Marc,
              This works great, it may be simple but I am still trying to get my head around it. I appreciate your quick response.
              Cheers,
              Max
              • 4. Re: script to calculate the hypotenuse of a page and place a picture box
                maxr2012 Level 1
                Hi John,
                I would love to see your spin on this as well if you have the time.
                Max
