5 Replies Latest reply on Apr 10, 2012 4:30 AM by JayCharles
    AppStats using onGetAppStats() in main.asc
    poojapooja
      I am trying to collect appstats using this code in main.asc.
      What is wrong here?
      application.onConnect = function( p_client, p_autoSenseBW )
           this.acceptConnection(p_client);
           nc_poll=new NetConnection();
           nc_poll.connect("rtmp://localhost:1111/admin","admin","a1s2d3f4");
           nc_poll.call("getAppStats",new onGetAppStats(), "vod");
          function onGetAppStats()
          this.onResult = function(info)
            trace("POOJA 1111");
            outputBox.text = "Info for "+appName.text+ " returned:" + newline;
            trace("POOJA 2222");
            printObj(info, outputBox);
          function printObj(obj, destination)
           trace("POOJA 3333");
           for (var prop in obj)
           destination.text += "\t";
           destination.text += prop + " = " + obj[prop] + newline;
           if (typeof (obj[prop]) == "object")
           trace("POOJA 4444");
            printObj(obj[prop], destination);
      thanks
        • 1. Re: AppStats using onGetAppStats() in main.asc
          JayCharles Champion
          1. Wait for the onStatus event from the NetConnection before invoking methods. Otherwise, you may be calling a method on a netconnection that hasn't been completed.
          2. Are you defining the nc_poll variable outside of the onConnect method? If not, the scope of nc_poll is the onConnect function, so when the function returns, the nc_poll variable will have gone out of scope, and will be eligible for garbage collection.
          • 2. Re: AppStats using onGetAppStats() in main.asc
            poojapooja Newcomer
            Hi JayCharles,
            I think onStatus event is received as seen in logs:
            2012-04-09  16:39:05    16248   (s)2641173  ******RECEIVED ONSTATUS******   -
            Main.asc file code is as below, Pls help.
            var nc_poll;
              nc_poll.onStatus = function(info)
               trace("******RECEIVED ONSTATUS******");
            nc_poll.connect("rtmp://localhost:1111/admin","admin","admin123");
            • 3. Re: AppStats using onGetAppStats() in main.asc
              JayCharles Champion
              You're still calling getAppStats on the connection without being sure the connection is established. Invoke a method outside of onConnect in response to the onStatus event.
              • 4. Re: AppStats using onGetAppStats() in main.asc
                poojapooja Newcomer
                Thanks Jay, i could write the correct code!!
                One query: This is giving stats when onConnect() is called from main.asc.
                If i need stats at just any time, where should i call admin api from?
                thanks.
                var nc_poll;
                  nc_poll.connect("rtmp://localhost:1111/admin","admin","admin");
                    if (info.code == "NetConnection.Connect.Success" && nc_poll.isConnected)
                      trace("We are connected");
                      nc_poll.call("getInstanceStats",new onGetInstanceStats(), "vod/_defInst_");
                  function onGetInstanceStats()
                    var dataobj=info.data;
                    trace("TOTAL NUMBER OF CONNECTIONS CURRENTLY ACTIVE: " +dataobj.connected);
                    trace("NUMBER OF CONNECTION ATTEMPTS ACCEPTED BY THIS APPLICATION: "+dataobj.accepted);
                    trace("NUMBER OF BYTES READ BY THIS APPLICATION: " +dataobj.bytes_in);
                    trace("NUMBER OF SOCKET CONNECTIONS TO THE APPLICATION SINCE THE APPLICATION WAS STARTED: " +dataobj.total_connects);
                • 5. Re: AppStats using onGetAppStats() in main.asc
                  JayCharles Champion
                  Create the connection in your onAppStart method, rather than the onConnect method.
                  Alternately, you can create a new class to manage this, and instantiate an instance of that class in your onAppStart.
