2 Replies Latest reply on Apr 4, 2012 8:51 PM by rantexfire
    how do i increase an integer
    rantexfire
      I'm tring to increase the valueof an integer by clicking a botton. the idea is this,
      a = 1
      a = a + 5
      so now
      a = 6
      each time hit button the value goes up by 5
      my code is this
      var myNum = 1;
      myButton.addEventListener (MOUSEEvent.CLICK, myIncreaseHandler)
      function myIncreaseHandler (evt ){
           var myNum = myNum + 5;
           myText.text = myNum.toString();
      but the number never increases
        • 1. Re: how do i increase an integer
          Mark Jawdoszak
          You're creating a new variable every time the button is clicked - so that new variable is being updated (probably saying "5" right?), not the global variable.
          Within your event handler, you want to put:
          function myIncreaseHandler( Event:event )
          myNum += 5;
          By ommiting the "var" portion, you are using the "var myNum = 1;" that you declared outside of the function.  Also, the "+= 5" part saves you a lot of re-writing, as this is an incrementor, and simply adds the next value to the existing value.
          Hope that helps!
          • 2. Re: how do i increase an integer
            rantexfire Level 1
            Yeah that helped. I ended up having to use myText.text is the integer start point instead of myNum =0;
