8 Replies Latest reply on Apr 4, 2012 4:16 PM by RjL190365
    What is faster?
    Parkd1234
      Hello!
      I have a Windows 7 computer and a 2011 MacBook Air
      The Windows Specs are:
      AMD Turion2 Dual Core Mobile M500
      4GB of RAM
      AMD M880g with ATI Radeon HD 4200
      320GB Hard Drive
      Mac Spects Are:
      Intel Core i5 1.6 GHz
      Intel HD 3000 Graphics
      4GB of Ram
      Now, What computer would be faster for basically everything In After Effects, Premiere Pro, Flah, and all those programs, WHATS FASTER???
        • 1. Re: What is faster?
          dh91 Level 1
          Do they both have SSD's?
          The Air's saving grace would be the SSD, but if you are hoping to do some professional work with these programs then I wouldn't suggest either one of them.
          • 2. Re: What is faster?
            As already said, neitehr of them is gonna have any significant advantage over the otehr. Where the otehr has a stronger processor, it only has a built-in graphics controller when the otehr has a weaker processor and a better graphics system. On balance, they will be pretty much the same in terms of working experience...
            Mylenium
            • 3. Re: What is faster?
              Dave LaRonde Level 7
              Parkd1234 wrote:
              WHATS FASTER???
              This is the After Effects-specific reply only: neither.  They're both low-horsepower machines.
              Why?  They only have 4 gigs of memory.  What does AE need to use multiprocessing?  Lots of memory.  On either machine you'd be limited to using just a single core.
              Not the most effective use of your processing power, is it?
              • 4. Re: What is faster?
                Todd_Kopriva Level 8
                See this page for information about hardware for Premiere Pro and After Effects: http://adobe.ly/pRYOuk
                • 5. Re: What is faster?
                  Harm Millaard Level 7
                  As said by others, neither. Even a severely handicapped elderly snail is way faster. Both systems are below minimum requirements, but maybe you can edit some very short (less than 10 minutes) SD DV material clips without effects if you are the patient type. Nothing more.
                  • 6. Re: What is faster?
                    Parkd1234 Level 1
                    Okay Thanks everyone. okay, so I obviously not going to make any big big big movies, just a few shorter ones...at max 10-15 mins. If I upgraded my Windows to 8GB of ram, would that make a big difference?
                    • 7. Re: What is faster?
                      That would be one step, but you need about four steps to make either system barely acceptable:
                      1. Better CPU and mobo.
                      2. Better memory.
                      3. Better video card.
                      4. At least 3 7200 RPM SATA disks.
                      Effectively you need a new system, but you can continue using the Macbook Air and the AMD for your kids  for some games.
                      • 8. Re: What is faster?
                        RjL190365 Level 4
                        As Harm stated, you'd still need a major hardware upgrade just to even run Premiere Pro to most people's satisfaction. No system with a dual-core CPU - not even a desktop - performs as fast as even a mediocre-performing quad-core CPU-based system. (For example, I got a dual-core i3-2100 system to achieve around 500 seconds total in the PPBM5 benchmark - but it took a GPU that costs significantly more money than the CPU, RAM and motherboard combined to achieve that result.) And since both of your laptops have only dual-core, low-clocked CPUs and lack any NVIDIA CUDA GPUs whatsoever, expect either system to perform at least 40 times slower than a fast i7 desktop Windows 7 PC.
                        So, in your case, given your current equipment, it would be more like "slower" and "slowest". In fact, the AMD Turion II can barely even run Premiere Pro at all since it performs slower than most of the Intel Core 2 Duo systems (both laptop and desktop).
