• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
5
Possible to move multiple layers from one Illustrator file to another?
Explorer ,
Apr 04, 2012 Apr 04, 2012
I have 2 large illustrator files (lets say version 1 and version 2). If I have 40 layers on version 2 that I want to send/add to version 1, is this possible (without copy/pasting in place each individual layer?)
thanks
Views
143.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Apr 04, 2012 Apr 04, 2012
in the layers panel flyout menu: make sure "paste remembers layers" is checked. Select  the artwork, copy paste in new document. It will recreate the layer structure as prev doc.
G
Votes
Translate
Translate
Adobe
Community Expert ,
G
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks!
Votes
Translate
Translate
Report
Report
New Here ,
Jun 24, 2015 Jun 24, 2015
I'm not sure if this function no longer works in CC or if I'm not doing it correctly, but I made sure "paste remembers layers" is active, then selected the layers and objects I wanted to copy, but when I paste in a new document it all pastes into the active layer. No new layers are created.
Votes
Translate
Translate
Report
Report
Community Expert ,
Paste Remembers Layers must be on in both documents.
Votes
Translate
Translate
Report
Report
Guest
Are you sure PRL can be set on a per document basis, Larry?
Votes
Translate
Translate
Report
Report
Community Expert ,
Yes, I just turn it on in the New Document Profile I use most.
Votes
Translate
Translate
Report
Report
Guest
Ok, then something must have changed.
I'm using AI CS5 and can set it only globally. That means it is not possible to have it turned on in Doc A and turned off in Doc B at the same time.
Votes
Translate
Translate
Report
Report
Community Expert ,
That may well be. I always work with it on.
Votes
Translate
Translate
Report
Report
Guest
Jeff, can you show a screenshot of your Layers palette (expanded)?
Votes
Translate
Translate
Report
Report
New Here ,
Feb 24, 2015 Feb 24, 2015
Thank you SOOO much. I knew there had to be a way to do this.
Votes
Translate
Translate
Report
Report
Community Expert ,
Sep 01, 2015 Sep 01, 2015
Sorry to resurrect this post, although i suppose it's not really THAT old.
I use Paste Remembers Layers for some very specific applications, but have it turned off most of the time because it can break other parts of my process. However, I'm attempting to build a new procedure for my mockup artists which requires specific layer hierarchy to be retained from one doc to the next. However, I've found that the oh so handy "paste remembers layers" option does not do anything for blank layers...
Does anybody know of a way to copy a layer (full of blank sublayers) from one document to the next? I may end up just scripting the process, but if i can avoid that i'd be very grateful.
Thanks.
Votes
Translate
Translate
Report
Report
Community Expert ,
Have you ever considered using template files or new document profiles?
Votes
Translate
Translate
Report
Report
Community Expert ,
Indeed. I'm actually building custom templates that are conducive to scripting for very specific artwork placement and naming rules. But sometimes those templates need to be merged together (some orders will have multiple styles in the same master file). So I'm building the template exactly how i need it, but in the event that i need to merge two or more, i'm looking for a way to maintain the layer structure (even if some layers are empty) because those empty layers may be filled later, and it's important for the subsequent scripts for those layers to be named properly and in the right level of hierarchy.
Votes
Translate
Translate
Report
Report
Community Expert ,
‌You might try using a small object of an oddball color on each layer, maybe off the artboard, to use as a place holder for the sub-layers when using "Paste Remembers Layers" and then delete it afterwards.
Votes
Translate
Translate
Report
Report
Community Expert ,
Sep 02, 2015 Sep 02, 2015
Thanks, Larry. I had considered that as well, but it leaves open the very likely possibility that an artist will forget to delete the placeholder artwork and then I will get blamed for the error that ensues when they attempt to run the script later. As is the nature of the operation i'm working in... I volunteered to script and automate our process, but nobody wants to change a single thing about their process because they can't see the tremendous time/money savings just over the hill.. But alas. I've decided to take on the challenge and gladly accept all the hurdles, because i know the knowledge and experience will only make me more valuable.
Anywho, Thanks for your suggestions. 😃
Votes
Translate
Translate
Report
Report
Community Expert ,
When you automate this with an action, you can include deleting the objects in the action.
Selecting object via a "Note" you apply to them ad delete. Read about actions in the manual.
Votes
Translate
Translate
Report
Report
Community Expert ,
Thanks. But I quit using actions for most things a long time ago. Especially when trying to reliably transverse multiple files. For one thing, an action cannot target a particular open document.. It can only target a saved document by filename. I need to reliably move objects from 1 file to another (including all layers and sub layers). There are some other stipulations that actions cannot access as well, such as unlocking layers by name. And most of all, the actions panel has been all but forgotten about by Adobe. There are a multitude of stability issues that have been present for years and Adobe has never even acknowledged them. So i keep my actions use down to a minimum (performing tasks that don't have hotkeys or the ability to add a hotkey such as align and pathfinder functions, and certain other things that javascript doesn't do very well such as selecting all text objects).
I do appreciate your suggestions, but JavaScript is the only tool that will do all the things i need to do, I was just hoping that there was a way around that blank layer issue.
Thanks again.
Votes
Translate
Translate
Report
Report
Community Expert ,
Check out the last post in this for a method to create and remove an action which might be what you need to remove the objects from your files.
Votes
Translate
Translate
Report
Report
Contributor ,
May 18, 2016 May 18, 2016
In my case, I got the error underneat, although both documents have the same size.
Solution: use 'Place in Front or Place in Back', which past the layer on the same position.
Votes
Translate
Translate
Report
Report
Community Expert ,
May 25, 2016 May 25, 2016
alternatively, paste in place, which is essentially paste in front i suppose. but it is another option.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 12, 2017 Oct 12, 2017
Thanks so much! I had no idea you could do that in Illustrator! This shortcut will save me TONS of time in the future! Can't believe I spent so much time in the past copying and pasting individual elements. Haha
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 21, 2019 Jun 21, 2019
Is it possible to duplicate a layer and avoid having both the parent and sublayers automatically get "copy" appended to the end of the layer name? I don't mind it for the parent layer but it becomes a major pain when having to also rename sublayers. Essentially we use this to track design options and each sublayer gets a graphic style applied for consistency. This way it's much easier to maintain or purge out old obsolete options. An ideal solution might be to specify the new layer name after running the 'Duplicate [Layer]' command rather than the command blasting all new layers with the 'copy' text appended to the end.
Thoughts on this anyone?
Votes
Translate
Translate
Report
Report
Participant ,
Jan 27, 2021 Jan 27, 2021
LATEST
This doesn't preserve the layer hierarchy.
Votes
Translate
Translate
Report
Report
