1 Reply Latest reply on Apr 7, 2012 5:40 PM by A.Liebscher
    FileReference filtering the save as file type
    jetrased
      Hi
      I am wondeirng if anyone can tell me if it is possible to filter/specify the save as types for a fileReference.save().
      I know to browse you can set the filetypes
      files = new FileReference();
      files.browse(new Array(new FileFilter("Image (*.png)", "*.png")));
      However I am looking to be able to set the save as type to say jpg, png, bmp. Is this possible?
        • 1. Re: FileReference filtering the save as file type
          A.Liebscher Level 1
          This seems to work for me....
          var file:File = File.desktopDirectory;
          file.browseForSave ("Save as *.your file type");
          file.addEventListener (Event.SELECT, onSaveSelect);
          function onSaveSelect(event:Event):void
               var array:Object = Object(arrCol);
               var saveFile:File = File(event.target);
               var directory:String = saveFile.url;
               if (directory.indexOf(".your file type") == -1)
                    directory +=  ".your file type";
               var file:File = new File(directory);
               var fileStream:FileStream = new FileStream();
               fileStream.open (file, FileMode.WRITE);
               fileStream.writeObject(array);
               fileStream.close ();
          It opens up the save dialog, but you don't have to enter a file type. When you click the save, or select, button it saves as whatever file type you want. If you need help understanding this method, just ask.
