• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Trying to install Flash Player but fails
New Here ,
Apr 04, 2012 Apr 04, 2012
OK I have been at this for hours, I am running Firefox, I try to access an online game, says need flash plugin. I click to install, Next window pops up and says installation failed then gives a manual installation button. I click on that, verify window comes up and completes verification, installation window comes up and gets to 47% then says installation failed. When I click finish it takes me tyo the adobe troubleshooting page. I have done EVERYTHING there including downloading the uninstall flash player program and ran that as well, said flash was uninstalled then ran everything above again. I don't know what else to do.
Views
32.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
same problem. failed to initialise error. i've tried all solutions in your adobe forums and nothing ever happens same problen failed to initialise errors.
Votes
Translate
Translate
Report
Report
New Here ,
And of course the employees seem to be ignoring all those with the same problem. It's driving me mad.
Votes
Translate
Translate
Report
Report
LEGEND ,
From the forum top:
To assist us in quickly understanding your problem, please follow these guidelines when posting:
  • Specify your operating system (including 32bit or 64bit edition)
  • Specify your web browser and version (including 32bit or 64bit edition)
  • Specify your Flash Player version
  • Give us a brief explanation of the problem, please include any information you feel is important
  • Please do not use existing topics to append questions that are entirely different from the original topic. When in doubt create a new topic.
Votes
Translate
Translate
Report
Report
New Here ,
I don't mean to sound sarcastic, but can't you read, I said I'm running XP, with Firefox (thats a browser) I have an old laptop running in 32bit, can't handle 64, and I have NO FLASH CAUSE IT WON'T INSTALL...geesh
Votes
Translate
Translate
Report
Report
Advisor ,
Download the current 32 uninstaller Uninstaller for 32 bit Operating Systems
Close all browser windows and run the uninstaller
Restart Windows
Delete all remaining files and folders located in the following directories. (tip: copy and paste these paths into the path bar in a Windows Explorer window)
  • C:\Windows\system32\Macromed\Flash
  • %appdata%\Adobe\Flash Player
  • %appdata%\Macromedia\Flash Player
  Verify that the file “FlashPlayerCPLApp.cpl” in C:\Window\system32\ for 32 bit systems has been deleted.
Download the following file:
Physically disconnect from the Internet and run the files.
Votes
Translate
Translate
Report
Report
LEGEND ,
No, I cannot read what you don't post; you merely mentioned Firefox in your initial post.
Try a clean install, as follows:
  1. Download the current 32-bit uninstaller
  2. Close all browser windows and run the uninstaller
  3. Restart Windows
  4. Delete all remaining files and folders located in the following directories.  (tip: copy and paste these paths into the path bar in an Explorer window)
  5. Verify that the file “FlashPlayerCPLApp.cpl” in C:\Window\system32 has been deleted
  6. download the installer(s)
  7. close all browser windows and run the downloaded installers.
Message was edited by: Pat Willener - oops, looks like I posted simultaneously with Carl.
Votes
Translate
Translate
Report
Report
Guest
May 16, 2013 May 16, 2013
In my case, it has nothing to do with 32 bit or 64bits at all.
Did you get the message given by the Windows Installer "The system administrator has set policies to prevent this installation" when Windows failed to install the Adobe Flash Player version 11? If that's the case, you can read the following:
Nowaday the security of the installation of SW for Windows is getting more and more strict. I have failed to install Flash player receiving the above mentioned msg while I am already the administrator . I tried to change the SW property but nothing works. I looked for how to change the installation policies,  but found nothing. Then I went back to the basic seacrhing for above mentioned msg, someone suggests that you can just go to the downloaded SW, "right click" on it and you should see "run as administrator". You should click on that option. Yes, funny enough that I am already the administrator but it works. The SW was installed without problem. I am not sure why Windows has such problem but it's not normal that me as administrator of my own computer can't install a SW and it complains about a policy that I didn't set....
Another thing I faced is that only installing flash player is not sufficient to see some graphics or games, etc. You might need to Install Java as well. After install these two SW, you also need to enable the internet option "Run Active X and Plug-ins".
Steps to do it:
Tools -> internet option -> security -> choose the the zone "internet" -> custom level -> scroll down to find "Run Active X and Plug-ins" and click "enable"
It works for me that now I can see the graphics again. I hope it would help you too. Another option is to use Firefox. I could see everything without any installation. Maybe it's less stressful but it's also fun to look for solution and solve it. Good for the brain  😉
ps. sorry, I didn't see that you use firefox.... that's starnge... because it works fine for me. Then check if you have to set something in the internet option.
Good luck!
Votes
Translate
Translate
Report
Report
New Here ,
Dec 22, 2019 Dec 22, 2019
Where this patn appears?
I checked out google Crome.May be you are working withnfirefox.BUt can you suggest a parellel solution.I also tried all the other options.I too am facing this problem of enabling "Run Active X and Plug-ins", please educate me on this!
Votes
Translate
Translate
Report
Report
New Here ,
Dec 23, 2019 Dec 23, 2019
Ok well noted thanks
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jan 06, 2020 Jan 06, 2020
LATEST
You are replying to a post that is almost 8 years old.  Whatever solution to the problem at that time may not be the same as yours, considering browser technology has evolved quite a bit since then.  Please start a new discussion topic and provide the following information:
  • Operating system, including version
  • Browser, including version
  • A description of the issue encountered, including screenshot of any error returned
  • step-by-step instructions to reproduce.
In the interim, locking this topic due to it's age.
Votes
Translate
Translate
Report
Report
