8 Replies Latest reply on Apr 13, 2012 7:10 PM by johnrdm
    Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
    johnrdm
      I just installed CS4 Master Collection on my new MacBook Pro running Lion 10.7.3
      Photoshop crashes immediatly I try and open a file.
      Other items (InDesign, Bridge and Illustrator) seem to work OK.
      NEED HELP!!!!
      Best,
      John
        • 1. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
          c.pfaffenbichler Level 8
          Boilerplate-text:
          Are Photoshop and OS fully updated?
          As with all unexplainable Photoshop-problems you might try trashing the prefs (after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed) by keeping command-alt-shift pressed on starting the program or starting from a new user-account.
          System Maintenance (repairing permissions, purging PRAM, running cron-scripts, cleaning caches, etc.) might also be beneficial, Onyx has been recommended for such tasks.
          http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
          Weeding out bad fonts never seems to be a bad idea, either. (Validate your fonts in Font Book and remove the bad ones.)
          If 3rd party plug-ins are installed try disabling them to verify if one of those may be responsible for the problem.
          • 2. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
            johnrdm Level 1
            Thanks for your reply.
            CS4 and OS are fully updated.
            I have repaired disk utilities.
            Photoshop opens, then when I select anything (like Help, File etc) it crashes immediately.
            Any other suggestions?
            John
            • 3. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
              You also did the command-alt-shift preference-removal and tried starting from a new user-account?
              If so you could try to clean up and install anew, but I have no idea if that would do any good.
              http://www.adobe.com/support/contact/cscleanertool.html
              • 4. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
                Level 7
                Without seeing the crash report, we can't even guess as to what might be happening.
                • 5. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
                  johnrdm Level 1
                  Here is the crash report:
                  Process:     Adobe Photoshop CS4 [1826]
                  Path:        /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
                  Identifier:  com.adobe.Photoshop
                  Version:     11.0.2 [11.0.2x20100519 [20100519.r.592 2010/05/19:02:00:00 cutoff; r branch]] (11.0.2)
                  Code Type:   X86 (Native)
                  Parent Process:  launchd [146]
                  Date/Time:   2012-04-08 22:14:48.457 -0700
                  OS Version:  Mac OS X 10.7.3 (11D50d)
                  Report Version:  9
                  Interval Since Last Report:      444989 sec
                  Crashes Since Last Report:       10
                  Per-App Interval Since Last Report:  984 sec
                  Per-App Crashes Since Last Report:   5
                  Anonymous UUID:                  153F03DD-378E-45C4-93A4-865304469730
                  Crashed Thread:  21  Dispatch queue: com.apple.root.low-overcommit-priority
                  Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
                  Exception Codes: KERN_INVALID_ADDRESS at 0x00000000ffffffa5
                  VM Regions Near 0xffffffa5:
                  --> shared memory      00000000ffff0000-00000000ffff2000 [8K] r-x/r-x SM=SHM
                  Application Specific Information:
                  objc[1826]: garbage collection is OFF
                  Thread 0:: Dispatch queue: opencl_runtime
                  0   libsystem_kernel.dylib    0x96d25c5e semaphore_wait_trap + 10
                  1   libdispatch.dylib         0x9c45c32c _dispatch_thread_semaphore_wait + 25
                  2   libdispatch.dylib         0x9c45b470 _dispatch_barrier_sync_f_slow + 121
                  3   libdispatch.dylib         0x9c45b584 dispatch_barrier_sync_f + 37
                  4   libcldcpuengine.dylib     0x26a39eff glrCompFinish + 48
                  5   com.apple.opencl          0x9016d0d8 processFinish + 35
                  6   libdispatch.dylib         0x9c45b4cd _dispatch_barrier_sync_f_slow + 214
                  7   libdispatch.dylib         0x9c45b584 dispatch_barrier_sync_f + 37
                  8   com.apple.opencl          0x9016d1cb clFinish + 123
                  9   com.apple.CoreImage       0x9caa43ed -[FEOpenCLContext _quad:] + 4153
                  10  com.apple.CoreImage       0x9cbb96d3 -[FEContext(Drawing) quad:] + 42
                  11  com.apple.CoreImage       0x9cae1320 FEApplyTreeNode::render1(FETreeContext*, FEShape const&, fe_kernel_target_struct*, int, float*, FETreeTexture*) + 2160
                  12  com.apple.CoreImage       0x9cae1b40 FEApplyTreeNode::render2(FETreeContext*, FEShape const*, void (*)(FEContext*, void*, FEFormat), void (*)(FEContext*, void*), void*) + 1618
                  13  com.apple.CoreImage       0x9cadee4b FETreeNode::render_(FETreeContext*, FEShape const*, void (*)(FEContext*, void*, FEFormat), void (*)(FEContext*, void*), void*) + 119
                  14  com.apple.CoreImage       0x9cae2811 FETreeNode::render(FETreeContext*, FEShape const&, void (*)(FEContext*, void*, FEFormat), void (*)(FEContext*, void*), void*) + 97
                  15  com.apple.CoreImage       0x9cae27aa FETreeContext::render(FETreeNode*, FEShape const&, void (*)(FEContext*, void*, FEFormat), void (*)(FEContext*, void*), void*) + 52
                  16  com.apple.CoreImage       0x9cae60c3 FETreeContext::renderTree(FETreeNode*, FEShape const&, void (*)(FEContext*, void*, FEFormat), void (*)(FEContext*, void*), void*) + 189
                  17  com.apple.CoreImage       0x9cae63b0 FETreeContext::renderImage_(FEImage*, CGRect, FEShape const*, CGAffineTransform, CGColorSpace*, FEFormat, bool, void (*)(FEContext*, void*, FEFormat), void (*)(FEContext*, void*), void*) + 686
                  18  com.apple.CoreImage       0x9cae661b FETreeContext::renderImage(FEImage*, CGRect, FEShape const*, CGAffineTransform, CGColorSpace*, FEFormat, bool, void (*)(FEContext*, void*, FEFormat), void (*)(FEContext*, void*), void*) + 361
                  19  com.apple.CoreImage       0x9cabb79a -[FEImage(Internal) _renderWithContext:bounds:transform:colorSpace:format:premultiplied:setupCallback:finishC allback:callbackData:] + 273
                  20  com.apple.CoreImage       0x9cabb02d -[FEImage getBitmap:withContext:origin:transform:colorSpace:] + 1543
                  21  com.apple.CoreImage       0x9ca6c8bd -[CIContextImpl render:toBitmap:rowBytes:bounds:format:colorSpace:] + 323
                  22  com.apple.CoreImage       0x9ca6b7ae -[CIContext render:toBitmap:rowBytes:bounds:format:colorSpace:] + 114
                  23  libCGXCoreImage.A.dylib   0x9b122951 cgxcoreimage_instance_render + 3799
                  24  libCGXCoreImage.A.dylib   0x9b12193c cgxcoreimage_provider_create_data + 83
                  25  libCGXCoreImage.A.dylib   0x9b12188a faultDataAcquireBytePointer + 181
                  26  com.apple.CoreGraphics    0x97bf05ac CGAccessSessionGetBytePointer + 39
                  27  com.apple.CoreGraphics    0x97c200be img_decode_read + 164
                  28  com.apple.CoreGraphics    0x97c1ff1f img_colormatch_read + 339
                  29  com.apple.CoreGraphics    0x97c1fc62 img_alphamerge_read + 295
                  30  com.apple.CoreGraphics    0x97c1db55 img_data_lock + 8151
                  31  com.apple.CoreGraphics    0x97ca63c0 CGSImageDataLock + 165
                  32  libRIP.A.dylib            0x90e6d989 ripc_AcquireImage + 1901
                  33  libRIP.A.dylib            0x90e6c1db ripc_DrawImage + 951
                  34  com.apple.CoreGraphics    0x97ca6025 CGContextDrawImage + 437
                  35  com.apple.coreui          0x9ce4f27a CUIPenCG::DrawImage(void*, CGRect, void*) + 66
                  36  com.apple.coreui          0x9ce5647b CUIRenderer::DrawImage(CGRect, long, CUIDescriptor const*) + 5437
                  37  com.apple.coreui          0x9ce2c3fd CUIRenderer::Draw(CGRect, CGContext*, __CFDictionary const*, __CFDictionary const**) + 5361
                  38  com.apple.coreui          0x9ce4c619 CUIDraw + 206
                  39  com.apple.HIToolbox       0x92a5bf98 _ZL28_HIThemeDrawMenuItemInternalPK6CGRectS1_PK24_HIThemeMenuItemDrawInfoP19MenuItemDrawi ngXUPPmP9CGContextmPS_ + 1598
                  40  com.apple.HIToolbox       0x92a5c4a0 HIThemeDrawMenuItem + 60
                  41  com.apple.HIToolbox       0x92ad349c HIStandardMenuView::DrawThemeItem(CGRect const*, CGRect const*, _HIThemeMenuItemDrawInfo const*, CGContext*, unsigned long, unsigned char, CGRect*) + 200
                  42  com.apple.HIToolbox       0x92ad6288 HIStandardMenuView::HandleEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*) + 1678
                  43  com.apple.HIToolbox       0x929ee59b HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 163
                  44  com.apple.HIToolbox       0x92b7262c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
                  45  com.apple.HIToolbox       0x929edf4f _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
                  46  com.apple.HIToolbox       0x929ed3cc _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 482
                  47  com.apple.HIToolbox       0x929ed1e4 SendEventToEventTargetWithOptions + 75
                  48  com.apple.HIToolbox       0x929f7994 MenuData::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 420
                  49  com.apple.HIToolbox       0x92b7262c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
                  50  com.apple.HIToolbox       0x929edf4f _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
                  51  com.apple.HIToolbox       0x929ed3cc _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 482
                  52  com.apple.HIToolbox       0x92a30f68 CallNextEventHandler + 79
                  53  com.adobe.Photoshop       0x000e1f70 0x1000 + 921456
                  54  com.apple.HIToolbox       0x92b7262c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
                  55  com.apple.HIToolbox       0x929edf4f _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
                  56  com.apple.HIToolbox       0x929ed3cc _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 482
                  57  com.apple.HIToolbox       0x929ed1e4 SendEventToEventTargetWithOptions + 75
                  58  com.apple.HIToolbox       0x92ad3e47 HIStandardMenuView::DrawItem(unsigned char, CGContext*, unsigned char) + 2409
                  59  com.apple.HIToolbox       0x92ad57e2 HIStandardMenuView::DrawSelf(short, __HIShape const*, CGContext*) + 470
                  60  com.apple.HIToolbox       0x92a0dc22 HIView::DrawCacheOrSelf(short, __HIShape const*, CGContext*) + 86
                  61  com.apple.HIToolbox       0x92a0da42 HIView::SendDraw(short, OpaqueGrafPtr*, __HIShape const*, CGContext*) + 124
                  62  com.apple.HIToolbox       0x92a9c5c7 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 755
                  63  com.apple.HIToolbox       0x92a9c8b9 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1509
                  64  com.apple.HIToolbox       0x92a9c8b9 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1509
                  65  com.apple.HIToolbox       0x92a9d86b HIView::DrawComposited(short, OpaqueGrafPtr*, __HIShape const*, unsigned long, HIView*, CGContext*) + 1227
                  66  com.apple.HIToolbox       0x92a9d9b3 HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 81
                  67  com.apple.HIToolbox       0x92a9dd7b HIView::Render(unsigned long, CGContext*) + 45
                  68  com.apple.HIToolbox       0x92a3384f WindowData::PrepareForVisibility() + 137
                  69  com.apple.HIToolbox       0x92cbc713 _HIWindowPrepareForVisibility + 29
                  70  com.apple.HIToolbox       0x92bca295 _ZL8DrawMDEFP14MenuSelectData7CGPoint + 698
                  71  com.apple.HIToolbox       0x92bca820 _ZL11DrawTheMenuP14MenuSelectDataPP9__CFArrayhPh + 622
                  72  com.apple.HIToolbox       0x92bcabee _ZL11MenuChangedP14MenuSelectDatahh + 608
                  73  com.apple.HIToolbox       0x92a3a29d _ZL15TrackMenuCommonR14MenuSelectDataPh + 1235
                  74  com.apple.HIToolbox       0x92bce474 _ZL14MenuSelectCoreP8MenuData5PointdmPP13OpaqueMenuRefPt + 420
                  75  com.apple.HIToolbox       0x92bce62b MenuSelect + 178
                  76  com.adobe.Photoshop       0x00064a72 0x1000 + 408178
                  77  com.adobe.Photoshop       0x00675df8 0x1000 + 6770168
                  78  com.adobe.Photoshop       0x000647e3 0x1000 + 407523
                  79  com.adobe.Photoshop       0x0007b995 0x1000 + 502165
                  80  com.adobe.Photoshop       0x00063c65 0x1000 + 404581
                  81  com.adobe.Photoshop       0x00063dd3 0x1000 + 404947
                  82  com.adobe.Photoshop       0x0006212f 0x1000 + 397615
                  83  com.adobe.Photoshop       0x002205da 0x1000 + 2225626
                  84  com.adobe.Photoshop       0x00220666 0x1000 + 2225766
                  85  com.adobe.Photoshop       0x00003812 0x1000 + 10258
                  86  com.adobe.Photoshop       0x00003739 0x1000 + 10041
                  Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                  0   libsystem_kernel.dylib    0x96d2890a kevent + 10
                  1   libdispatch.dylib         0x9c45ac58 _dispatch_mgr_invoke + 969
                  2   libdispatch.dylib         0x9c4596a7 _dispatch_mgr_thread + 53
                  Thread 2:
                  0   libsystem_kernel.dylib    0x96d2783e __psynch_cvwait + 10
                  1   libsystem_c.dylib         0x9c36be78 _pthread_cond_wait + 914
                  2   libsystem_c.dylib         0x9c31382a pthread_cond_wait + 48
                  3   com.adobe.amt.services    0x0bf41552 AMTConditionLock::LockWhenCondition(int) + 46
                  4   com.adobe.amt.services    0x0bf3c995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
                  5   com.adobe.amt.services    0x0bf415b0 AMTThread::Worker(void*) + 20
                  6   libsystem_c.dylib         0x9c367ed9 _pthread_start + 335
                  7   libsystem_c.dylib         0x9c36b6de thread_start + 34
                  Thread 3:
                  0   libsystem_kernel.dylib    0x96d25c76 semaphore_timedwait_trap + 10
                  1   com.apple.CoreServices.CarbonCore0x94ebaa98 MPWaitOnSemaphore + 104
                  2   MultiProcessor Support    0x26a8feff 0x26a60000 + 196351
                  3   com.apple.CoreServices.CarbonCore0x94ebb5e0 PrivateMPEntryPoint + 68
                  4   libsystem_c.dylib         0x9c367ed9 _pthread_start + 335
                  5   libsystem_c.dylib         0x9c36b6de thread_start + 34
                  Thread 4:
                  Thread 5:
                  Thread 6:
                  Thread 7:
                  Thread 8:
                  Thread 9:
                  Thread 10:
                  1   libsystem_c.dylib         0x9c36be21 _pthread_cond_wait + 827
                  2   libsystem_c.dylib         0x9c31c42c pthread_cond_wait$UNIX2003 + 71
                  3   com.apple.CoreServices.CarbonCore0x94ee6e62 TSWaitOnCondition + 124
                  4   com.apple.CoreServices.CarbonCore0x94e583c5 TSWaitOnConditionTimedRelative + 136
                  5   com.apple.CoreServices.CarbonCore0x94eba681 MPWaitOnQueue + 200
                  6   AdobeACE                  0x027c038d 0x278f000 + 201613
                  7   AdobeACE                  0x027bfd85 0x278f000 + 200069
                  8   com.apple.CoreServices.CarbonCore0x94ebb5e0 PrivateMPEntryPoint + 68
                  9   libsystem_c.dylib         0x9c367ed9 _pthread_start + 335
                  10  libsystem_c.dylib         0x9c36b6de thread_start + 34
                  Thread 11:
                  Thread 12:
                  Thread 13:
                  Thread 14:
                  Thread 15:
                  Thread 16:
                  Thread 17:
                  0   libsystem_kernel.dylib    0x96d25d36 mach_wait_until + 10
                  1   libsystem_c.dylib         0x9c315439 nanosleep + 388
                  2   com.adobe.PSAutomate      0x2a8381b1 ScObjects::Thread::sleep(unsigned int) + 143
                  3   com.adobe.PSAutomate      0x2a838211 ScObjects::Thread::wait(unsigned int) + 23
                  4   com.adobe.PSAutomate      0x2a828dc6 ScObjects::BridgeTalkThread::run() + 332
                  5   com.adobe.PSAutomate      0x2a8384d3 ScObjects::Thread::go(void*) + 239
                  Thread 18:: Dispatch queue: com.apple.root.low-overcommit-priority
                  0   cl_kernels                0x26a5583b __program_Vectorized_wrapper + 843
                  1   libcldcpuengine.dylib     0x26a3a803 cld_exec_workitem + 637
                  2   libdispatch.dylib         0x9c45ccdb _dispatch_apply2 + 62
                  3   libdispatch.dylib         0x9c45cc43 dispatch_apply_f + 360
                  4   libcldcpuengine.dylib     0x26a3a568 cld_exec_kernel + 104
                  5   libdispatch.dylib         0x9c45a797 _dispatch_queue_drain + 224
                  6   libdispatch.dylib         0x9c45a63c _dispatch_queue_invoke + 47
                  7   libdispatch.dylib         0x9c459e44 _dispatch_worker_thread2 + 187
                  8   libsystem_c.dylib         0x9c369b24 _pthread_wqthread + 346
                  9   libsystem_c.dylib         0x9c36b6fe start_wqthread + 30
                  Thread 19:
                  2   libsystem_c.dylib         0x9c36bf7b pthread_cond_timedwait_relative_np + 47
                  3   com.apple.CoreServices.CarbonCore0x94e583ef TSWaitOnConditionTimedRelative + 178
                  4   com.apple.CoreServices.CarbonCore0x94e58165 TSWaitOnSemaphoreCommon + 490
                  5   com.apple.CoreServices.CarbonCore0x94e57f76 TSWaitOnSemaphoreRelative + 24
                  6   com.apple.CoreServices.CarbonCore0x94e9c61d AsyncFileThread(void*) + 248
                  7   libsystem_c.dylib         0x9c367ed9 _pthread_start + 335
                  8   libsystem_c.dylib         0x9c36b6de thread_start + 34
                  Thread 20:: Dispatch queue: com.apple.root.low-overcommit-priority
                  0   cl_kernels                0x26a55832 __program_Vectorized_wrapper + 834
                  3   libdispatch.dylib         0x9c459e70 _dispatch_worker_thread2 + 231
                  4   libsystem_c.dylib         0x9c369b24 _pthread_wqthread + 346
                  5   libsystem_c.dylib         0x9c36b6fe start_wqthread + 30
                  Thread 21 Crashed:: Dispatch queue: com.apple.root.low-overcommit-priority
                  Thread 22:: Dispatch queue: com.apple.root.low-overcommit-priority
                  0   libsystem_kernel.dylib    0x96d2802e __workq_kernreturn + 10
                  1   libsystem_c.dylib         0x9c367942 pick_nextworkqueue_droplock + 696
                  2   libsystem_c.dylib         0x9c367b73 pthread_workqueue_additem_np + 273
                  3   libdispatch.dylib         0x9c4594e2 _dispatch_queue_wakeup_global + 140
                  4   libdispatch.dylib         0x9c459e15 _dispatch_worker_thread2 + 140
                  5   libsystem_c.dylib         0x9c369b24 _pthread_wqthread + 346
                  6   libsystem_c.dylib         0x9c36b6fe start_wqthread + 30
                  Thread 23:
                  0   libsystem_c.dylib         0x9c36b6e0 start_wqthread + 0
                  Thread 21 crashed with X86 Thread State (32-bit):
                    eax: 0x00000000  ebx: 0x05180d58  ecx: 0x00000080  edx: 0x00000000
                    edi: 0x00000002  esi: 0x00000001  ebp: 0xb010fe18  esp: 0xb010eb00
                     ss: 0x00000023  efl: 0x00010202  eip: 0x26a5583b   cs: 0x0000001b
                     ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
                    cr2: 0xffffffa5
                  Logical CPU: 2
                  Binary Images:
                  0x1000 -  0x19aefdf +com.adobe.Photoshop (11.0.2 [11.0.2x20100519 [20100519.r.592 2010/05/19:02:00:00 cutoff; r branch]] - 11.0.2) <40DBAC70-2688-44B1-A8CE-142BF8A18887> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
                  0x207f000 -  0x2085fff  org.twain.dsm (1.9.4 - 1.9.4) <3269566F-997C-3E69-82D2-CAEDC827C249> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                  0x208c000 -  0x246601f +com.adobe.linguistic.LinguisticManager (4.0.0 - 7863) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                  0x251a000 -  0x2714fcf +AdobeOwl (??? - ???) <4CCA2C7B-4896-4DDA-A14B-725FB0C202B5> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                  0x278f000 -  0x289cfff +AdobeACE (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                  0x28ba000 -  0x2c84fef +AdobeMPS (??? - ???) <277E01A3-CAC3-4FA9-A591-4BC0A5BC125A> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                  0x2d13000 -  0x2d73fc7 +AdobeXMP (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                  0x2d82000 -  0x307dfff +AdobeAGM (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                  0x313d000 -  0x33d0fe7 +AdobeCoolType (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                  0x3454000 -  0x346dfff +AdobeBIB (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                  0x3477000 -  0x3498ff7 +AdobeBIBUtils (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                  0x34a5000 -  0x34c0ff9 +AdobePDFSettings (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
                  0x34da000 -  0x34feff6 +AdobeAXE8SharedExpat (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                  0x3511000 -  0x359e2cb +libicucnv.dylib.36.0 (36.0.0 - compatibility 36.0.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
                  0x35cb000 -  0x35e680f +libicudata.dylib.36.0 (36.0.0 - compatibility 36.0.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
                  0x35e9000 -  0x379fff4 +com.adobe.amtlib (amtlib 2.0.1.10077 - 2.0.1.10077) <CB2EC3BF-6771-4DAB-BF29-6775FB6F9608> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                  0x37d6000 -  0x3866fc3 +WRServices (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                  0x39e8000 -  0x39ecffc +com.adobe.AdobeCrashReporter (2.5 - 3.0.20080806) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                  0x39f2000 -  0x3a0efd7 +com.adobe.LogTransport (1.0 - 1.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
                  0x3a19000 -  0x3aeefdd +FileInfo (??? - ???) <F0932F89-FC98-4BA9-B4F2-C58D0E71D3C1> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                  0x3b1f000 -  0x3b76fff +aif_core (??? - ???) <B4DCB439-E1EE-ABE3-BD12-2C42E980366B> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                  0x3b8e000 -  0x3babffd +data_flow (??? - ???) <8E452B6F-8032-39D8-EB5C-49A4E31CB988> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
                  0x3bd7000 -  0x3c50fff +image_flow (??? - ???) <498A857D-F8C6-F9E0-C92F-BC3EC8680ED0> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
                  0x3cb6000 -  0x3cc6fff +image_runtime (??? - ???) <F379A952-2983-1E44-676D-BBD8259F131A> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                  0x3cdb000 -  0x3e9affe +aif_ogl (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                  0x3f4b000 -  0x4449fc3 +AdobeOwlCanvas (??? - ???) <FCB2D1A3-1F6E-4182-8E2C-D0B23572D285> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/AdobeOwlCanvas
                  0x4592000 -  0x4664fe7 +AdobeAXEDOMCore (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                  0x4718000 -  0x477afe7 +com.adobe.PlugPlug (1.0.0.73 - 1.0.0.73) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                  0x47db000 -  0x4822fc7 +com.adobe.adobe_caps (adobe_caps 2.0.99.0 - 2.0.99.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                  0x4832000 -  0x486ffff  com.apple.vmutils (4.2.1 - 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                  0x4fed000 -  0x4feeff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                  0x4ff5000 -  0x4ff7fff +com.Logitech.Control Center.Scroll Enhancer Loader (2.6.0 - 2.6.0) /Library/InputManagers/*/LCC Scroll Enhancer Loader.bundle/Contents/MacOS/LCC Scroll Enhancer Loader
                  0x7400000 -  0x7402fff +com.Logitech.Control Center.Scroll Enhancer (2.6.0 - 2.6.0) /Library/Application Support/Logitech/LCC Scroll Enhancer.bundle/Contents/MacOS/LCC Scroll Enhancer
                  0x742b000 -  0x7439ffb  libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <4378B89F-0BDA-3072-9C67-DE1A371DD816> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                  0x743d000 -  0x744ffff  libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <F7D2A96C-D03F-3C0B-83FC-1016BB787B59> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                  0x7453000 -  0x7454ffc  ATSHI.dylib (??? - ???) <805E9255-39D3-3137-8DA9-3C69182D9BD7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                  0x745d000 -  0x746aff7 +com.adobe.asneu.framework (asneu version 1.6.2f01 - 1.6.2) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
                  0x7478000 -  0x7478fff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <859B5BCC-B5D9-370F-8B6C-1E2B242D5DCD> /usr/lib/libmx.A.dylib
                  0x747b000 -  0x747dffa +Adobe Unit Types (a2.0.0 - 2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
                  0x7481000 -  0x7483fff +com.Logitech.Control Center.Scroll Enhancer OSAX Loader (2.6.0 - 2.6.0) /Library/ScriptingAdditions/LCC Scroll Enhancer Loader.osax/Contents/MacOS/LCC Scroll Enhancer Loader
                  0x77ec000 -  0x77f7fff +Enable Async IO (??? - ???) <FD91E79F-C4AA-4EBC-AF6D-3E154F14878F> /Applications/Adobe Photoshop CS4/*/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
                  0xbf21000 -  0xbfc2fc3 +com.adobe.amt.services (AMTServices 2.0.1.10077 [BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09] - 2 . 0) <31E82904-C3C2-424E-A1AE-A5EFADBB19B8> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservices
                  0xc0df000 -  0xc0ed02f +FastCore (??? - ???) <F12878B7-BEE9-40CA-9F05-65CD0F5688E2> /Applications/Adobe Photoshop CS4/*/FastCore.plugin/Contents/MacOS/FastCore
                  0x1d52d000 - 0x1d55aff8  GLRendererFloat (??? - ???) <046FB12A-6022-3A91-8385-5BDF85BDACE7> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                  0x1d5a2000 - 0x1d5adffb +PPCCore (??? - ???) <ED521EB7-681D-45AA-9AE3-6BF4663E4BD3> /Applications/Adobe Photoshop CS4/*/PPCCore.plugin/Contents/MacOS/PPCCore
                  0x1d5b3000 - 0x1d5beffe +AltiVecCore (??? - ???) <A967AE2A-F2AE-4E12-A7B6-68B981CBD906> /Applications/Adobe Photoshop CS4/*/AltiVecCore.plugin/Contents/MacOS/AltiVecCore
                  0x1d5f9000 - 0x1d5fbfff  libCoreFSCache.dylib (??? - ???) <17698E23-65F8-30AF-9C05-7E6172E52656> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                  0x26a07000 - 0x26a2aff7 +CSI-Launcher.dylib (??? - ???) /Library/Application Support/Adobe/*/CSI-Launcher.dylib
                  0x26a39000 - 0x26a3efe2  libcldcpuengine.dylib (1.50.69 - compatibility 1.0.0) <57256969-D8B2-3B02-9425-25E719AAF478> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
                  0x26a55000 - 0x26a55ff3 +cl_kernels (??? - ???) <1B304F9D-0A91-4ACB-BBAC-F9F0CFE0D6D2> cl_kernels
                  0x26a60000 - 0x26aa7ff7 +MultiProcessor Support (??? - ???) <001A163B-5314-4613-A23A-F35B63065FD0> /Applications/Adobe Photoshop CS4/*/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                  0x275c6000 - 0x27733ffc  GLEngine (??? - ???) <5C52561A-F1B6-33ED-B6A0-7439EA2B0920> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                  0x27767000 - 0x2785effb  libGLProgrammability.dylib (??? - ???) <C45CEE58-603A-371C-B4AB-5346DC13D8F3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                  0x27882000 - 0x27b23ff7  com.apple.ATIRadeonX3000GLDriver (7.18.11 - 7.1.8) <A33C9540-E6D0-39A2-BCA4-D09E7F793124> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLD river
                  0x27b54000 - 0x27eebfef  com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.18.11 - 7.1.8) <B32656E1-E4CA-3176-94F0-C3F50B1D4D32> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD3000GraphicsGLDriver
                  0x28200000 - 0x28265fe3 +MMXCore (??? - ???) <E206C8DC-AEA8-49DF-8FBC-8B447E3A59A1> /Applications/Adobe Photoshop CS4/*/MMXCore.plugin/Contents/MacOS/MMXCore
                  0x28303000 - 0x28455fc7 +com.adobe.coretech.adm (3.10x16 - 3.1) /Applications/Adobe Photoshop CS4/*/AdobeADM.bundle/Contents/MacOS/AdobeADM
                  0x286b6000 - 0x28728fff +com.DivXInc.DivXDecoder (6.4.0 - 6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
                  0x2a700000 - 0x2a95cfdf +com.adobe.PSAutomate (11.0.1 - 11.0.1) /Applications/Adobe Photoshop CS4/*/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
                  0x2abf0000 - 0x2acbefff +AdobeExtendScript (3.7.0 - compatibility 3.7.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                  0x2ad35000 - 0x2add6fd7 +AdobeScCore (3.7.0 - compatibility 3.7.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                  0x2c463000 - 0x2c494fe3 +com.adobe.amt.registration (AMTRegistration 2.0.1.10077 [BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09] - 2 . 0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/registration.framework/Versions/a/registration
                  0x2d0d8000 - 0x2d55afe3 +AdobeLM_libFNP.dylib (??? - ???) <02E9AC76-9CC6-4974-AF05-48E737C2CC20> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/a/AdobeLM_libFNP.dylib
                  0x2dc00000 - 0x2dc5cff2 +AdobeUpdater (??? - ???) <064CFAA4-1CAF-46E3-BEBF-04948641C927> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/a/AdobeUpdater
                  0x2f1f3000 - 0x2f294ff7  unorm8_bgra.dylib (1.50.69 - compatibility 1.0.0) <7A0427BD-4FB5-3F4E-A7F8-F760AD944283> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
                  0x40000000 - 0x400ae030 +AdobeJP2K (??? - ???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                  0x8fe6e000 - 0x8fea0aa7  dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
                  0x90019000 - 0x9001dffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <56256537-6538-3522-BCB6-2C79DA6AC8CD> /usr/lib/system/libcache.dylib
                  0x9001e000 - 0x9012fff7  libJP2.dylib (??? - ???) <143828CE-D429-3C66-A0DC-4F39536568E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
                  0x90155000 - 0x9017effe  com.apple.opencl (1.50.69 - 1.50.69) <44120D48-00A2-3C09-9055-36D309F1E7C9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                  0x9019a000 - 0x901aefff  com.apple.CFOpenDirectory (10.7 - 146) <58050170-D74E-3670-945D-D8501F67835F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                  0x901e2000 - 0x901eaff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <BB0C7B49-600F-3551-A460-B7E36CA4C4A4> /usr/lib/system/libcopyfile.dylib
                  0x901eb000 - 0x9022bff7  com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                  0x9022c000 - 0x9022fff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
                  0x90230000 - 0x9023dfff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                  0x9024a000 - 0x908c5fe5  com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                  0x908d8000 - 0x90914ffa  libGLImage.dylib (??? - ???) <05B36DC4-6B90-33E6-AE6A-10CAA1B70606> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                  0x90915000 - 0x909fdfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <A1B07527-9C74-3107-A972-9795B817D683> /usr/lib/libxml2.2.dylib
                  0x90e57000 - 0x90e95fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0FAB8C29-2A1B-3E25-BA34-BDD832B828DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                  0x91262000 - 0x912f9ff3  com.apple.securityfoundation (5.0 - 55107) <DF36D4ED-47F7-3F7F-AB09-32E5BFB7EF05> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                  0x912fa000 - 0x9176fff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                  0x91770000 - 0x9177bffb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <DFF43AC6-7D21-36C6-97C9-F46411D18032> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                  0x9177c000 - 0x9178cfff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
                  0x9178d000 - 0x9178dfff  com.apple.Carbon (153 - 153) <F996332A-390E-3337-A09E-A1E54004B567> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                  0x918d6000 - 0x918d7fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
                  0x918d8000 - 0x91965ff7  com.apple.CoreText (220.11.0 - ???) <720EFEE0-A92A-3519-9C88-D06E4DE14EAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                  0x91968000 - 0x91969ff7  libquarantine.dylib (36.2.0 - compatibility 1.0.0) <3F974196-FBAD-3DBD-8ED0-DC16C2B3526B> /usr/lib/system/libquarantine.dylib
                  0x919ba000 - 0x91ae6ff9  com.apple.CFNetwork (520.3.2 - 520.3.2) <58021CA7-0C91-3395-8278-8BD76E03BDCB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                  0x91ae7000 - 0x91b12fff  com.apple.GSS (2.1 - 2.0) <DA24E4F9-F9D4-3CDB-89E4-6EAA7A9F6005> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                  0x91b46000 - 0x91b89fff  com.apple.MediaKit (12 - 589) <C9B45C52-6AC0-3685-82E7-E65960D82F87> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                  0x91b90000 - 0x91b90fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                  0x91c89000 - 0x929d9feb  com.apple.QuickTimeComponents.component (7.7.1 - 2315) <1826E4DB-15C2-3495-A278-A17ADEDB0A62> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
                  0x929da000 - 0x929e4ff2  com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                  0x929e6000 - 0x92d2affb  com.apple.HIToolbox (1.8 - ???) <9540400F-B432-3116-AEAD-C1FBCFE67E73> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                  0x92d2f000 - 0x92d44fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                  0x92d45000 - 0x92d4aff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <943213F3-CC9B-328E-8A6F-16D85C4274C7> /usr/lib/system/libmacho.dylib
                  0x92d4b000 - 0x92effff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
                  0x92fd8000 - 0x930c8ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
                  0x93135000 - 0x9313cff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
                  0x9313d000 - 0x931fffff  com.apple.CoreServices.OSServices (478.37 - 478.37) <00A48B2A-2D75-3FD0-9805-61BB11710879> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                  0x93208000 - 0x9348dfe3  com.apple.QuickTime (7.7.1 - 2315) <E6249041-B569-3A96-897F-E84B1C057948> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                  0x9348e000 - 0x9348fff4  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
                  0x93492000 - 0x93495ffd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                  0x93496000 - 0x93496ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                  0x9349d000 - 0x9349dffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
                  0x9349e000 - 0x9349efff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                  0x9349f000 - 0x935b3ff3  com.apple.QuickTimeImporters.component (7.7.1 - 2315) <5851AB10-A55E-3D80-94D3-46B90E0879DA> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
                  0x936e4000 - 0x93bc0ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                  0x93bc6000 - 0x93bc7ffd  libCVMSPluginSupport.dylib (??? - ???) <6C364E11-B9B3-351A-B297-DB06FBAAFFD1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                  0x93bc8000 - 0x93bcaff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <52F7B44C-1B43-3B7B-9C9E-6410D8682935> /usr/lib/system/libdyld.dylib
                  0x93c1b000 - 0x93c52fef  com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                  0x93dba000 - 0x93dbbff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <2F4B35B2-706C-3383-AA86-DABA409FAE45> /usr/lib/system/libunc.dylib
                  0x93dee000 - 0x93ecfff7  com.apple.DiscRecording (6.0.3 - 6030.4.1) <BB3FE6A8-B9EB-3CA2-B87E-70F7688527EA> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                  0x93f0d000 - 0x943ecfe7  com.apple.RawCamera.bundle (3.11.0 - 608) <C5855290-62E8-2AA7-63BA-87A2D82ADB3D> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                  0x943ed000 - 0x94436ff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                  0x94442000 - 0x94594fff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <E369AC9E-F548-3DF6-B320-9D09E486070E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                  0x94595000 - 0x945c9ff3  libTrueTypeScaler.dylib (??? - ???) <43479E0A-C47D-3CE3-B328-9CB33D3FC3B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                  0x945ca000 - 0x9463efff  com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                  0x9463f000 - 0x94675ff4  com.apple.LDAPFramework (3.1 - 120.2) <A8601C27-6134-3AD1-A76C-F65D49183D9E> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                  0x94676000 - 0x9469ffff  com.apple.shortcut (2.1 - 2.1) <D56F5E5E-A41F-36D1-ACD5-42EA7910B20F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                  0x946a0000 - 0x946a4fff  com.apple.CommonPanels (1.2.5 - 94) <EA47550D-7DAF-30D9-91DB-1FB594CC8522> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                  0x946b1000 - 0x9470afff  com.apple.HIServices (1.11 - ???) <F8B77735-B168-3E21-9B8F-921115B4C19B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                  0x9470e000 - 0x94773ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                  0x9477c000 - 0x9478dfff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
                  0x9478e000 - 0x947a3ff7  com.apple.ImageCapture (7.0 - 7.0) <E019C6BB-CCE9-3D8C-A131-909CE8853502> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                  0x947cb000 - 0x947d6ffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <B63F5D07-93B3-3F02-BFB7-472B4ED3521F> /usr/lib/libbz2.1.0.dylib
                  0x947d7000 - 0x949aefff  com.apple.CoreFoundation (6.7.1 - 635.19) <3A07EDA3-F460-3971-BFCB-AFE9A11F74F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x949af000 - 0x949c2ffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <AE079D11-3A38-3707-A2DF-6BD2FC24B712> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                  0x949c3000 - 0x94a80ff3  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <1C0646D4-18D6-375E-9C0E-EA066C6A6C3C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
                  0x94a81000 - 0x94a9eff3  com.apple.openscripting (1.3.3 - ???) <8ABD04D6-7B7A-3C39-801E-1630098D5B42> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                  0x94a9f000 - 0x94af0ff9  com.apple.ScalableUserInterface (1.0 - 1) <3C39DF4D-5CAE-373A-BE08-8CD16E514337> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                  0x94b8e000 - 0x94b95fff  com.apple.agl (3.1.4 - AGL-3.1.4) <39BB17D3-4CF5-303C-BE8E-E07924AB2E66> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                  0x94b96000 - 0x94bb9fff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                  0x94bba000 - 0x94bdcffe  com.apple.framework.familycontrols (3.0 - 300) <6B0920A5-3971-30EF-AE4C-5361BB7199EB> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                  0x94df9000 - 0x94e01ff3  liblaunch.dylib (392.35.0 - compatibility 1.0.0) <5FF5F6DE-32EE-3DEC-9DC4-2BC1D5797C82> /usr/lib/system/liblaunch.dylib
                  0x94e0d000 - 0x94e18ffc  com.apple.NetAuth (3.1 - 3.1) <CD89526E-4FF6-3BB3-A94E-832D4504AB1C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                  0x94e19000 - 0x94e19ff0  com.apple.ApplicationServices (41 - 41) <C48EF6B2-ABF9-35BD-A07A-A38EC0008294> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                  0x94e1a000 - 0x9511cfff  com.apple.CoreServices.CarbonCore (960.20 - 960.20) <E6300673-A013-3A91-BB1A-DD793B857E16> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                  0x9511d000 - 0x95146ff1  com.apple.CoreServicesInternal (113.12 - 113.12) <CFF78E35-81F5-36C2-A59F-BF85561AC16D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                  0x95147000 - 0x95216fff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <D4D6EB78-8A6C-3474-921C-622C6951489B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                  0x95230000 - 0x95240fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                  0x95d81000 - 0x95de2ffb  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <E617857C-D870-3E2D-BA13-3732DD1BC15E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                  0x95eb7000 - 0x95ec5fff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
                  0x95ec6000 - 0x961d0ff3  com.apple.Foundation (6.7.1 - 833.24) <8E2AD829-587C-3146-B483-9D0209B84192> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                  0x9623f000 - 0x96243ff7  com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                  0x96425000 - 0x96430fff  libkxld.dylib (??? - ???) <AD3C0B3E-EBA8-3A85-ADDB-F86613564E2D> /usr/lib/system/libkxld.dylib
                  0x96431000 - 0x96493ffb  com.apple.datadetectorscore (3.0 - 179.4) <32262124-6F75-3999-86DA-590A90BA464C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                  0x965f7000 - 0x965fdffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                  0x965fe000 - 0x96604ffd  com.apple.CommerceCore (1.0 - 17) <E59CD307-58E2-35FD-9131-B38978799910> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                  0x96646000 - 0x9664fff3  com.apple.CommonAuth (2.1 - 2.0) <5DA75D12-A4D6-3362-AD72-79A64C79669E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                  0x96ceb000 - 0x96d0dff1  com.apple.PerformanceAnalysis (1.10 - 10) <FEB4AEF4-F8C0-3A20-A004-B236B2F0B02B> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                  0x96d0e000 - 0x96d0efff  com.apple.Cocoa (6.6 - ???) <5FAFE73E-6AF5-3D09-9191-0BDC8C6875CB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                  0x96d0f000 - 0x96d2dff7  libsystem_kernel.dylib (1699.24.8 - compatibility 1.0.0) <124A6CE3-3934-3994-9D0A-E85A0C0BF082> /usr/lib/system/libsystem_kernel.dylib
                  0x96d2e000 - 0x96d32fff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                  0x96d3d000 - 0x96ff9ff3  com.apple.security (7.0 - 55110) <2F4FCD65-2A30-3330-99DE-91FE1F78B9FB> /System/Library/Frameworks/Security.framework/Versions/A/Security
                  0x96ffa000 - 0x97069fff  com.apple.Heimdal (2.1 - 2.0) <BCF7C3F1-23BE-315A-BBB6-5F01C79CF626> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                  0x9706a000 - 0x97089fff  com.apple.RemoteViewServices (1.3 - 44) <243F16F3-FFFE-3E81-A969-2EC947A11D89> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                  0x9708a000 - 0x97111fff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                  0x97112000 - 0x97174ff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
                  0x97175000 - 0x9736aff7  com.apple.CoreData (104.1 - 358.13) <EB02DCA7-DB2A-32DD-B49E-ECE54D078610> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                  0x9737d000 - 0x97407ffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                  0x97453000 - 0x97487ff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
                  0x97698000 - 0x976fffff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
                  0x97700000 - 0x97740ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
                  0x97746000 - 0x97b48ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                  0x97b49000 - 0x97b6eff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                  0x97b6f000 - 0x97b71ff9  com.apple.securityhi (4.0 - 1) <39157216-5E43-392A-AE3F-716726D8C8BF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                  0x97b72000 - 0x9849a5eb  com.apple.CoreGraphics (1.600.0 - ???) <E285B0B6-F9FC-33BC-988F-ED619B32029C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                  0x9849b000 - 0x98f2eff6  com.apple.AppKit (6.7.3 - 1138.32) <008E7C05-C20C-344A-B51C-4A2441372785> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x98fac000 - 0x99009ffb  com.apple.htmlrendering (76 - 1.1.4) <409EF0CB-2997-369A-9326-BE12436B9EE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                  0x9900a000 - 0x99024fff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                  0x99025000 - 0x99108ff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
                  0x99353000 - 0x99386fef  libtidy.A.dylib (??? - ???) <E962D8EC-6B9D-35B7-B586-F07D92302ADD> /usr/lib/libtidy.A.dylib
                  0x99387000 - 0x9938bffd  IOSurface (??? - ???) <CAF0B3F2-1589-3139-8A59-E54797C02EA0> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                  0x99443000 - 0x99446ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
                  0x99447000 - 0x99447fff  libdnsinfo.dylib (395.7.0 - compatibility 1.0.0) <A870EB56-560C-3DA2-B189-6E0FD2D3B66D> /usr/lib/system/libdnsinfo.dylib
                  0x99484000 - 0x99583ffb  com.apple.DiskImagesFramework (10.7.3 - 331.3) <92112BAD-4A81-32C0-BB4F-3A92DBFF829F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                  0x99892000 - 0x99899ffd  com.apple.NetFS (4.0 - 4.0) <AE731CFE-1B2E-3E46-8759-843F5FB8C24F> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                  0x9989a000 - 0x9992fff7  com.apple.LaunchServices (480.27.1 - 480.27.1) <8BFE799A-7E35-3834-9403-20E5ADE015D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                  0x99930000 - 0x99a4efec  com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                  0x99a4f000 - 0x99a57fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                  0x99a58000 - 0x99a9bffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <6B35F203-5D72-335A-A4BC-CC89FEC0E14F> /usr/lib/system/libcommonCrypto.dylib
                  0x99aed000 - 0x99b03ffe  libxpc.dylib (77.18.0 - compatibility 1.0.0) <D40B8FD1-C671-3BD5-8C9E-054AF6D4FE9A> /usr/lib/system/libxpc.dylib
                  0x99b04000 - 0x99b07ff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <E06426D8-CC01-3754-B5B3-D15CBA5C8D73> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                  0x99b08000 - 0x99b25fff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
                  0x99b26000 - 0x99b2eff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
                  0x99b2f000 - 0x99b3dfff  com.apple.opengl (1.7.6 - 1.7.6) <5EF9685C-F8B2-3B22-B291-8012761E9AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                  0x99b49000 - 0x99b71ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <5158C760-D168-3842-AAE0-3B146B3537A7> /usr/lib/libxslt.1.dylib
                  0x99b72000 - 0x99c6aff7  libFontParser.dylib (??? - ???) <8C069D3D-534F-3EBC-8035-A43E2B3A431A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                  0x99f21000 - 0x99f3dff5  com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                  0x99f3e000 - 0x99f3efff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                  0x99f57000 - 0x99f85fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
                  0x99f86000 - 0x9a013fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                  0x9a014000 - 0x9a01fff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <DD0529E3-9D71-37B6-9EB8-D7747B2B12C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                  0x9a020000 - 0x9a070ff0  libTIFF.dylib (??? - ???) <F532A16A-7761-355C-8B7B-CEF988D8EEFF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                  0x9a0de000 - 0x9a154fff  com.apple.Metadata (10.7.0 - 627.28) <71AC8DA5-FA89-3411-A97C-65B6129E97BD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                  0x9a155000 - 0x9a156fff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                  0x9a157000 - 0x9a158fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
                  0x9a159000 - 0x9a1f4ff3  com.apple.ink.framework (1.3.2 - 110) <F0E9C225-0D20-31D2-AB14-2299CFAE6C2E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                  0x9a2d7000 - 0x9a2e7ff7  libCRFSuite.dylib (??? - ???) <94E040D2-2769-359A-A21B-DB85FCB73BDC> /usr/lib/libCRFSuite.dylib
                  0x9a2e9000 - 0x9a317ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                  0x9a318000 - 0x9a3eeaab  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
                  0x9a3ef000 - 0x9a453fff  com.apple.framework.IOKit (2.0 - ???) <8DAF4991-7359-3D1B-AC69-3CBA797D1E3C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                  0x9afa6000 - 0x9afe7ff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <CAE102A7-EA5E-391C-A91F-A08071A68652> /usr/lib/libcurl.4.dylib
                  0x9b110000 - 0x9b119fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
                  0x9b11a000 - 0x9b11eff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
                  0x9b11f000 - 0x9b126ff8  libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <8CBED8FC-BF9A-316D-8B47-32336263BE68> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
                  0x9b166000 - 0x9b19cff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                  0x9b19d000 - 0x9b1daff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <4508AABD-EDA8-3BF7-B03A-978D2395C9A8> /usr/lib/libcups.2.dylib
                  0x9b27e000 - 0x9b283ffd  libGFXShared.dylib (??? - ???) <179E77CE-C72C-3B5F-8F1E-3901517C24BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                  0x9b285000 - 0x9b395fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
                  0x9b396000 - 0x9b399ff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
                  0x9b39a000 - 0x9b43efff  com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                  0x9b54b000 - 0x9b54dffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                  0x9b54e000 - 0x9b65dfff  com.apple.DesktopServices (1.6.2 - 1.6.2) <33DCFB71-1D9E-30B6-BC4C-CD54068690BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                  0x9b65e000 - 0x9b66bfff  com.apple.HelpData (2.1.2 - 72) <37D51522-EDED-38BC-9412-3224ED91A078> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                  0x9b66c000 - 0x9b6b4ff7  com.apple.SystemConfiguration (1.11.2 - 1.11) <CA077C0D-8A54-38DB-9690-5D222899B93D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                  0x9b967000 - 0x9b9e2ffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <7A8B0538-8E2E-3355-81E3-0C0A7EBED28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                  0x9c12a000 - 0x9c138ff7  libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
                  0x9c19e000 - 0x9c1f9ff3  com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                  0x9c1fa000 - 0x9c24bfff  libFontRegistry.dylib (??? - ???) <DF69E8EC-9114-3757-8355-8F3E82156F85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                  0x9c30b000 - 0x9c3d6fff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
                  0x9c438000 - 0x9c439ff7  libsystem_sandbox.dylib (??? - ???) <D272A77F-7F47-32CD-A36E-5A3FB966ED55> /usr/lib/system/libsystem_sandbox.dylib
                  0x9c458000 - 0x9c466fff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
                  0x9c467000 - 0x9c46eff9  libsystem_dnssd.dylib (??? - ???) <2FD48636-7CFA-32FA-A595-F12E4246E355> /usr/lib/system/libsystem_dnssd.dylib
                  0x9c46f000 - 0x9c49eff7  libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
                  0x9c80b000 - 0x9c8cbffb  com.apple.ColorSync (4.7.1 - 4.7.1) <68413C12-2380-3B73-AF74-B9E069DFB89A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                  0x9c8cc000 - 0x9ca2dffb  com.apple.QuartzCore (1.7 - 270.2) <4A6035C8-1237-37E5-9FFF-1EFD735D8B18> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                  0x9ca2e000 - 0x9ca4affc  libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                  0x9ca5e000 - 0x9ca61ffb  com.apple.help (1.3.2 - 42) <B1E6701C-7473-30B2-AB5A-AFC9A4823694> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                  0x9ca62000 - 0x9ccd5ff7  com.apple.CoreImage (7.93 - 1.0.1) <88FEFE5B-83A9-3CD9-BE2E-DB1E0553EBB0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                  0x9cd75000 - 0x9cd75fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                  0x9cd7a000 - 0x9cdf6ff7  libType1Scaler.dylib (??? - ???) <2560F511-3288-3367-A4E2-AD15219B6913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
                  0x9cdf7000 - 0x9cdf8fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
                  0x9ce25000 - 0x9ce81fff  com.apple.coreui (1.2.1 - 165.3) <65526A00-D355-3932-9279-9A7D6BF76D95> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                  0xb0000000 - 0xb0006ff8  com.apple.carbonframeworktemplate (1.3 - 1.3.12) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                  0xba900000 - 0xba91bffd  libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <473499F3-8CB8-3372-98B0-8E3BCC1A3D80> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                  0xbab00000 - 0xbab21ff6  libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <B5E80EAA-78D8-3243-A735-A6ECED09A8AC> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                  External Modification Summary:
                    Calls made by other processes targeting this process:
                  task_for_pid: 3
                  thread_create: 0
                  thread_set_state: 0
                    Calls made by this process:
                  task_for_pid: 0
                  thread_create: 0
                  thread_set_state: 0
                    Calls made by all processes on this machine:
                  task_for_pid: 5341
                  thread_create: 0
                  thread_set_state: 0
                  VM Region Summary:
                  ReadOnly portion of Libraries: Total=254.7M resident=149.3M(59%) swapped_out_or_unallocated=105.3M(41%)
                  Writable regions: Total=486.5M written=22.4M(5%) resident=63.6M(13%) swapped_out=0K(0%) unallocated=422.9M(87%)
                  REGION TYPE                  VIRTUAL
                  ATS (font support)             33.2M
                  ATS (font support) (reserved)     4K    reserved VM address space (unallocated)
                  CG backing stores              33.7M
                  CG raster data                  128K
                  CG shared images               3472K
                  CoreGraphics                      8K
                  CoreImage                         4K
                  CoreServices                   2852K
                  IOKit (reserved)              256.0M    reserved VM address space (unallocated)
                  MALLOC                        124.6M
                  MALLOC guard page                48K
                  Memory tag=240                    4K
                  Memory tag=242                   12K
                  Memory tag=243                    8K
                  Memory tag=249                  192K
                  OpenCL                            8K
                  Stack                          75.2M
                  Stack (reserved)                516K    reserved VM address space (unallocated)
                  VM_ALLOCATE                    16.2M
                  __CI_BITMAP                      80K
                  __DATA                         23.6M
                  __DATA/__OBJC                    72K
                  __IMAGE                         528K
                  __IMPORT                        288K
                  __LINKEDIT                     54.9M
                  __OBJC                         1956K
                  __OBJC/__DATA                   200K
                  __PAGEZERO                        4K
                  __RC_CAMERAS                    240K
                  __TEXT                        199.8M
                  __UNICODE                       544K
                  __dw                             12K
                  mapped file                   270.5M
                  shared memory                   312K
                  shared pmap                    8052K
                  TOTAL                           1.1G
                  TOTAL, minus reserved VM space850.0M
                  Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.2 GHz, 4 GB, SMC 1.69f3
                  Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
                  Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
                  Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                  Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                  AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.100.98.75.19)
                  Bluetooth: Version 4.0.3f12, 2 service, 18 devices, 1 incoming serial ports
                  Network Service: AirPort, AirPort, en1
                  Serial ATA Device: TOSHIBA MK5065GSXF, 500.11 GB
                  Serial ATA Device: MATSHITADVD-R   UJ-8A8
                  USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 3
                  USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 5
                  USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 8
                  USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 4
                  USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
                  USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
                  USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
                  • 6. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
                    Level 7
                    You're crashing DEEP inside Apple OS code.
                    I'd guess a bad OS install, or a serious bug in Apple's OpenCL code for your video card.
                    You could try turning off automatic graphics switching in Apple's preferences (that has confused their code before).
                    If that doesn't do it, then you're looking at an OS reinstall or contacting Apple for help with an OpenCL bug.
                    • 7. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
                      johnrdm Level 1
                      Thank you for your reply.
                      How do I turn of auto graphics switching?
                      John
                      • 8. Re: Photoshop CS4 crashes in Lion - other CS4 items seem to work OK
                        johnrdm Level 1
                        OK, so I am replying to my original post.
                        After many, many, hours with Adobe and Apple tech support...
                        The problem was the Caches.
                        Go here:
                        ~/Library/Caches
                        And dump em in the trash. Restart. Then empty trash.
                        All should now be well with your P/S world.
                        Thanks to Lisa, Michael, and many nameless (but pleasant ) Indian tech people.
                        Yours in a (now working) Photoshop world....
                        John
