1 Reply Latest reply on Apr 5, 2012 10:05 PM by Flex harUI
    Strange behavior in Datagrid...Help!!
    jerry98225 Level 1
      Hi guys, this problem has driven me crazy and I really need you guys help.
      I have a datagrid showing data that is queried from mysql. I am trying to add a new row to my datagrid if the users add new record to the database. In other words, I want datagrid to reflect the uploaded data in the database. The datagrid seems to work ONLY on the first record I added. If I try to add a second record, the new row will be added but it ALSO change the first row to the newly updated record. I know it's a bit hard to understand so I draw a picture here.
          DATAGRID
          id   name     number
          1    test1     111
          2    test2     222
      Lets say I add a new record and the datagrid will be
          id   name     number
          1    test1     111
          2    test2     222
          3    test3     333  //new record, works fine.
      but if I add another record, it will become
          id   name     number
          1    test1     111
          2    test2     222
          4    test4     444  //old record, the values change to the newest record.
          4    test4     444  //new record, but also change the previous record
      If I add another record again, it will become
          id   name     number
          1    test1     111
          2    test2     222
          5    test5     555  //first record, the values change to the newest record.
          5    test5     555  //second record, the values change to the newest record.
          5    test5     555  //newest record, change the previous 2 records
      I have done anything I could think of to debug but still no luck.
      The following are my codes:
        // my php data service
          <s:CallResponder id="addResult" result="addResult_resultHandler(event)" />
           <script>
                      //The handler after the user click ADD button
                       protected function addBtn_clickHandler(event:MouseEvent):void
                                                       var newData:object = new Object();
                                                       newData.test1=formField1.text;
                                                       newData.test2=formField2.text;
                                                       newData.test3=formField3.text;
                                                       newData.test4=formField4.text;
                                                           addResult.token=Service.createJob(newData);
                        //the result handler for data service.
                        protected function addResult_resultHandler(event:ResultEvent):void
                                     //jobData is my dataProvider in my datagrid component
                                     //not sure why addItem() would mess me up so badly...
                                     //newData is an Object created after user click the update
                                     //button
                                     jobDG.jobData.addItem(newData);
              Mxml
              <components:dataGridPanel  id="jobDG"
                                         jobData="{getJobsResult.lastResult}"/>
              My datagrid component
              mxml
                        <s:DataGrid id="dg" editable="true" x="5" y="3" width="734" height="253">
                                  <s:columns>
                                       <s:ArrayList>
                                            <s:GridColumn dataField="test1" headerText="text1">
                                      </s:GridColumn>
                                            <s:GridColumn dataField="test2" headerText="text2">
                                      </s:GridColumn>
                                            <s:GridColumn dataField="test3" headerText="text3">
                                      </s:GridColumn>
                                            <s:GridColumn dataField="test4" headerText="text4">
                                      </s:GridColumn>
                                     </s:ArrayList>
                                  </s:columns>
                                  <s:typicalItem>
                                  <fx:Object text1="aaaaa" text2="bbbbb" text3="ccccc" text4="dddddd">
                               </fx:Object>
                                  </s:typicalItem>
                                   <s:AsyncListView list="{jobData}" />   //My dataProvider
                        </s:DataGrid>
      I am really desperate now. Any helps would be appreciated.
