2 Replies Latest reply on Apr 6, 2012 5:10 AM by Selva_TRM
    Can we create Dropdown list as variable?
    Selva_TRM Level 1
      Hi all
      Can we create Dropdown list with variable texts. I am trying to do this, but locked. my code is
      var myTable = myText.convertToTable();
      var myRowCount = myTable[0].rows.count();
      var e = "";
      for (i = 0; i<=myRowCount-1; i++){
          e = "\""+myTable[0].rows[i].contents+"\", "+e;
      var s = "["+e.toString()+"]";
      alert(s);
      var myDialog = app.dialogs.add({name: "Choose Printer Preset"});
              with (myDialog.dialogColumns.add()){
                  staticTexts.add({staticLabel:"Presets: "});
                      var myList = dropdowns.add({stringList: s, selectedIndex:1});
          var result = myDialog.show();
      So, i have create table with some text, then, give it to the dropdown list parameter, but i got "invalid parameter" error message.
      Any suggestion please.
      Selva
        • 1. Re: Can we create Dropdown list as variable?
          csm_phil Level 4
          Hi Selva,
          I have modified your above JS code, i hope you expected this! Check and revert.
          var myText = app.selection[0];
          var myRowCount = myTable.rows.count();
          var Arr = [];
              //Arr.push(myTable.rows[i].contents+"\r");
               Arr.push("\""+myTable.rows[i].contents+"\", ");
          //alert(Arr);
          var myDialog = app.dialogs.add({name: "Table Text"});
               staticTexts.add({staticLabel:"Row Texts: "});
               var myList = dropdowns.add({stringList:Arr, selectedIndex:0});
          thx
          csm_phil
          • 2. Re: Can we create Dropdown list as variable?
            Selva_TRM Level 1
            wow!!!
            thanks phill
            That is what i want, for this i spent more than four hour in my office time.
            I have used another methodology,  i created dummy printer presets using the list text and then call it to dropdown parameter, it also works!
            but i know its not proper way.
            now you give me the good solution.
            Thanks again
            Selva
