24 Replies Latest reply on Apr 14, 2012 11:26 PM by Darkmoon2010
      • 1. Re: trouble Flash 11
        pwillener Level 8
        Download the full (64-bit) installer from the link in http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#Ins tall_in_a_firewall_proxy_server_environment and save it to disk.  Close all browser windows, then run the downloaded installer.
        • 2. Re: trouble Flash 11
          Darkmoon2010 Level 1
          i followed the directions above and when the installer reached 100% the installer froze and stopped responding, i keep repeating the steps and the same result occurs every time.
          • 3. Re: trouble Flash 11
            pwillener Level 8
            Can you post the contents of the FlashInstall.log files from both C:\Windows\system32\Macromed\Flash and C:\Windows\syswow64\Macromed\Flash ?
            • 4. Re: trouble Flash 11
              Flash64_11_1_102.ocx, FlashInstall, FlashUtil64_11_1_102_ActiveX.dll, FlashUtil64_11_1_102_ActiveX, FlashUtil64_11_1_102_Plugin, NPSWF64_11_1_102.dll
              FlashPlayerTrust, Flash11e.ocx, Flash11f.ocx, FlashInstall, flashplayer.xpt, FlashUtil11e_ActiveX, FlashUtil11e_Plugin, FlashUtil11f_ActiveX.dll, FlashUtil11f_ActiveX, install, NPSWF32.dll
              • 5. Re: trouble Flash 11
                Carl E. Myers Jr. Level 4
                Download the current 64 bit uninstaller
                Close all browser windows and run the uninstaller
                Restart Windows
                Delete all remaining files and folders located in the following directories. (tip: copy and paste these paths into the path bar in a Windows Explorer window)
                • C:\Windows\system32\Macromed\Flash
                • C:\Windows\SysWOW64\Macromed\Flash
                • %appdata%\Macromedia\Flash Player
                • %appdata%\Adobe\Flash Player
                Verify that the file “FlashPlayerCPLApp.cpl” in C:\Windows\SysWOW64\ has been deleted.
                Download the following installer file: 64 bit Flash Player for ActiveX (Internet Explorer)
                Physically disconnect from the Internet and run the installer.
                • 6. Re: trouble Flash 11
                  i followed the directions above and it still will not install
                  • 7. Re: trouble Flash 11
                    Exactly what happens when you double click install_flash_player_ax_64bit.exe?
                    What files are in C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash?
                    • 8. Re: trouble Flash 11
                      SysWoW64/Macromed/Flash - Flash.ocx , I am the adminstrator and only user on this computer and It will not let me delete this ActiveX control
                      System32/Macromed/Flash - Empty
                      I open the installer, click the checkbox, then click install, the installing... screen appears the blue bar goes 100%, the installer stops working after this point and when I click on it ,it says (not responding) .
                      • 9. Re: trouble Flash 11
                        Are you sure the file simply says Flash.ocx?
                        Have you tried the program Unlocker on Flash.ocx?
                        Have you virus scanned Flash.ocx?
                        What is the exact message you get when you try to delete Flash.ocx?
                        Have you tried booting in the safe mode and deleting Flash.ocx?
                        • 10. Re: trouble Flash 11
                          pwillener Level 8
                          Apart from deleting that Flash.ocx file, you should also delete the folders, as you may have a permission problem:
                          • C:\Windows\syswow64\Macromed\Flash
                          • 11. Re: trouble Flash 11
                            tried deleting it in safe mode and it would not delete, deleted the folders except sysWoW64/Macromed it agains says i need administrator permissions, the folder Flash with the Flash.ocx still remains. I scanned it with the Total Defense Security Suite and it showed no viruses. the exact message i get is :
                            Folder Access Denied
                            You need permission to perform this action
                            You require permission from an Administrators to make changes to this file
                            • 12. Re: trouble Flash 11
                              chris.campbell Adobe Employee
                              Hi Darkmoon2010,
                              Could you try running through this FAQ to see if it fixes your permission problem with that folder?
                              How do I fix Windows permission problems with Flash Player?
                              Chris
                              • 13. Re: trouble Flash 11
                                I followed the instructions above and the installer gets stuck on retrieving install i left it running for a day and it is still at 0%
                                • 14. Re: trouble Flash 11
                                  pwillener Level 8
                                  Did you download the installer from the link that Carl provided in his earlier reply?  Apparently not, that installer would not retrieve anything during the install.
                                  • 15. Re: trouble Flash 11
                                    UnFlash Level 1
                                    Did all those steps (I even gave everyone full 0_0) still no luck. Removed and updated java and reader without issue.
                                    === Verbose logging started: 4/12/2012  05:25:33  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
                                    MSI (c) (F4:A0) [05:25:33:647]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
                                    MSI (c) (F4:64) [05:25:33:678]: Resetting cached policy values
                                    MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'Debug' is 0
                                    MSI (c) (F4:64) [05:25:33:678]: ******* RunEngine:
                                               ******* Product: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                               ******* Action:
                                               ******* CommandLine: **********
                                    MSI (c) (F4:64) [05:25:33:678]: Machine policy value 'DisableUserInstalls' is 0
                                    MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
                                    MSI (c) (F4:64) [05:25:33:678]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
                                    MSI (c) (F4:64) [05:25:33:991]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
                                    MSI (c) (F4:64) [05:25:34:053]: Cloaking enabled.
                                    MSI (c) (F4:64) [05:25:34:053]: Attempting to enable all disabled privileges before calling Install on Server
                                    MSI (c) (F4:64) [05:25:34:069]: End dialog not enabled
                                    MSI (c) (F4:64) [05:25:34:069]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                    MSI (c) (F4:64) [05:25:34:069]: Package we're running from ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: Compatibility mode property overrides found.
                                    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                    MSI (c) (F4:64) [05:25:34:069]: APPCOMPAT: no matching ProductCode found in database.
                                    MSI (c) (F4:64) [05:25:34:069]: MSCOREE not loaded loading copy from system32
                                    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'TransformsSecure' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: User policy value 'TransformsAtSource' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2205 2:  3: MsiFileHash
                                    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisablePatch' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AllowLockdownPatch' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableLUAPatching' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableFlyWeightPatching' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
                                    MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                    MSI (c) (F4:64) [05:25:34:084]: APPCOMPAT: no matching ProductCode found in database.
                                    MSI (c) (F4:64) [05:25:34:084]: Transforms are not secure.
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
                                    MSI (c) (F4:64) [05:25:34:084]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop CLIENTUILEVEL=0 CLIENTPROCESSID=4596
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
                                    MSI (c) (F4:64) [05:25:34:084]: Product Code passed to Engine.Initialize:           ''
                                    MSI (c) (F4:64) [05:25:34:084]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                    MSI (c) (F4:64) [05:25:34:084]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                    MSI (c) (F4:64) [05:25:34:084]: Product not registered: beginning first-time install
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
                                    MSI (c) (F4:64) [05:25:34:084]: Entering CMsiConfigurationManager::SetLastUsedSource.
                                    MSI (c) (F4:64) [05:25:34:084]: User policy value 'SearchOrder' is 'nmu'
                                    MSI (c) (F4:64) [05:25:34:084]: Adding new sources is allowed.
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
                                    MSI (c) (F4:64) [05:25:34:084]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
                                    MSI (c) (F4:64) [05:25:34:084]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
                                    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2262 2: AdminProperties 3: -2147287038
                                    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'DisableMsi' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: Machine policy value 'AlwaysInstallElevated' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: User policy value 'AlwaysInstallElevated' is 0
                                    MSI (c) (F4:64) [05:25:34:084]: Product installation will be elevated because user is admin and product is being installed per-machine.
                                    MSI (c) (F4:64) [05:25:34:084]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
                                    MSI (c) (F4:64) [05:25:34:084]: TRANSFORMS property is now:
                                    MSI (c) (F4:64) [05:25:34:084]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
                                    MSI (c) (F4:64) [05:25:34:084]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
                                    MSI (c) (F4:64) [05:25:34:084]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
                                    MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
                                    MSI (c) (F4:64) [05:25:34:100]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
                                    MSI (c) (F4:64) [05:25:34:100]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
                                    MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'MsiDisableEmbeddedUI' is 0
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
                                    MSI (c) (F4:A0) [05:25:34:100]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
                                    === Logging started: 4/12/2012  05:25:34 ===
                                    MSI (c) (F4:64) [05:25:34:100]: Note: 1: 2205 2:  3: PatchPackage
                                    MSI (c) (F4:64) [05:25:34:100]: Machine policy value 'DisableRollback' is 0
                                    MSI (c) (F4:64) [05:25:34:100]: User policy value 'DisableRollback' is 0
                                    MSI (c) (F4:64) [05:25:34:100]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
                                    MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
                                    MSI (c) (F4:64) [05:25:34:116]: Doing action: INSTALL
                                    Action 05:25:34: INSTALL.
                                    Action start 05:25:34: INSTALL.
                                    MSI (c) (F4:64) [05:25:34:116]: UI Sequence table 'InstallUISequence' is present and populated.
                                    MSI (c) (F4:64) [05:25:34:116]: Running UISequence
                                    MSI (c) (F4:64) [05:25:34:116]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
                                    MSI (c) (F4:64) [05:25:34:116]: Doing action: ISSetAllUsers
                                    Action 05:25:34: ISSetAllUsers.
                                    Action start 05:25:34: ISSetAllUsers.
                                    MSI (c) (F4:64) [05:25:34:147]: Creating MSIHANDLE (1) of type 790542 for thread 1380
                                    MSI (c) (F4:78) [05:25:34:147]: Invoking remote custom action. DLL: C:\Users\Ad~1\AppData\Local\Temp\MSIEDE8.tmp, Entrypoint: SetAllUsers
                                    MSI (c) (F4:DC) [05:25:34:147]: Cloaking enabled.
                                    MSI (c) (F4:DC) [05:25:34:147]: Attempting to enable all disabled privileges before calling Install on Server
                                    MSI (c) (F4:DC) [05:25:34:147]: Connected to service for CA interface.
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (2) of type 790531 for thread 2532
                                    InstallShield 05:25:34: Begin SetAllUsers()
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (2) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (3) of type 790541 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (4) of type 790531 for thread 2532
                                    InstallShield 05:25:34: Getting records from Upgrade table
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (4) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (5) of type 790540 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (6) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (7) of type 790531 for thread 2532
                                    InstallShield 05:25:34: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (7) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (8) of type 790531 for thread 2532
                                    InstallShield 05:25:34: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (8) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (6) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (9) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (10) of type 790531 for thread 2532
                                    InstallShield 05:25:34: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (10) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (11) of type 790531 for thread 2532
                                    InstallShield 05:25:34: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (11) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (9) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (12) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (13) of type 790531 for thread 2532
                                    InstallShield 05:25:34: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (13) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (14) of type 790531 for thread 2532
                                    InstallShield 05:25:34: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (14) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (12) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Creating MSIHANDLE (15) of type 790531 for thread 2532
                                    InstallShield 05:25:34: End SetAllUsers()
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (15) of type 790531 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (5) of type 790540 for thread 2532
                                    MSI (c) (F4!E4) [05:25:34:256]: Closing MSIHANDLE (3) of type 790541 for thread 2532
                                    MSI (c) (F4:78) [05:25:34:256]: Closing MSIHANDLE (1) of type 790542 for thread 1380
                                    Action ended 05:25:34: ISSetAllUsers. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:256]: Doing action: AppSearch
                                    Action 05:25:34: AppSearch. Searching for installed applications
                                    Action start 05:25:34: AppSearch.
                                    MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2205 2:  3: AppSearch
                                    MSI (c) (F4:64) [05:25:34:256]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
                                    Action ended 05:25:34: AppSearch. Return value 0.
                                    MSI (c) (F4:64) [05:25:34:256]: Doing action: LaunchConditions
                                    Action 05:25:34: LaunchConditions. Evaluating launch conditions
                                    Action start 05:25:34: LaunchConditions.
                                    Action ended 05:25:34: LaunchConditions. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:272]: Doing action: SetupInitialization
                                    Action 05:25:34: SetupInitialization.
                                    Action start 05:25:34: SetupInitialization.
                                    Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                    Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                    Action 05:25:34: SetupInitialization. Dialog created
                                    Action ended 05:25:34: SetupInitialization. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:288]: Doing action: FindRelatedProducts
                                    Action 05:25:34: FindRelatedProducts. Searching for related applications
                                    Action start 05:25:34: FindRelatedProducts.
                                    Action ended 05:25:34: FindRelatedProducts. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:288]: Skipping action: CCPSearch (condition is false)
                                    MSI (c) (F4:64) [05:25:34:288]: Skipping action: RMCCPSearch (condition is false)
                                    MSI (c) (F4:64) [05:25:34:288]: Doing action: ValidateProductID
                                    Action 05:25:34: ValidateProductID.
                                    Action start 05:25:34: ValidateProductID.
                                    Action ended 05:25:34: ValidateProductID. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: CostInitialize
                                    Action 05:25:34: CostInitialize. Computing space requirements
                                    Action start 05:25:34: CostInitialize.
                                    MSI (c) (F4:64) [05:25:34:303]: Machine policy value 'MaxPatchCacheSize' is 10
                                    MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
                                    MSI (c) (F4:64) [05:25:34:303]: Baseline: New baseline 11.2.202 from transaction.
                                    MSI (c) (F4:64) [05:25:34:303]: Baseline: Sorted order Native: Order 0.
                                    MSI (c) (F4:64) [05:25:34:303]: Baseline Data Table:
                                    MSI (c) (F4:64) [05:25:34:303]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
                                    MSI (c) (F4:64) [05:25:34:303]: Baseline File Table:
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
                                    Action ended 05:25:34: CostInitialize. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: FileCost
                                    Action 05:25:34: FileCost. Computing space requirements
                                    Action start 05:25:34: FileCost.
                                    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: MsiAssembly
                                    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Class
                                    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Extension
                                    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: TypeLib
                                    Action ended 05:25:34: FileCost. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: IsolateComponents
                                    Action 05:25:34: IsolateComponents.
                                    Action start 05:25:34: IsolateComponents.
                                    Action ended 05:25:34: IsolateComponents. Return value 0.
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: setUserProfileNT
                                    Action 05:25:34: setUserProfileNT.
                                    Action start 05:25:34: setUserProfileNT.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
                                    Action ended 05:25:34: setUserProfileNT. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:303]: Skipping action: SetAllUsersProfileNT (condition is false)
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: setAllUsersProfile2K
                                    Action 05:25:34: setAllUsersProfile2K.
                                    Action start 05:25:34: setAllUsersProfile2K.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
                                    Action ended 05:25:34: setAllUsersProfile2K. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: ResolveSource
                                    Action 05:25:34: ResolveSource.
                                    Action start 05:25:34: ResolveSource.
                                    MSI (c) (F4:64) [05:25:34:303]: Resolving source.
                                    MSI (c) (F4:64) [05:25:34:303]: Resolving source to launched-from source.
                                    MSI (c) (F4:64) [05:25:34:303]: Setting launched-from source as last-used.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                    MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR ==> C:\Users\Admin\Desktop\
                                    MSI (c) (F4:64) [05:25:34:303]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
                                    MSI (c) (F4:64) [05:25:34:303]: Determining source type
                                    MSI (c) (F4:64) [05:25:34:303]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
                                    MSI (c) (F4:64) [05:25:34:303]: Source path resolution complete. Dumping Directory table...
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
                                    Action ended 05:25:34: ResolveSource. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: CostFinalize
                                    Action 05:25:34: CostFinalize. Computing space requirements
                                    Action start 05:25:34: CostFinalize.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
                                    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2262 2: Patch 3: -2147287038
                                    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2205 2:  3: Condition
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
                                    MSI (c) (F4:64) [05:25:34:303]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
                                    MSI (c) (F4:64) [05:25:34:303]: Target path resolution complete. Dumping Directory table...
                                    MSI (c) (F4:64) [05:25:34:303]: Note: target paths subject to change (via custom actions or browsing)
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TARGETDIR , Object: E:\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                                    MSI (c) (F4:64) [05:25:34:303]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
                                    MSI (c) (F4:64) [05:25:34:303]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
                                    Action ended 05:25:34: CostFinalize. Return value 1.
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: MigrateFeatureStates
                                    Action 05:25:34: MigrateFeatureStates. Migrating feature states from related applications
                                    Action start 05:25:34: MigrateFeatureStates.
                                    Action ended 05:25:34: MigrateFeatureStates. Return value 0.
                                    MSI (c) (F4:64) [05:25:34:303]: Skipping action: PatchWelcome (condition is false)
                                    MSI (c) (F4:64) [05:25:34:303]: Doing action: InstallWelcome
                                    Action 05:25:34: InstallWelcome.
                                    Action start 05:25:34: InstallWelcome.
                                    Action 05:25:34: InstallWelcome. Dialog created
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: _RemoveFilePath
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: MsiFileHash
                                    MSI (c) (F4:9C) [05:25:34:319]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: BindImage
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: ProgId
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: PublishComponent
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: SelfReg
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Extension
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Font
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Shortcut
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: Class
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2205 2:  3: TypeLib
                                    MSI (c) (F4:9C) [05:25:34:319]: Note: 1: 2727 2:
                                    Action ended 05:25:36: InstallWelcome. Return value 1.
                                    MSI (c) (F4:64) [05:25:36:022]: Skipping action: SetupResume (condition is false)
                                    MSI (c) (F4:64) [05:25:36:022]: Skipping action: MaintenanceWelcome (condition is false)
                                    MSI (c) (F4:64) [05:25:36:022]: Doing action: SetupProgress
                                    Action 05:25:36: SetupProgress.
                                    Action start 05:25:36: SetupProgress.
                                    Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                    Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                    Action 05:25:36: SetupProgress. Dialog created
                                    Action ended 05:25:36: SetupProgress. Return value 1.
                                    MSI (c) (F4:64) [05:25:36:038]: Doing action: ExecuteAction
                                    Action 05:25:36: ExecuteAction.
                                    Action start 05:25:36: ExecuteAction.
                                    MSI (c) (F4:64) [05:25:36:053]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
                                    MSI (c) (F4:64) [05:25:36:053]: Grabbed execution mutex.
                                    MSI (c) (F4:64) [05:25:36:053]: Incrementing counter to disable shutdown. Counter after increment: 0
                                    MSI (c) (F4:64) [05:25:36:053]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\" USERNAME="Viking" CLIENTPROCESSID="4596" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop"  ADDLOCAL=FlashPlayerAXInstaller
                                    MSI (s) (28:94) [05:25:36:069]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                    MSI (s) (28:94) [05:25:36:069]: Grabbed execution mutex.
                                    MSI (s) (28:78) [05:25:36:069]: Resetting cached policy values
                                    MSI (s) (28:78) [05:25:36:069]: Machine policy value 'Debug' is 0
                                    MSI (s) (28:78) [05:25:36:069]: ******* RunEngine:
                                               ******* Action: INSTALL
                                    MSI (s) (28:78) [05:25:36:069]: Machine policy value 'DisableUserInstalls' is 0
                                    MSI (s) (28:78) [05:25:36:069]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
                                    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
                                    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
                                    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
                                    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
                                    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
                                    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
                                    MSI (s) (28:78) [05:25:36:084]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
                                    MSI (s) (28:78) [05:25:36:084]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
                                    MSI (s) (28:78) [05:25:36:084]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
                                    MSI (s) (28:78) [05:25:36:084]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
                                    MSI (s) (28:78) [05:25:36:084]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
                                    MSI (s) (28:78) [05:25:36:084]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
                                    MSI (s) (28:78) [05:25:46:319]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 390.
                                    MSI (s) (28:78) [05:25:46:319]: File will have security applied from OpCode.
                                    MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi' against software restriction policy
                                    MSI (s) (28:78) [05:25:46:366]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi has a digital signature
                                    MSI (s) (28:78) [05:25:46:538]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
                                    MSI (s) (28:78) [05:25:46:538]: End dialog not enabled
                                    MSI (s) (28:78) [05:25:46:538]: Original package ==> C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                    MSI (s) (28:78) [05:25:46:538]: Package we're running from ==> C:\Windows\Installer\1201d91.msi
                                    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: Compatibility mode property overrides found.
                                    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                    MSI (s) (28:78) [05:25:46:538]: APPCOMPAT: no matching ProductCode found in database.
                                    MSI (s) (28:78) [05:25:46:553]: MSCOREE not loaded loading copy from system32
                                    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'TransformsSecure' is 0
                                    MSI (s) (28:78) [05:25:46:553]: User policy value 'TransformsAtSource' is 0
                                    MSI (s) (28:78) [05:25:46:553]: Note: 1: 2205 2:  3: MsiFileHash
                                    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisablePatch' is 0
                                    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'AllowLockdownPatch' is 0
                                    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableLUAPatching' is 0
                                    MSI (s) (28:78) [05:25:46:553]: Machine policy value 'DisableFlyWeightPatching' is 0
                                    MSI (s) (28:78) [05:25:46:553]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
                                    MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                    MSI (s) (28:78) [05:25:46:553]: APPCOMPAT: no matching ProductCode found in database.
                                    MSI (s) (28:78) [05:25:46:553]: Transforms are not secure.
                                    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG'.
                                    MSI (s) (28:78) [05:25:46:553]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\ USERNAME=Viking CLIENTPROCESSID=4596 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
                                    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
                                    MSI (s) (28:78) [05:25:46:553]: Product Code passed to Engine.Initialize:           ''
                                    MSI (s) (28:78) [05:25:46:553]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                    MSI (s) (28:78) [05:25:46:553]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                    MSI (s) (28:78) [05:25:46:553]: Product not registered: beginning first-time install
                                    MSI (s) (28:78) [05:25:46:553]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
                                    MSI (s) (28:78) [05:25:46:553]: MSI_LUA: Credential prompt not required, user is an admin
                                    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
                                    MSI (s) (28:78) [05:25:46:553]: Entering CMsiConfigurationManager::SetLastUsedSource.
                                    MSI (s) (28:78) [05:25:46:553]: User policy value 'SearchOrder' is 'nmu'
                                    MSI (s) (28:78) [05:25:46:553]: Adding new sources is allowed.
                                    MSI (s) (28:78) [05:25:46:553]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
                                    MSI (s) (28:78) [05:25:46:569]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
                                    MSI (s) (28:78) [05:25:46:569]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
                                    MSI (s) (28:78) [05:25:46:569]: Note: 1: 2262 2: AdminProperties 3: -2147287038
                                    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableMsi' is 0
                                    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'AlwaysInstallElevated' is 0
                                    MSI (s) (28:78) [05:25:46:569]: User policy value 'AlwaysInstallElevated' is 0
                                    MSI (s) (28:78) [05:25:46:569]: Product installation will be elevated because user is admin and product is being installed per-machine.
                                    MSI (s) (28:78) [05:25:46:569]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Viking'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '4596'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
                                    MSI (s) (28:78) [05:25:46:569]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'ffdbe6677a09a542b5e6559f7939deaf'.
                                    MSI (s) (28:78) [05:25:46:569]: RESTART MANAGER: Session opened.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
                                    MSI (s) (28:78) [05:25:46:569]: Engine has iefSecondSequence set to true.
                                    MSI (s) (28:78) [05:25:46:569]: TRANSFORMS property is now:
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\'.
                                    MSI (s) (28:78) [05:25:46:569]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
                                    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
                                    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
                                    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
                                    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
                                    MSI (s) (28:78) [05:25:46:569]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
                                    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
                                    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
                                    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
                                    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData
                                    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
                                    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
                                    MSI (s) (28:78) [05:25:46:584]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                                    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                                    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                    MSI (s) (28:78) [05:25:46:600]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                                    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
                                    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
                                    MSI (s) (28:78) [05:25:46:616]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
                                    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
                                    MSI (s) (28:78) [05:25:46:616]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
                                    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
                                    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
                                    MSI (s) (28:78) [05:25:46:616]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
                                    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1201d91.msi'.
                                    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi'.
                                    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MsiDisableEmbeddedUI' is 0
                                    MSI (s) (28:78) [05:25:46:616]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
                                    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: PatchPackage
                                    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'DisableRollback' is 0
                                    MSI (s) (28:78) [05:25:46:616]: User policy value 'DisableRollback' is 0
                                    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
                                    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
                                    MSI (s) (28:78) [05:25:46:616]: Doing action: INSTALL
                                    Action 05:25:46: INSTALL.
                                    Action start 05:25:46: INSTALL.
                                    MSI (s) (28:78) [05:25:46:616]: Running ExecuteSequence
                                    MSI (s) (28:78) [05:25:46:616]: Doing action: ISSetAllUsers
                                    Action 05:25:46: ISSetAllUsers.
                                    Action start 05:25:46: ISSetAllUsers.
                                    MSI (s) (28:78) [05:25:46:616]: Skipping action due to msidbCustomActionTypeFirstSequence option.
                                    Action ended 05:25:46: ISSetAllUsers. Return value 0.
                                    MSI (s) (28:78) [05:25:46:616]: Doing action: AppSearch
                                    Action 05:25:46: AppSearch. Searching for installed applications
                                    Action start 05:25:46: AppSearch.
                                    MSI (s) (28:78) [05:25:46:616]: Skipping AppSearch action: already done on client side
                                    Action ended 05:25:46: AppSearch. Return value 0.
                                    MSI (s) (28:78) [05:25:46:616]: Doing action: LaunchConditions
                                    Action 05:25:46: LaunchConditions. Evaluating launch conditions
                                    Action start 05:25:46: LaunchConditions.
                                    Action ended 05:25:46: LaunchConditions. Return value 1.
                                    MSI (s) (28:78) [05:25:46:616]: Doing action: FindRelatedProducts
                                    Action 05:25:46: FindRelatedProducts. Searching for related applications
                                    Action start 05:25:46: FindRelatedProducts.
                                    MSI (s) (28:78) [05:25:46:616]: Skipping FindRelatedProducts action: already done on client side
                                    Action ended 05:25:46: FindRelatedProducts. Return value 0.
                                    MSI (s) (28:78) [05:25:46:616]: Skipping action: CCPSearch (condition is false)
                                    MSI (s) (28:78) [05:25:46:616]: Skipping action: RMCCPSearch (condition is false)
                                    MSI (s) (28:78) [05:25:46:616]: Doing action: ValidateProductID
                                    Action 05:25:46: ValidateProductID.
                                    Action start 05:25:46: ValidateProductID.
                                    Action ended 05:25:46: ValidateProductID. Return value 1.
                                    MSI (s) (28:78) [05:25:46:616]: Doing action: CostInitialize
                                    Action 05:25:46: CostInitialize. Computing space requirements
                                    Action start 05:25:46: CostInitialize.
                                    MSI (s) (28:78) [05:25:46:616]: Machine policy value 'MaxPatchCacheSize' is 10
                                    MSI (s) (28:78) [05:25:46:616]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
                                    MSI (s) (28:78) [05:25:46:616]: Baseline: New baseline 11.2.202 from transaction.
                                    MSI (s) (28:78) [05:25:46:616]: Baseline: Sorted order Native: Order 0.
                                    MSI (s) (28:78) [05:25:46:616]: Baseline Data Table:
                                    MSI (s) (28:78) [05:25:46:616]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
                                    MSI (s) (28:78) [05:25:46:616]: Baseline File Table:
                                    MSI (s) (28:78) [05:25:46:616]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
                                    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2262 2: Patch 3: -2147287038
                                    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
                                    MSI (s) (28:78) [05:25:46:616]: Note: 1: 2205 2:  3: __MsiPatchFileList
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PatchPackage
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
                                    MSI (s) (28:78) [05:25:46:631]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
                                    Action ended 05:25:46: CostInitialize. Return value 1.
                                    MSI (s) (28:78) [05:25:46:631]: Doing action: FileCost
                                    Action 05:25:46: FileCost. Computing space requirements
                                    Action start 05:25:46: FileCost.
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiAssembly
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Class
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Extension
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: TypeLib
                                    Action ended 05:25:46: FileCost. Return value 1.
                                    MSI (s) (28:78) [05:25:46:631]: Doing action: IsolateComponents
                                    Action 05:25:46: IsolateComponents.
                                    Action start 05:25:46: IsolateComponents.
                                    Action ended 05:25:46: IsolateComponents. Return value 0.
                                    MSI (s) (28:78) [05:25:46:631]: Doing action: CostFinalize
                                    Action 05:25:46: CostFinalize. Computing space requirements
                                    Action start 05:25:46: CostFinalize.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Condition
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
                                    MSI (s) (28:78) [05:25:46:631]: Target path resolution complete. Dumping Directory table...
                                    MSI (s) (28:78) [05:25:46:631]: Note: target paths subject to change (via custom actions or browsing)
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TARGETDIR , Object: E:\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: TempFolder , Object: C:\Users\Ad~1\AppData\Local\Temp\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                                    MSI (s) (28:78) [05:25:46:631]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
                                    Action ended 05:25:46: CostFinalize. Return value 1.
                                    MSI (s) (28:78) [05:25:46:631]: Doing action: SetARPINSTALLLOCATION
                                    Action 05:25:46: SetARPINSTALLLOCATION.
                                    Action start 05:25:46: SetARPINSTALLLOCATION.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                    Action ended 05:25:46: SetARPINSTALLLOCATION. Return value 1.
                                    MSI (s) (28:78) [05:25:46:631]: Doing action: SetODBCFolders
                                    Action 05:25:46: SetODBCFolders. Initializing ODBC directories
                                    Action start 05:25:46: SetODBCFolders.
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCDriver
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ODBCTranslator
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
                                    Action ended 05:25:46: SetODBCFolders. Return value 0.
                                    MSI (s) (28:78) [05:25:46:631]: Doing action: MigrateFeatureStates
                                    Action 05:25:46: MigrateFeatureStates. Migrating feature states from related applications
                                    Action start 05:25:46: MigrateFeatureStates.
                                    MSI (s) (28:78) [05:25:46:631]: Skipping MigrateFeatureStates action: already done on client side
                                    Action ended 05:25:46: MigrateFeatureStates. Return value 0.
                                    MSI (s) (28:78) [05:25:46:631]: Doing action: InstallValidate
                                    Action 05:25:46: InstallValidate. Validating install
                                    Action start 05:25:46: InstallValidate.
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'ffdbe6677a09a542b5e6559f7939deaf'.
                                    MSI (s) (28:78) [05:25:46:631]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
                                    MSI (s) (28:78) [05:25:46:631]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                                    MSI (s) (28:78) [05:25:46:631]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
                                    MSI (s) (28:78) [05:25:46:631]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: BindImage
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: ProgId
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: PublishComponent
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: SelfReg
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Font
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: Shortcut
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: _RemoveFilePath
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: MsiFileHash
                                    MSI (s) (28:78) [05:25:46:631]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2727 2:
                                    MSI (s) (28:78) [05:25:46:631]: Note: 1: 2205 2:  3: FilesInUse
                                    MSI (s) (28:78) [05:25:46:647]: Note: 1: 2727 2:
                                    Action ended 05:25:46: InstallValidate. Return value 1.
                                    MSI (s) (28:78) [05:25:46:647]: Doing action: RemoveExistingProducts
                                    Action 05:25:46: RemoveExistingProducts. Removing applications
                                    Action start 05:25:46: RemoveExistingProducts.
                                    Action ended 05:25:46: RemoveExistingProducts. Return value 1.
                                    MSI (s) (28:78) [05:25:46:663]: Doing action: InstallInitialize
                                    Action 05:25:46: InstallInitialize.
                                    Action start 05:25:46: InstallInitialize.
                                    MSI (s) (28:78) [05:25:46:663]: Machine policy value 'AlwaysInstallElevated' is 0
                                    MSI (s) (28:78) [05:25:46:663]: User policy value 'AlwaysInstallElevated' is 0
                                    MSI (s) (28:78) [05:25:46:663]: BeginTransaction: Locking Server
                                    MSI (s) (28:78) [05:25:46:663]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
                                    Action ended 05:25:50: InstallInitialize. Return value 1.
                                    MSI (s) (28:78) [05:25:50:538]: Skipping action: CallExeUninstaller (condition is false)
                                    MSI (s) (28:78) [05:25:50:538]: Doing action: MakePropsAvailable
                                    Action 05:25:50: MakePropsAvailable.
                                    Action start 05:25:50: MakePropsAvailable.
                                    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                    Action ended 05:25:50: MakePropsAvailable. Return value 1.
                                    MSI (s) (28:78) [05:25:50:538]: Doing action: AllocateRegistrySpace
                                    Action 05:25:50: AllocateRegistrySpace. Allocating registry space
                                    Action start 05:25:50: AllocateRegistrySpace.
                                    Action ended 05:25:50: AllocateRegistrySpace. Return value 1.
                                    MSI (s) (28:78) [05:25:50:538]: Doing action: ProcessComponents
                                    Action 05:25:50: ProcessComponents. Updating component registration
                                    Action start 05:25:50: ProcessComponents.
                                    MSI (s) (28:78) [05:25:50:538]: Note: 1: 2205 2:  3: MsiPatchCertificate
                                    MSI (s) (28:78) [05:25:50:538]: LUA patching is disabled: missing MsiPatchCertificate table
                                    MSI (s) (28:78) [05:25:50:538]: Resolving source.
                                    MSI (s) (28:78) [05:25:50:538]: Resolving source to launched-from source.
                                    MSI (s) (28:78) [05:25:50:538]: Setting launched-from source as last-used.
                                    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\'.
                                    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\'.
                                    MSI (s) (28:78) [05:25:50:538]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                    MSI (s) (28:78) [05:25:50:538]: SOURCEDIR ==> C:\Users\Admin\Desktop\
                                    MSI (s) (28:78) [05:25:50:538]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
                                    MSI (s) (28:78) [05:25:50:538]: Determining source type
                                    MSI (s) (28:78) [05:25:50:553]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
                                    MSI (s) (28:78) [05:25:50:553]: Source path resolution complete. Dumping Directory table...
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\ , LongSubPath:  , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\Temp\ , LongSubPath: Temp\ , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\System64\ , LongSubPath: System64\ , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\ , LongSubPath: Common\ , ShortSubPath:
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
                                    MSI (s) (28:78) [05:25:50:553]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
                                    Action 05:25:50: GenerateScript. Generating script operations for action:
                                    GenerateScript: Updating component registration
                                    Action ended 05:25:50: ProcessComponents. Return value 1.
                                    MSI (s) (28:78) [05:25:50:553]: Doing action: UnpublishComponents
                                    Action 05:25:50: UnpublishComponents. Unpublishing Qualified Components
                                    Action start 05:25:50: UnpublishComponents.
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: PublishComponent
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                    Action ended 05:25:50: UnpublishComponents. Return value 0.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: MsiUnpublishAssemblies
                                    Action 05:25:50: MsiUnpublishAssemblies. Unpublishing assembly information
                                    Action start 05:25:50: MsiUnpublishAssemblies.
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: MsiAssembly
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                    Action ended 05:25:50: MsiUnpublishAssemblies. Return value 0.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: UnpublishFeatures
                                    Action 05:25:50: UnpublishFeatures. Unpublishing product features
                                    Action start 05:25:50: UnpublishFeatures.
                                    Action ended 05:25:50: UnpublishFeatures. Return value 1.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: StopServices
                                    Action 05:25:50: StopServices. Stopping services
                                    Action start 05:25:50: StopServices.
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: ServiceControl
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
                                    Action ended 05:25:50: StopServices. Return value 1.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: DeleteServices
                                    Action 05:25:50: DeleteServices. Deleting services
                                    Action start 05:25:50: DeleteServices.
                                    Action ended 05:25:50: DeleteServices. Return value 1.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterComPlus
                                    Action 05:25:50: UnregisterComPlus. Unregistering COM+ Applications and Components
                                    Action start 05:25:50: UnregisterComPlus.
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: Complus
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
                                    Action ended 05:25:50: UnregisterComPlus. Return value 0.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: SelfUnregModules
                                    Action 05:25:50: SelfUnregModules. Unregistering modules
                                    Action start 05:25:50: SelfUnregModules.
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: SelfReg
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
                                    Action ended 05:25:50: SelfUnregModules. Return value 1.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: UnregisterTypeLibraries
                                    Action 05:25:50: UnregisterTypeLibraries. Unregistering type libraries
                                    Action start 05:25:50: UnregisterTypeLibraries.
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2205 2:  3: TypeLib
                                    MSI (s) (28:78) [05:25:50:569]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
                                    Action ended 05:25:50: UnregisterTypeLibraries. Return value 0.
                                    MSI (s) (28:78) [05:25:50:569]: Doing action: RemoveODBC
                                    Action 05:25:50: RemoveODBC. Removing ODBC components
                                    Action start 05:25:50: RemoveODBC.
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDataSource
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCTranslator
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: ODBCDriver
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager
                                    1: Removing ODBC components
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2711 2: ODBCDriverManager64
                                    Action ended 05:25:50: RemoveODBC. Return value 1.
                                    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterFonts
                                    Action 05:25:50: UnregisterFonts. Unregistering fonts
                                    Action start 05:25:50: UnregisterFonts.
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Font
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
                                    Action ended 05:25:50: UnregisterFonts. Return value 1.
                                    MSI (s) (28:78) [05:25:50:584]: Doing action: RemoveRegistryValues
                                    Action 05:25:50: RemoveRegistryValues. Removing system registry values
                                    Action start 05:25:50: RemoveRegistryValues.
                                    Action ended 05:25:50: RemoveRegistryValues. Return value 1.
                                    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterClassInfo
                                    Action 05:25:50: UnregisterClassInfo. Unregister class servers
                                    Action start 05:25:50: UnregisterClassInfo.
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Class
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                    Action ended 05:25:50: UnregisterClassInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterExtensionInfo
                                    Action 05:25:50: UnregisterExtensionInfo. Unregistering extension servers
                                    Action start 05:25:50: UnregisterExtensionInfo.
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2205 2:  3: Extension
                                    MSI (s) (28:78) [05:25:50:584]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                    Action ended 05:25:50: UnregisterExtensionInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:584]: Doing action: UnregisterProgIdInfo
                                    Action 05:25:50: UnregisterProgIdInfo. Unregistering program identifiers
                                    Action start 05:25:50: UnregisterProgIdInfo.
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: ProgId
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                    Action ended 05:25:50: UnregisterProgIdInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: UnregisterMIMEInfo
                                    Action 05:25:50: UnregisterMIMEInfo. Unregistering MIME info
                                    Action start 05:25:50: UnregisterMIMEInfo.
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: MIME
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                    Action ended 05:25:50: UnregisterMIMEInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveIniValues
                                    Action 05:25:50: RemoveIniValues. Removing INI file entries
                                    Action start 05:25:50: RemoveIniValues.
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: IniFile
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
                                    Action ended 05:25:50: RemoveIniValues. Return value 1.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveShortcuts
                                    Action 05:25:50: RemoveShortcuts. Removing shortcuts
                                    Action start 05:25:50: RemoveShortcuts.
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Shortcut
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                    Action ended 05:25:50: RemoveShortcuts. Return value 0.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveEnvironmentStrings
                                    Action 05:25:50: RemoveEnvironmentStrings. Updating environment strings
                                    Action start 05:25:50: RemoveEnvironmentStrings.
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2205 2:  3: Environment
                                    MSI (s) (28:78) [05:25:50:600]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
                                    Action ended 05:25:50: RemoveEnvironmentStrings. Return value 1.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveDuplicateFiles
                                    Action 05:25:50: RemoveDuplicateFiles. Removing duplicated files
                                    Action start 05:25:50: RemoveDuplicateFiles.
                                    Action ended 05:25:50: RemoveDuplicateFiles. Return value 1.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: RemoveFolders
                                    Action 05:25:50: RemoveFolders. Removing folders
                                    Action start 05:25:50: RemoveFolders.
                                    Action ended 05:25:50: RemoveFolders. Return value 1.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: CreateFolders
                                    Action 05:25:50: CreateFolders. Creating folders
                                    Action start 05:25:50: CreateFolders.
                                    CreateFolders: Folder: Creating folders
                                    Action ended 05:25:50: CreateFolders. Return value 1.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: MoveFiles
                                    Action 05:25:50: MoveFiles. Moving files
                                    Action start 05:25:50: MoveFiles.
                                    Action ended 05:25:50: MoveFiles. Return value 1.
                                    MSI (s) (28:78) [05:25:50:600]: Doing action: InstallFiles
                                    Action 05:25:50: InstallFiles. Copying new files
                                    Action start 05:25:50: InstallFiles.
                                    MSI (s) (28:78) [05:25:50:616]: Dumping binary patch manager data...
                                    MSI (s) (28:78) [05:25:50:616]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
                                    InstallFiles: File: Copying new files,  Directory: ,  Size:
                                    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
                                    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
                                    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiSFCBypass
                                    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
                                    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: MsiPatchHeaders
                                    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
                                    MSI (s) (28:78) [05:25:50:616]: Note: 1: 2205 2:  3: PatchPackage
                                    Action ended 05:25:50: InstallFiles. Return value 1.
                                    MSI (s) (28:78) [05:25:50:616]: Doing action: NewCustomAction1
                                    Action 05:25:50: NewCustomAction1.
                                    Action start 05:25:50: NewCustomAction1.
                                    NewCustomAction1:
                                    Action ended 05:25:50: NewCustomAction1. Return value 1.
                                    MSI (s) (28:78) [05:25:50:616]: Doing action: PatchFiles
                                    Action 05:25:50: PatchFiles. Patching files
                                    Action start 05:25:50: PatchFiles.
                                    Action ended 05:25:50: PatchFiles. Return value 1.
                                    MSI (s) (28:78) [05:25:50:616]: Doing action: DuplicateFiles
                                    Action 05:25:50: DuplicateFiles. Creating duplicate files
                                    Action start 05:25:50: DuplicateFiles.
                                    Action ended 05:25:50: DuplicateFiles. Return value 1.
                                    MSI (s) (28:78) [05:25:50:616]: Doing action: BindImage
                                    Action 05:25:50: BindImage. Binding executables
                                    Action start 05:25:50: BindImage.
                                    Action ended 05:25:50: BindImage. Return value 1.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: CreateShortcuts
                                    Action 05:25:50: CreateShortcuts. Creating shortcuts
                                    Action start 05:25:50: CreateShortcuts.
                                    CreateShortcuts: Shortcut: Creating shortcuts
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Shortcut
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
                                    Action ended 05:25:50: CreateShortcuts. Return value 0.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterClassInfo
                                    Action 05:25:50: RegisterClassInfo. Registering class servers
                                    Action start 05:25:50: RegisterClassInfo.
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Class
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                    Action ended 05:25:50: RegisterClassInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterExtensionInfo
                                    Action 05:25:50: RegisterExtensionInfo. Registering extension servers
                                    Action start 05:25:50: RegisterExtensionInfo.
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Extension
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                    Action ended 05:25:50: RegisterExtensionInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterProgIdInfo
                                    Action 05:25:50: RegisterProgIdInfo. Registering program identifiers
                                    Action start 05:25:50: RegisterProgIdInfo.
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: ProgId
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                    Action ended 05:25:50: RegisterProgIdInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: RegisterMIMEInfo
                                    Action 05:25:50: RegisterMIMEInfo. Registering MIME info
                                    Action start 05:25:50: RegisterMIMEInfo.
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: MIME
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                    Action ended 05:25:50: RegisterMIMEInfo. Return value 0.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteRegistryValues
                                    Action 05:25:50: WriteRegistryValues. Writing system registry values
                                    Action start 05:25:50: WriteRegistryValues.
                                    WriteRegistryValues: Key: Writing system registry values, Name: , Value:
                                    Action ended 05:25:50: WriteRegistryValues. Return value 1.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteIniValues
                                    Action 05:25:50: WriteIniValues. Writing INI file values
                                    Action start 05:25:50: WriteIniValues.
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: IniFile
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
                                    Action ended 05:25:50: WriteIniValues. Return value 1.
                                    MSI (s) (28:78) [05:25:50:631]: Doing action: WriteEnvironmentStrings
                                    Action 05:25:50: WriteEnvironmentStrings. Updating environment strings
                                    Action start 05:25:50: WriteEnvironmentStrings.
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2205 2:  3: Environment
                                    MSI (s) (28:78) [05:25:50:631]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
                                    Action ended 05:25:50: WriteEnvironmentStrings. Return value 1.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterFonts
                                    Action 05:25:50: RegisterFonts. Registering fonts
                                    Action start 05:25:50: RegisterFonts.
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Font
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
                                    Action ended 05:25:50: RegisterFonts. Return value 1.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: InstallODBC
                                    Action 05:25:50: InstallODBC. Installing ODBC components
                                    Action start 05:25:50: InstallODBC.
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2711 2: ODBCDriverManager64
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDriver
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`, `Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCTranslator
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileNam e`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ODBCDataSource
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
                                    Action ended 05:25:50: InstallODBC. Return value 0.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterTypeLibraries
                                    Action 05:25:50: RegisterTypeLibraries. Registering type libraries
                                    Action start 05:25:50: RegisterTypeLibraries.
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: TypeLib
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
                                    Action ended 05:25:50: RegisterTypeLibraries. Return value 0.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: SelfRegModules
                                    Action 05:25:50: SelfRegModules. Registering modules
                                    Action start 05:25:50: SelfRegModules.
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: SelfReg
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
                                    Action ended 05:25:50: SelfRegModules. Return value 1.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterComPlus
                                    Action 05:25:50: RegisterComPlus. Registering COM+ Applications and Components
                                    Action start 05:25:50: RegisterComPlus.
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: Complus
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
                                    Action ended 05:25:50: RegisterComPlus. Return value 0.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: InstallServices
                                    Action 05:25:50: InstallServices. Installing new services
                                    Action start 05:25:50: InstallServices.
                                    MSI (s) (28:78) [05:25:50:647]: Detected older ServiceInstall table schema
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceInstall
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrder Group`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Argume nts` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
                                    Action ended 05:25:50: InstallServices. Return value 1.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: StartServices
                                    Action 05:25:50: StartServices. Starting services
                                    Action start 05:25:50: StartServices.
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2205 2:  3: ServiceControl
                                    MSI (s) (28:78) [05:25:50:647]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
                                    Action ended 05:25:50: StartServices. Return value 1.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterUser
                                    Action 05:25:50: RegisterUser. Registering user
                                    Action start 05:25:50: RegisterUser.
                                    RegisterUser: Registering user
                                    Action ended 05:25:50: RegisterUser. Return value 1.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: RegisterProduct
                                    Action 05:25:50: RegisterProduct. Registering product
                                    Action start 05:25:50: RegisterProduct.
                                    RegisterProduct: Registering product
                                    MSI (s) (28:78) [05:25:50:647]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
                                    Action ended 05:25:50: RegisterProduct. Return value 1.
                                    MSI (s) (28:78) [05:25:50:647]: Doing action: PublishComponents
                                    Action 05:25:50: PublishComponents. Publishing qualified components
                                    Action start 05:25:50: PublishComponents.
                                    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: PublishComponent
                                    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
                                    Action ended 05:25:50: PublishComponents. Return value 0.
                                    MSI (s) (28:78) [05:25:50:663]: Doing action: MsiPublishAssemblies
                                    Action 05:25:50: MsiPublishAssemblies. Publishing assembly information
                                    Action start 05:25:50: MsiPublishAssemblies.
                                    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2205 2:  3: MsiAssembly
                                    MSI (s) (28:78) [05:25:50:663]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
                                    Action ended 05:25:50: MsiPublishAssemblies. Return value 0.
                                    MSI (s) (28:78) [05:25:50:663]: Doing action: PublishFeatures
                                    Action 05:25:50: PublishFeatures. Publishing product features
                                    Action start 05:25:50: PublishFeatures.
                                    PublishFeatures: Feature: Publishing product features
                                    Action ended 05:25:50: PublishFeatures. Return value 1.
                                    MSI (s) (28:78) [05:25:50:663]: Doing action: PublishProduct
                                    Action 05:25:50: PublishProduct. Publishing product information
                                    Action start 05:25:50: PublishProduct.
                                    1: Publishing product information
                                    Action ended 05:25:50: PublishProduct. Return value 1.
                                    MSI (s) (28:78) [05:25:50:663]: Skipping action: ScheduleReboot (condition is false)
                                    MSI (s) (28:78) [05:25:50:663]: Doing action: InstallFinalize
                                    Action 05:25:50: InstallFinalize.
                                    Action start 05:25:50: InstallFinalize.
                                    MSI (s) (28:78) [05:25:50:663]: Running Script: C:\Windows\Installer\MSI2E1D.tmp
                                    MSI (s) (28:78) [05:25:50:663]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
                                    MSI (s) (28:78) [05:25:50:663]: Machine policy value 'DisableRollback' is 0
                                    MSI (s) (28:78) [05:25:50:663]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1033,Platform=589824, ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680 650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101- 488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymen tFlags=3)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=0,Argument=1033)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=0,)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: SetBaseline(Baseline=1,)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
                                    Action 5:25:50: ProcessComponents. Updating component registration
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},KeyPath=C:\Windows\s ystem32\Macromed\Flash\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
                                    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},KeyPath=C:\Users\Ad~ 1\AppData\Local\Temp\InstallAX64.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=1)
                                    1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
                                    Action 5:25:50: RemoveODBC. Removing ODBC components
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=0)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ODBCDriverManager(,BinaryType=1)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
                                    Action 5:25:50: CreateFolders. Creating folders
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
                                    CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
                                    Action 5:25:50: InstallFiles. Copying new files
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: SetSourceFolder(Folder=1\Temp\)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\Windows\Instal ler\1201d91.msi,,,,,IsFirstPhysicalMedia=1)
                                    MSI (s) (28:78) [05:25:50:678]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=InstallAX64.exe,DestName=In stallAX64.exe,Attributes=16384,FileSize=8767136,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC= 0,Version=11.2.202.228,Language=1033,InstallMode=58982400,,,,,,,)
                                    MSI (s) (28:78) [05:25:50:678]: File: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
                                    MSI (s) (28:78) [05:25:50:678]: Source for file 'InstallAX64.exe' is compressed
                                    InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Ad~1\AppData\Local\Temp\,  Size: 8767136
                                    MSI (s) (28:78) [05:25:50:772]: Executing op: CacheSizeFlush(,)
                                    MSI (s) (28:78) [05:25:50:772]: Executing op: ActionStart(Name=NewCustomAction1,,)
                                    Action 5:25:50: NewCustomAction1.
                                    MSI (s) (28:78) [05:25:50:772]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C:\Users\Ad~1\AppData \Local\Temp\InstallAX64.exe,Target=-install -msi,)
                                    CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
                                    MSI (s) (28:78) [05:25:53:788]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
                                    Info 2835.The control ErrorIcon was not found on dialog SetupError.
                                    Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
                                    MSI (s) (28:78) [05:25:58:694]: Product: Adobe Flash Player 11 ActiveX (x64) -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe, command: -install -msi
                                    Action ended 05:25:58: InstallFinalize. Return value 3.
                                    MSI (s) (28:78) [05:25:58:694]: User policy value 'DisableRollback' is 0
                                    MSI (s) (28:78) [05:25:58:694]: Machine policy value 'DisableRollback' is 0
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082927930,LangId=1033,Platform=589824, ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=0,Argument=1033)
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
                                    Action 5:25:58: Rollback. Rolling back action:
                                    Rollback: NewCustomAction1
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=NewCustomAction1,,)
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680 650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101- 488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymen tFlags=3)
                                    Rollback: Copying new files
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: SetTargetFolder(Folder=C:\Users\Ad~1\AppData\Local\Temp\)
                                    MSI (s) (28:78) [05:25:58:694]: Executing op: FileRemove(,FileName=C:\Users\Ad~1\AppData\Local\Temp\InstallAX64.exe,,)
                                    Rollback: Creating folders
                                    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
                                    MSI (s) (28:78) [05:25:58:709]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,SecurityDescriptor=Bina ryData,)
                                    Rollback: Removing ODBC components
                                    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
                                    Rollback: Updating component registration
                                    MSI (s) (28:78) [05:25:58:709]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
                                    MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},ProductKey={5C804E BB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
                                    MSI (s) (28:78) [05:25:58:709]: Executing op: ComponentUnregister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},ProductKey={5C804E BB-475F-4555-A225-1D6573F158BD},BinaryType=1,)
                                    MSI (s) (28:78) [05:25:58:709]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=0)
                                    MSI (s) (28:78) [05:25:58:709]: Error in rollback skipped. Return: 5
                                    MSI (s) (28:78) [05:25:58:709]: Note: 1: 2318 2:
                                    MSI (s) (28:78) [05:25:58:709]: Calling SRSetRestorePoint API. dwRestorePtType: 13, dwEventType: 103, llSequenceNumber: 390, szDescription: "".
                                    MSI (s) (28:78) [05:25:58:709]: The call to SRSetRestorePoint API succeeded. Returned status: 0.
                                    MSI (s) (28:78) [05:25:58:709]: Unlocking Server
                                    MSI (s) (28:78) [05:25:59:350]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
                                    Action ended 05:25:59: INSTALL. Return value 3.
                                    Property(S): DiskPrompt = [1]
                                    Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
                                    Property(S): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
                                    Property(S): ProductToBeRegistered = 1
                                    Property(S): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
                                    Property(S): SOURCEDIR = C:\Users\Admin\Desktop\
                                    Property(S): VersionNT = 601
                                    Property(S): TARGETDIR = E:\
                                    Property(S): ALLUSERSPROFILE = C:\ProgramData\
                                    Property(S): PrimaryVolumeSpaceRemaining = 0
                                    Property(S): PrimaryVolumeSpaceRequired = 0
                                    Property(S): PrimaryVolumeSpaceAvailable = 0
                                    Property(S): OutOfNoRbDiskSpace = 0
                                    Property(S): OutOfDiskSpace = 0
                                    Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                                    Property(S): MACROMED = C:\Windows\system32\Macromed\
                                    Property(S): FLASH = C:\Windows\system32\Macromed\Flash\
                                    Property(S): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
                                    Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                                    Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                                    Property(S): System64Folder = C:\Windows\system32\
                                    Property(S): CostingComplete = 1
                                    Property(S): SourceDir = C:\Users\Admin\Desktop\
                                    Property(S): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
                                    Property(S): USERPROFILE = C:\Users\Admin\
                                    Property(S): Preselected = 1
                                    Property(S): UILevel = 5
                                    Property(S): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                    Property(S): DATABASE = C:\Windows\Installer\1201d91.msi
                                    Property(S): Privileged = 1
                                    Property(S): MsiRunningElevated = 1
                                    Property(S): RedirectedDllSupport = 2
                                    Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
                                    Property(S): MsiNetAssemblySupport = 4.0.30319.1
                                    Property(S): Date = 4/12/2012
                                    Property(S): Time = 5:25:59
                                    Property(S): TTCSupport = 1
                                    Property(S): ColorBits = 32
                                    Property(S): TextInternalLeading = 3
                                    Property(S): TextHeight = 16
                                    Property(S): BorderSide = 1
                                    Property(S): BorderTop = 1
                                    Property(S): CaptionHeight = 22
                                    Property(S): ScreenY = 768
                                    Property(S): ISCHECKFORPRODUCTUPDATES = 1
                                    Property(S): ApplicationUsers = AllUsers
                                    Property(S): AgreeToLicense = No
                                    Property(S): _IsMaintenance = Change
                                    Property(S): RestartManagerOption = CloseRestart
                                    Property(S): IS_SQLSERVER_USERNAME = sa
                                    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                                    Property(S): SetupType = Typical
                                    Property(S): _IsSetupTypeMin = Typical
                                    Property(S): Display_IsBitmapDlg = 1
                                    Property(S): ScreenX = 1024
                                    Property(S): ProductName = Adobe Flash Player 11 ActiveX (x64)
                                    Property(S): ALLUSERS = 1
                                    Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
                                    Property(S): ARPNOMODIFY = 1
                                    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                                    Property(S): ARPURLINFOABOUT = http://www.adobe.com
                                    Property(S): SystemLanguageID = 1033
                                    Property(S): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
                                    Property(S): DWUSINTERVAL = 30
                                    Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
                                    Property(S): DefaultUIFont = Tahoma8
                                    Property(S): DialogCaption = InstallShield for Windows Installer
                                    Property(S): DisplayNameCustom = Custom
                                    Property(S): DisplayNameMinimal = Minimal
                                    Property(S): DisplayNameTypical = Typical
                                    Property(S): ErrorDialog = SetupError
                                    Property(S): INSTALLLEVEL = 100
                                    Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
                                    Property(S): ISVROOT_PORT_NO = 0
                                    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                                    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                                    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                                    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                                    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                                    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                                    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                                    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                                    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                                    Property(S): InstallChoice = AR
                                    Property(S): Manufacturer = Adobe Systems Incorporated
                                    Property(S): MsiLogging = voicewarmupx
                                    Property(S): NewProperty2 = 0
                                    Property(S): NewProperty3 = 0
                                    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                                    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                                    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                                    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                                    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                                    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                                    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                                    Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
                                    Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
                                    Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                                    Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                                    Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                                    Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                                    Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                                    Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                                    Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                                    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                                    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                                    Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
                                    Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                                    Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                                    Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                                    Property(S): ProductID = none
                                    Property(S): ProductLanguage = 1033
                                    Property(S): ProductVersion = 11.2.202.228
                                    Property(S): ProgressType0 = install
                                    Property(S): ProgressType1 = Installing
                                    Property(S): ProgressType2 = installed
                                    Property(S): ProgressType3 = installs
                                    Property(S): RebootYesNo = Yes
                                    Property(S): ReinstallModeText = omus
                                    Property(S): SHOWLAUNCHPROGRAM = 0
                                    Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
                                    Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
                                    Property(S): RemoveFilesCA = C:\Windows\system32\Macromed\Flash\
                                    Property(S): ARPINSTALLLOCATION = C:\Windows\system32\Macromed\Flash\
                                    Property(S): ComputerName = NSDQ01
                                    Property(S): UserLanguageID = 1033
                                    Property(S): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
                                    Property(S): LogonUser = Admin
                                    Property(S): AdminUser = 1
                                    Property(S): MsiTrueAdminUser = 1
                                    Property(S): VirtualMemory = 6406
                                    Property(S): PhysicalMemory = 4094
                                    Property(S): Intel = 6
                                    Property(S): Msix64 = 6
                                    Property(S): MsiAMD64 = 6
                                    Property(S): ShellAdvtSupport = 1
                                    Property(S): OLEAdvtSupport = 1
                                    Property(S): GPTSupport = 1
                                    Property(S): FontsFolder = C:\Windows\Fonts\
                                    Property(S): DesktopFolder = C:\Users\Public\Desktop\
                                    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                                    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                                    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                                    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                                    Property(S): MyPicturesFolder = C:\Users\Admin\Pictures\
                                    Property(S): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
                                    Property(S): CommonAppDataFolder = C:\ProgramData\
                                    Property(S): USERNAME = Viking
                                    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                                    Property(S): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
                                    Property(S): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
                                    Property(S): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                                    Property(S): PersonalFolder = C:\Users\Admin\Documents\
                                    Property(S): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                                    Property(S): FavoritesFolder = C:\Users\Admin\Favorites\
                                    Property(S): AppDataFolder = C:\Users\Admin\AppData\Roaming\
                                    Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
                                    Property(S): ProgramFiles64Folder = C:\Program Files\
                                    Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                                    Property(S): RemoteAdminTS = 1
                                    Property(S): SystemFolder = C:\Windows\SysWOW64\
                                    Property(S): WindowsVolume = C:\
                                    Property(S): WindowsFolder = C:\Windows\
                                    Property(S): MsiNTProductType = 1
                                    Property(S): ServicePackLevelMinor = 0
                                    Property(S): ServicePackLevel = 1
                                    Property(S): WindowsBuild = 7601
                                    Property(S): VersionNT64 = 601
                                    Property(S): VersionMsi = 5.00
                                    Property(S): MsiSystemRebootPending = 1
                                    Property(S): ADDLOCAL = FlashPlayerAXInstaller
                                    Property(S): CURRENTDIRECTORY = C:\Users\Admin\Desktop
                                    Property(S): CLIENTUILEVEL = 0
                                    Property(S): CLIENTPROCESSID = 4596
                                    Property(S): VersionDatabase = 200
                                    Property(S): ACTION = INSTALL
                                    Property(S): EXECUTEACTION = INSTALL
                                    Property(S): ROOTDRIVE = E:\
                                    Property(S): SECONDSEQUENCE = 1
                                    Property(S): PackagecodeChanging = 1
                                    Property(S): ProductState = -1
                                    Property(S): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
                                    Property(S): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
                                    MSI (s) (28:78) [05:25:59:366]: MainEngineThread is returning 1603
                                    MSI (s) (28:94) [05:25:59:366]: RESTART MANAGER: Session closed.
                                    MSI (s) (28:94) [05:25:59:366]: User policy value 'DisableRollback' is 0
                                    MSI (s) (28:94) [05:25:59:366]: Machine policy value 'DisableRollback' is 0
                                    MSI (s) (28:94) [05:25:59:366]: Incrementing counter to disable shutdown. Counter after increment: 0
                                    MSI (s) (28:94) [05:25:59:366]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
                                    MSI (s) (28:94) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
                                    MSI (s) (28:94) [05:25:59:381]: Restoring environment variables
                                    MSI (c) (F4:64) [05:25:59:381]: Back from server. Return value: 1603
                                    MSI (c) (F4:64) [05:25:59:381]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
                                    MSI (c) (F4:64) [05:25:59:381]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
                                    Action ended 05:25:59: ExecuteAction. Return value 3.
                                    MSI (c) (F4:64) [05:25:59:381]: Doing action: SetupCompleteError
                                    Action 05:25:59: SetupCompleteError.
                                    Action start 05:25:59: SetupCompleteError.
                                    Action 05:25:59: SetupCompleteError. Dialog created
                                    Action ended 05:26:00: SetupCompleteError. Return value 2.
                                    Action ended 05:26:00: INSTALL. Return value 3.
                                    MSI (c) (F4:64) [05:26:00:694]: Destroying RemoteAPI object.
                                    MSI (c) (F4:DC) [05:26:00:709]: Custom Action Manager thread ending.
                                    Property(C): DiskPrompt = [1]
                                    Property(C): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
                                    Property(C): ProductCode = {5C804EBB-475F-4555-A225-1D6573F158BD}
                                    Property(C): PrimaryVolumeSpaceRemaining = 0
                                    Property(C): PrimaryVolumeSpaceRequired = 0
                                    Property(C): PrimaryVolumeSpaceAvailable = 0
                                    Property(C): OutOfNoRbDiskSpace = 0
                                    Property(C): OutOfDiskSpace = 0
                                    Property(C): VersionNT = 601
                                    Property(C): TARGETDIR = E:\
                                    Property(C): ALLUSERSPROFILE = C:\ProgramData\
                                    Property(C): SourcedirProduct = {5C804EBB-475F-4555-A225-1D6573F158BD}
                                    Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                                    Property(C): MACROMED = C:\Windows\system32\Macromed\
                                    Property(C): FLASH = C:\Windows\system32\Macromed\Flash\
                                    Property(C): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
                                    Property(C): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                                    Property(C): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                                    Property(C): System64Folder = C:\Windows\system32\
                                    Property(C): CostingComplete = 1
                                    Property(C): ROOTDRIVE = E:\
                                    Property(C): SourceDir = C:\Users\Admin\Desktop\
                                    Property(C): TempFolder = C:\Users\Ad~1\AppData\Local\Temp\
                                    Property(C): USERPROFILE = C:\Users\Admin\
                                    Property(C): EXECUTEACTION = INSTALL
                                    Property(C): ACTION = INSTALL
                                    Property(C): UILevel = 5
                                    Property(C): VersionHandler = 5.00
                                    Property(C): SOURCEDIR = C:\Users\Admin\Desktop\
                                    Property(C): OriginalDatabase = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                    Property(C): DATABASE = C:\Users\Admin\Desktop\install_flash_player_11_active_x_64bit.msi
                                    Property(C): Privileged = 1
                                    Property(C): MsiRunningElevated = 1
                                    Property(C): RedirectedDllSupport = 2
                                    Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
                                    Property(C): MsiNetAssemblySupport = 4.0.30319.1
                                    Property(C): Date = 4/12/2012
                                    Property(C): Time = 05:26:00
                                    Property(C): TTCSupport = 1
                                    Property(C): ISCHECKFORPRODUCTUPDATES = 1
                                    Property(C): ApplicationUsers = AllUsers
                                    Property(C): AgreeToLicense = No
                                    Property(C): _IsMaintenance = Change
                                    Property(C): RestartManagerOption = CloseRestart
                                    Property(C): IS_SQLSERVER_USERNAME = sa
                                    Property(C): IS_SQLSERVER_AUTHENTICATION = 0
                                    Property(C): SetupType = Typical
                                    Property(C): _IsSetupTypeMin = Typical
                                    Property(C): Display_IsBitmapDlg = 1
                                    Property(C): ProductName = Adobe Flash Player 11 ActiveX (x64)
                                    Property(C): ALLUSERS = 1
                                    Property(C): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
                                    Property(C): ARPNOMODIFY = 1
                                    Property(C): ARPPRODUCTICON = ARPPRODUCTICON.exe
                                    Property(C): ARPURLINFOABOUT = http://www.adobe.com
                                    Property(C): ColorBits = 32
                                    Property(C): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
                                    Property(C): DWUSINTERVAL = 30
                                    Property(C): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
                                    Property(C): DefaultUIFont = Tahoma8
                                    Property(C): DialogCaption = InstallShield for Windows Installer
                                    Property(C): DisplayNameCustom = Custom
                                    Property(C): DisplayNameMinimal = Minimal
                                    Property(C): DisplayNameTypical = Typical
                                    Property(C): ErrorDialog = SetupError
                                    Property(C): INSTALLLEVEL = 100
                                    Property(C): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
                                    Property(C): ISVROOT_PORT_NO = 0
                                    Property(C): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                                    Property(C): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                                    Property(C): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                                    Property(C): IS_PROGMSG_XML_COSTING = Costing XML files...
                                    Property(C): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                                    Property(C): IS_PROGMSG_XML_FILES = Performing XML file changes...
                                    Property(C): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                                    Property(C): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                                    Property(C): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                                    Property(C): InstallChoice = AR
                                    Property(C): Manufacturer = Adobe Systems Incorporated
                                    Property(C): MsiLogging = voicewarmupx
                                    Property(C): NewProperty2 = 0
                                    Property(C): NewProperty3 = 0
                                    Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                                    Property(C): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                                    Property(C): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                                    Property(C): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                                    Property(C): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                                    Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                                    Property(C): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                                    Property(C): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
                                    Property(C): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
                                    Property(C): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                                    Property(C): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                                    Property(C): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                                    Property(C): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                                    Property(C): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                                    Property(C): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                                    Property(C): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                                    Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                                    Property(C): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                                    Property(C): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
                                    Property(C): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                                    Property(C): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                                    Property(C): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                                    Property(C): ProductID = none
                                    Property(C): ProductLanguage = 1033
                                    Property(C): ProductVersion = 11.2.202.228
                                    Property(C): ProgressType0 = install
                                    Property(C): ProgressType1 = Installing
                                    Property(C): ProgressType2 = installed
                                    Property(C): ProgressType3 = installs
                                    Property(C): RebootYesNo = Yes
                                    Property(C): ReinstallModeText = omus
                                    Property(C): SHOWLAUNCHPROGRAM = 0
                                    Property(C): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
                                    Property(C): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
                                    Property(C): TextInternalLeading = 3
                                    Property(C): TextHeight = 16
                                    Property(C): BorderSide = 1
                                    Property(C): BorderTop = 1
                                    Property(C): AdminUser = 1
                                    Property(C): CaptionHeight = 22
                                    Property(C): ScreenY = 1080
                                    Property(C): ScreenX = 1920
                                    Property(C): SystemLanguageID = 1033
                                    Property(C): ComputerName = NSDQ01
                                    Property(C): UserLanguageID = 1033
                                    Property(C): UserSID = S-1-5-21-2660183097-2710711284-1203379116-500
                                    Property(C): LogonUser = Admin
                                    Property(C): MsiTrueAdminUser = 1
                                    Property(C): VirtualMemory = 6439
                                    Property(C): PhysicalMemory = 4094
                                    Property(C): Intel = 6
                                    Property(C): Msix64 = 6
                                    Property(C): MsiAMD64 = 6
                                    Property(C): ShellAdvtSupport = 1
                                    Property(C): OLEAdvtSupport = 1
                                    Property(C): GPTSupport = 1
                                    Property(C): FontsFolder = C:\Windows\Fonts\
                                    Property(C): DesktopFolder = C:\Users\Public\Desktop\
                                    Property(C): USERNAME = Viking
                                    Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                                    Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                                    Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                                    Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                                    Property(C): MyPicturesFolder = C:\Users\Admin\Pictures\
                                    Property(C): LocalAppDataFolder = C:\Users\Admin\AppData\Local\
                                    Property(C): CommonAppDataFolder = C:\ProgramData\
                                    Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                                    Property(C): SendToFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo\
                                    Property(C): RecentFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent\
                                    Property(C): PrintHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                                    Property(C): PersonalFolder = C:\Users\Admin\Documents\
                                    Property(C): NetHoodFolder = C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                                    Property(C): FavoritesFolder = C:\Users\Admin\Favorites\
                                    Property(C): AppDataFolder = C:\Users\Admin\AppData\Roaming\
                                    Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
                                    Property(C): ProgramFiles64Folder = C:\Program Files\
                                    Property(C): ProgramFilesFolder = C:\Program Files (x86)\
                                    Property(C): RemoteAdminTS = 1
                                    Property(C): SystemFolder = C:\Windows\SysWOW64\
                                    Property(C): WindowsVolume = C:\
                                    Property(C): WindowsFolder = C:\Windows\
                                    Property(C): MsiNTProductType = 1
                                    Property(C): ServicePackLevelMinor = 0
                                    Property(C): ServicePackLevel = 1
                                    Property(C): WindowsBuild = 7601
                                    Property(C): VersionNT64 = 601
                                    Property(C): VersionMsi = 5.00
                                    Property(C): VersionDatabase = 200
                                    Property(C): MsiSystemRebootPending = 1
                                    Property(C): CLIENTPROCESSID = 4596
                                    Property(C): CLIENTUILEVEL = 0
                                    Property(C): CURRENTDIRECTORY = C:\Users\Admin\Desktop
                                    Property(C): PackagecodeChanging = 1
                                    Property(C): ProductState = -1
                                    Property(C): PackageCode = {56994055-C101-488E-A9CB-CF207652B759}
                                    Property(C): MsiLogFileLocation = C:\Users\Ad~1\AppData\Local\Temp\MSIfec02.LOG
                                    === Logging stopped: 4/12/2012  05:26:00 ===
                                    MSI (c) (F4:64) [05:26:00:709]: Note: 1: 1708
                                    MSI (c) (F4:64) [05:26:00:709]: Product: Adobe Flash Player 11 ActiveX (x64) -- Installation operation failed.
                                    MSI (c) (F4:64) [05:26:00:709]: Windows Installer installed the product. Product Name: Adobe Flash Player 11 ActiveX (x64). Product Version: 11.2.202.228. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
                                    MSI (c) (F4:64) [05:26:00:709]: Grabbed execution mutex.
                                    MSI (c) (F4:64) [05:26:00:709]: Cleaning up uninstalled install packages, if any exist
                                    MSI (c) (F4:64) [05:26:00:709]: MainEngineThread is returning 1603
                                    === Verbose logging stopped: 4/12/2012  05:26:00 ===
                                    • 16. Re: trouble Flash 11
                                      chris.campbell Adobe Employee
                                      Are you running the .msi or .exe?  If .msi, can you try the .exe instead?
                                      • 17. Re: trouble Flash 11
                                        UnFlash Level 1
                                        Chris, I did all three: MSI, MSI extracted EXE, and EXE. With a re-check or permissions and a Adobe clean up w/ reboot between. Running as admin. SW, reader, and java all removed and reinstalled without issue.
                                        Thnak you.
                                        • 18. Re: trouble Flash 11
                                          could you post the contents of your flashinstall.log?
                                          Where do I find the Flash Player installation log on Windows?
                                          • 19. Re: trouble Flash 11
                                            UnFlash Level 1
                                            Installed the EXE extracted from the MSI.
                                            32 BIT:
                                            =O====== M/11.2.202.228 2012-04-13+02-38-35.903 ========
                                            0000 [I] 00000010 "C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit\InstallAX64.exe "
                                            0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                                            0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                            0003 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                                            0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                            0005 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                            0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                                            0007 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
                                            0008 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.exe
                                            0009 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.dll
                                            0010 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                            0011 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
                                            0012 [I] 00000018
                                            0013 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
                                            0014 [I] 00000011 1
                                            =X====== M/11.2.202.228 2012-04-13+02-40-02.410 ========
                                            And now 64 BIT:
                                            =O====== M/11.2.202.228 2012-04-13+02-38-44.262 ========
                                            0000 [W] 00001113 C:\Windows\SysWOW64\Macromed\Flash\\* 3
                                            0001 [I] 00000010 "C:\Users\Admin\AppData\Local\Temp\{962A8EE6-178E-4769-95EC-7ADB7C363052}\InstallFlashPla yer.exe" -install -skipARPEntry -iv 1
                                            0002 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
                                            0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                            0004 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                            0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                                            0006 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx
                                            0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe
                                            0008 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.dll
                                            0009 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                            0010 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                                            0011 [W] 00001102
                                            0012 [W] 00001106
                                            0013 [W] 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
                                            0014 [I] 00000018
                                            0015 [E] 00001032 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
                                            =X====== M/11.2.202.228 2012-04-13+02-38-49.458 ========
                                            Thank you.
                                            • 20. Re: trouble Flash 11
                                              pwillener Level 8
                                              There are obviously some permission problems (80070005).
                                              Can you try
                                              P.S. you got the names wrong: system32 is 64-bit, syswow64 is 32-bit.
                                              • 21. Re: trouble Flash 11
                                                UnFlash Level 1
                                                Done and rebooted. @ PS Long day . Tried install, same results.
                                                • 22. Re: trouble Flash 11
                                                  UnFlash Level 1
                                                  =O====== M/11.2.202.228 2012-04-13+03-21-24.389 ========
                                                  0000 [W] 00001113 C:\Windows\system32\Macromed\Flash\\* 3
                                                  0001 [I] 00000010 "C:\Users\Admin\Desktop\__Download\uninstall_flash_player_64bit.exe" -force
                                                  0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0005 [W] 00001018
                                                  0006 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
                                                  0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                                                  0008 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                                                  0009 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                                                  0010 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                                                  0011 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                                                  0012 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                                                  0013 [W] 00001021
                                                  0014 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0015 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0016 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                                                  0017 [W] 00001048
                                                  0018 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                                                  0019 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0021 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                                                  0022 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0023 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0024 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0025 [W] 00001018
                                                  0026 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                                                  0027 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                                                  0028 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                                                  0029 [W] 00001019
                                                  0030 [W] 00001020
                                                  0031 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                                                  0032 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                                                  0033 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                                                  0034 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                                                  0035 [W] 00001021
                                                  0036 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0037 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0038 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                                                  0039 [W] 00001048
                                                  0040 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                                                  0041 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0042 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0043 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
                                                  0044 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0045 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0046 [W] 00001036 Software\Opera Software/Last CommandLine 2
                                                  0047 [W] 00001036 Software\Opera Software/Last CommandLine 2
                                                  0048 [W] 00001036 Software\Opera Software/Plugin Path 2
                                                  0049 [W] 00001036 Software\Opera Software/Plugin Path 2
                                                  0050 [I] 00000011 1
                                                  =X====== M/11.2.202.228 2012-04-13+03-21-29.170 ========
                                                  =O====== M/11.2.202.228 2012-04-13+03-34-50.133 ========
                                                  0000 [I] 00000010 "C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe" -install -msi
                                                  0003 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                                  0004 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                                                  0005 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx
                                                  0006 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.exe
                                                  0007 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_ActiveX.dll
                                                  0008 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                                  0009 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
                                                  0010 [I] 00000018
                                                  0011 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash64_11_2_202_228.ocx 80070005
                                                  =X====== M/11.2.202.228 2012-04-13+03-34-57.058 ========
                                                  Next
                                                  =O====== M/11.2.202.228 2012-04-13+03-21-19.202 ========
                                                  0001 [I] 00000010 "C:\Users\Admin\Desktop\__Download\uninstall_flash_player_32bit.exe" -force
                                                  0002 [E] 00001042
                                                  =X====== M/11.2.202.228 2012-04-13+03-21-22.061 ========
                                                  =O====== M/11.2.202.228 2012-04-13+03-21-27.717 ========
                                                  0000 [I] 00000010 "C:\Users\Admin\AppData\Local\Temp\{5BB16666-101E-410A-B931-A384C4339FEC}\InstallFlashPla yer.exe" -force  -uninstall
                                                  0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0002 [W] 00001018
                                                  0003 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
                                                  0005 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                                                  0006 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                                                  0007 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                                                  0008 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                                                  0009 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                                                  0010 [W] 00001021
                                                  0011 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0012 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0013 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                                                  0014 [W] 00001048
                                                  0015 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                                  0016 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0018 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                                                  0021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0022 [W] 00001018
                                                  0023 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                                                  0024 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
                                                  0025 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
                                                  0026 [W] 00001019
                                                  0027 [W] 00001020
                                                  0028 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                                                  0029 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
                                                  0030 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
                                                  0031 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                                                  0032 [W] 00001021
                                                  0033 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0035 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                                                  0036 [W] 00001048
                                                  0037 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
                                                  0038 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                                  0039 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                                  0040 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 2
                                                  0043 [W] 00001036 Software\Opera Software/Last CommandLine 2
                                                  0044 [W] 00001036 Software\Opera Software/Last CommandLine 2
                                                  0045 [W] 00001036 Software\Opera Software/Plugin Path 2
                                                  0046 [W] 00001036 Software\Opera Software/Plugin Path 2
                                                  =X====== M/11.2.202.228 2012-04-13+03-21-27.874 ========
                                                  And
                                                  === Verbose logging started: 4/12/2012  22:33:46  Build type: SHIP UNICODE 5.00.7601.00  Calling process: C:\Windows\System32\msiexec.exe ===
                                                  MSI (c) (64:A0) [22:33:46:086]: Font created.  Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
                                                  MSI (c) (64:B0) [22:33:46:102]: Resetting cached policy values
                                                  MSI (c) (64:B0) [22:33:46:102]: Machine policy value 'Debug' is 0
                                                  MSI (c) (64:B0) [22:33:46:102]: ******* RunEngine:
                                                             ******* Product: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
                                                             ******* Action:
                                                             ******* CommandLine: **********
                                                  MSI (c) (64:B0) [22:33:46:102]: Machine policy value 'DisableUserInstalls' is 0
                                                  MSI (c) (64:B0) [22:33:46:118]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi' against software restriction policy
                                                  MSI (c) (64:B0) [22:33:46:118]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi has a digital signature
                                                  MSI (c) (64:B0) [22:33:46:243]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
                                                  MSI (c) (64:B0) [22:33:46:336]: Cloaking enabled.
                                                  MSI (c) (64:B0) [22:33:46:336]: Attempting to enable all disabled privileges before calling Install on Server
                                                  MSI (c) (64:B0) [22:33:46:336]: End dialog not enabled
                                                  MSI (c) (64:B0) [22:33:46:336]: Original package ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
                                                  MSI (c) (64:B0) [22:33:46:336]: Package we're running from ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
                                                  MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: Compatibility mode property overrides found.
                                                  MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                                  MSI (c) (64:B0) [22:33:46:336]: APPCOMPAT: no matching ProductCode found in database.
                                                  MSI (c) (64:B0) [22:33:46:383]: MSCOREE not loaded loading copy from system32
                                                  MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'TransformsSecure' is 0
                                                  MSI (c) (64:B0) [22:33:46:415]: User policy value 'TransformsAtSource' is 0
                                                  MSI (c) (64:B0) [22:33:46:415]: Note: 1: 2205 2:  3: MsiFileHash
                                                  MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'DisablePatch' is 0
                                                  MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'AllowLockdownPatch' is 0
                                                  MSI (c) (64:B0) [22:33:46:415]: Machine policy value 'DisableLUAPatching' is 0
                                                  MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'DisableFlyWeightPatching' is 0
                                                  MSI (c) (64:B0) [22:33:46:430]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
                                                  MSI (c) (64:B0) [22:33:46:430]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                                  MSI (c) (64:B0) [22:33:46:430]: APPCOMPAT: no matching ProductCode found in database.
                                                  MSI (c) (64:B0) [22:33:46:430]: Transforms are not secure.
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Admin\AppData\Local\Temp\MSI78867.LOG'.
                                                  MSI (c) (64:B0) [22:33:46:430]: Command Line: CURRENTDIRECTORY=C:\Users\Admin\Desktop\__Download CLIENTUILEVEL=0 CLIENTPROCESSID=3940
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
                                                  MSI (c) (64:B0) [22:33:46:430]: Product Code passed to Engine.Initialize:           ''
                                                  MSI (c) (64:B0) [22:33:46:430]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                                  MSI (c) (64:B0) [22:33:46:430]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                                  MSI (c) (64:B0) [22:33:46:430]: Product not registered: beginning first-time install
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
                                                  MSI (c) (64:B0) [22:33:46:430]: Entering CMsiConfigurationManager::SetLastUsedSource.
                                                  MSI (c) (64:B0) [22:33:46:430]: User policy value 'SearchOrder' is 'nmu'
                                                  MSI (c) (64:B0) [22:33:46:430]: Adding new sources is allowed.
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
                                                  MSI (c) (64:B0) [22:33:46:430]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
                                                  MSI (c) (64:B0) [22:33:46:430]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
                                                  MSI (c) (64:B0) [22:33:46:430]: Note: 1: 2262 2: AdminProperties 3: -2147287038
                                                  MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'DisableMsi' is 0
                                                  MSI (c) (64:B0) [22:33:46:430]: Machine policy value 'AlwaysInstallElevated' is 0
                                                  MSI (c) (64:B0) [22:33:46:430]: User policy value 'AlwaysInstallElevated' is 0
                                                  MSI (c) (64:B0) [22:33:46:430]: Product installation will be elevated because user is admin and product is being installed per-machine.
                                                  MSI (c) (64:B0) [22:33:46:430]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop\__Download'.
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '3940'.
                                                  MSI (c) (64:B0) [22:33:46:430]: TRANSFORMS property is now:
                                                  MSI (c) (64:B0) [22:33:46:430]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
                                                  MSI (c) (64:B0) [22:33:46:430]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
                                                  MSI (c) (64:B0) [22:33:46:430]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
                                                  MSI (c) (64:B0) [22:33:46:446]: MSI_LUA: Setting AdminUser property to 1 because this is the client or the user has already permitted elevation
                                                  MSI (c) (64:B0) [22:33:46:446]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
                                                  MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
                                                  MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
                                                  MSI (c) (64:B0) [22:33:46:446]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
                                                  MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Jasper'.
                                                  MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi'.
                                                  MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi'.
                                                  MSI (c) (64:B0) [22:33:46:446]: Machine policy value 'MsiDisableEmbeddedUI' is 0
                                                  MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
                                                  MSI (c) (64:B0) [22:33:46:446]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
                                                  MSI (c) (64:A0) [22:33:46:477]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
                                                  === Logging started: 4/12/2012  22:33:46 ===
                                                  MSI (c) (64:B0) [22:33:46:477]: Note: 1: 2205 2:  3: PatchPackage
                                                  MSI (c) (64:B0) [22:33:46:477]: Machine policy value 'DisableRollback' is 0
                                                  MSI (c) (64:B0) [22:33:46:477]: User policy value 'DisableRollback' is 0
                                                  MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
                                                  MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
                                                  MSI (c) (64:B0) [22:33:46:477]: Doing action: INSTALL
                                                  Action 22:33:46: INSTALL.
                                                  Action start 22:33:46: INSTALL.
                                                  MSI (c) (64:B0) [22:33:46:477]: UI Sequence table 'InstallUISequence' is present and populated.
                                                  MSI (c) (64:B0) [22:33:46:477]: Running UISequence
                                                  MSI (c) (64:B0) [22:33:46:477]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
                                                  MSI (c) (64:B0) [22:33:46:477]: Doing action: ISSetAllUsers
                                                  Action 22:33:46: ISSetAllUsers.
                                                  Action start 22:33:46: ISSetAllUsers.
                                                  MSI (c) (64:B0) [22:33:46:524]: Creating MSIHANDLE (1) of type 790542 for thread 1968
                                                  MSI (c) (64:2C) [22:33:46:540]: Invoking remote custom action. DLL: C:\Users\Admin\AppData\Local\Temp\MSI8A0F.tmp, Entrypoint: SetAllUsers
                                                  MSI (c) (64:A8) [22:33:46:540]: Cloaking enabled.
                                                  MSI (c) (64:A8) [22:33:46:540]: Attempting to enable all disabled privileges before calling Install on Server
                                                  MSI (c) (64:A8) [22:33:46:540]: Connected to service for CA interface.
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (2) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: Begin SetAllUsers()
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (2) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (3) of type 790541 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (4) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: Getting records from Upgrade table
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (4) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (5) of type 790540 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (6) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (7) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 11.2.202.228 Language:  Attributes: 769
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (7) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (8) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (8) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (6) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (9) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (10) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (10) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (11) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (11) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (9) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (12) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (13) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion:  MaxVersion: 11.2.202.228 Language:  Attributes: 257
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (13) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (14) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (14) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (12) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Creating MSIHANDLE (15) of type 790531 for thread 3748
                                                  InstallShield 22:33:46: End SetAllUsers()
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (15) of type 790531 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (5) of type 790540 for thread 3748
                                                  MSI (c) (64!A4) [22:33:46:821]: Closing MSIHANDLE (3) of type 790541 for thread 3748
                                                  MSI (c) (64:2C) [22:33:46:821]: Closing MSIHANDLE (1) of type 790542 for thread 1968
                                                  Action ended 22:33:46: ISSetAllUsers. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:821]: Doing action: AppSearch
                                                  Action 22:33:46: AppSearch. Searching for installed applications
                                                  Action start 22:33:46: AppSearch.
                                                  MSI (c) (64:B0) [22:33:46:821]: Note: 1: 2205 2:  3: AppSearch
                                                  MSI (c) (64:B0) [22:33:46:821]: Note: 1: 2228 2:  3: AppSearch 4: SELECT `Property`, `Signature_` FROM `AppSearch`
                                                  Action ended 22:33:46: AppSearch. Return value 0.
                                                  MSI (c) (64:B0) [22:33:46:821]: Doing action: LaunchConditions
                                                  Action 22:33:46: LaunchConditions. Evaluating launch conditions
                                                  Action start 22:33:46: LaunchConditions.
                                                  Action ended 22:33:46: LaunchConditions. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:821]: Doing action: SetupInitialization
                                                  Action 22:33:46: SetupInitialization.
                                                  Action start 22:33:46: SetupInitialization.
                                                  Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                                  Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                                  Action 22:33:46: SetupInitialization. Dialog created
                                                  Action ended 22:33:46: SetupInitialization. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:852]: Doing action: FindRelatedProducts
                                                  Action 22:33:46: FindRelatedProducts. Searching for related applications
                                                  Action start 22:33:46: FindRelatedProducts.
                                                  Action ended 22:33:46: FindRelatedProducts. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:852]: Skipping action: CCPSearch (condition is false)
                                                  MSI (c) (64:B0) [22:33:46:852]: Skipping action: RMCCPSearch (condition is false)
                                                  MSI (c) (64:B0) [22:33:46:852]: Doing action: ValidateProductID
                                                  Action 22:33:46: ValidateProductID.
                                                  Action start 22:33:46: ValidateProductID.
                                                  Action ended 22:33:46: ValidateProductID. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:852]: Doing action: CostInitialize
                                                  Action 22:33:46: CostInitialize. Computing space requirements
                                                  Action start 22:33:46: CostInitialize.
                                                  MSI (c) (64:B0) [22:33:46:852]: Machine policy value 'MaxPatchCacheSize' is 10
                                                  MSI (c) (64:B0) [22:33:46:852]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
                                                  MSI (c) (64:B0) [22:33:46:852]: Baseline: New baseline 11.2.202 from transaction.
                                                  MSI (c) (64:B0) [22:33:46:899]: Baseline: Sorted order Native: Order 0.
                                                  MSI (c) (64:B0) [22:33:46:899]: Baseline Data Table:
                                                  MSI (c) (64:B0) [22:33:46:899]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
                                                  MSI (c) (64:B0) [22:33:46:899]: Baseline File Table:
                                                  MSI (c) (64:B0) [22:33:46:915]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
                                                  MSI (c) (64:B0) [22:33:46:915]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
                                                  Action ended 22:33:46: CostInitialize. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:915]: Doing action: FileCost
                                                  Action 22:33:46: FileCost. Computing space requirements
                                                  Action start 22:33:46: FileCost.
                                                  MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: MsiAssembly
                                                  MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: Class
                                                  MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: Extension
                                                  MSI (c) (64:B0) [22:33:46:915]: Note: 1: 2205 2:  3: TypeLib
                                                  Action ended 22:33:46: FileCost. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:915]: Doing action: IsolateComponents
                                                  Action 22:33:46: IsolateComponents.
                                                  Action start 22:33:46: IsolateComponents.
                                                  Action ended 22:33:46: IsolateComponents. Return value 0.
                                                  MSI (c) (64:B0) [22:33:46:915]: Doing action: setUserProfileNT
                                                  Action 22:33:46: setUserProfileNT.
                                                  Action start 22:33:46: setUserProfileNT.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin'.
                                                  Action ended 22:33:46: setUserProfileNT. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:930]: Skipping action: SetAllUsersProfileNT (condition is false)
                                                  MSI (c) (64:B0) [22:33:46:930]: Doing action: setAllUsersProfile2K
                                                  Action 22:33:46: setAllUsersProfile2K.
                                                  Action start 22:33:46: setAllUsersProfile2K.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData'.
                                                  Action ended 22:33:46: setAllUsersProfile2K. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:930]: Doing action: ResolveSource
                                                  Action 22:33:46: ResolveSource.
                                                  Action start 22:33:46: ResolveSource.
                                                  MSI (c) (64:B0) [22:33:46:930]: Resolving source.
                                                  MSI (c) (64:B0) [22:33:46:930]: Resolving source to launched-from source.
                                                  MSI (c) (64:B0) [22:33:46:930]: Setting launched-from source as last-used.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                                  MSI (c) (64:B0) [22:33:46:930]: SOURCEDIR ==> C:\Users\Admin\Desktop\__Download\
                                                  MSI (c) (64:B0) [22:33:46:930]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
                                                  MSI (c) (64:B0) [22:33:46:930]: Determining source type
                                                  MSI (c) (64:B0) [22:33:46:930]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
                                                  MSI (c) (64:B0) [22:33:46:930]: Source path resolution complete. Dumping Directory table...
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\__Download\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\__Download\Temp\ , LongSubPath: Temp\ , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\__Download\System64\ , LongSubPath: System64\ , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\ , LongSubPath: Common\ , ShortSubPath:
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\__Download\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
                                                  Action ended 22:33:46: ResolveSource. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:930]: Doing action: CostFinalize
                                                  Action 22:33:46: CostFinalize. Computing space requirements
                                                  Action start 22:33:46: CostFinalize.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
                                                  MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2262 2: Patch 3: -2147287038
                                                  MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2205 2:  3: Condition
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Modifying USERPROFILE property. Its current value is 'C:\Users\Admin'. Its new value: 'C:\Users\Admin\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: PROPERTY CHANGE: Modifying ALLUSERSPROFILE property. Its current value is 'C:\ProgramData'. Its new value: 'C:\ProgramData\'.
                                                  MSI (c) (64:B0) [22:33:46:930]: Target path resolution complete. Dumping Directory table...
                                                  MSI (c) (64:B0) [22:33:46:930]: Note: target paths subject to change (via custom actions or browsing)
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: TARGETDIR , Object: E:\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: TempFolder , Object: C:\Users\Admin\AppData\Local\Temp\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                                                  MSI (c) (64:B0) [22:33:46:930]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
                                                  MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2205 2:  3: MsiAssembly
                                                  MSI (c) (64:B0) [22:33:46:930]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
                                                  Action ended 22:33:46: CostFinalize. Return value 1.
                                                  MSI (c) (64:B0) [22:33:46:930]: Doing action: MigrateFeatureStates
                                                  Action 22:33:46: MigrateFeatureStates. Migrating feature states from related applications
                                                  Action start 22:33:46: MigrateFeatureStates.
                                                  Action ended 22:33:46: MigrateFeatureStates. Return value 0.
                                                  MSI (c) (64:B0) [22:33:46:930]: Skipping action: PatchWelcome (condition is false)
                                                  MSI (c) (64:B0) [22:33:46:930]: Doing action: InstallWelcome
                                                  Action 22:33:46: InstallWelcome.
                                                  Action start 22:33:46: InstallWelcome.
                                                  Action 22:33:46: InstallWelcome. Dialog created
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: _RemoveFilePath
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: MsiFileHash
                                                  MSI (c) (64:D8) [22:33:46:946]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: BindImage
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: ProgId
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: PublishComponent
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: SelfReg
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Extension
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Font
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Shortcut
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: Class
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2205 2:  3: TypeLib
                                                  MSI (c) (64:D8) [22:33:46:946]: Note: 1: 2727 2:
                                                  Action ended 22:33:48: InstallWelcome. Return value 1.
                                                  MSI (c) (64:B0) [22:33:48:430]: Skipping action: SetupResume (condition is false)
                                                  MSI (c) (64:B0) [22:33:48:430]: Skipping action: MaintenanceWelcome (condition is false)
                                                  MSI (c) (64:B0) [22:33:48:430]: Doing action: SetupProgress
                                                  Action 22:33:48: SetupProgress.
                                                  Action start 22:33:48: SetupProgress.
                                                  Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                                  Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
                                                  Action 22:33:48: SetupProgress. Dialog created
                                                  Action ended 22:33:48: SetupProgress. Return value 1.
                                                  MSI (c) (64:B0) [22:33:48:477]: Doing action: ExecuteAction
                                                  Action 22:33:48: ExecuteAction.
                                                  Action start 22:33:48: ExecuteAction.
                                                  MSI (c) (64:B0) [22:33:48:477]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
                                                  MSI (c) (64:B0) [22:33:48:477]: Grabbed execution mutex.
                                                  MSI (c) (64:B0) [22:33:48:477]: Incrementing counter to disable shutdown. Counter after increment: 0
                                                  MSI (c) (64:B0) [22:33:48:477]: Switching to server: SECONDSEQUENCE="1" TARGETDIR="E:\" ALLUSERSPROFILE="C:\ProgramData\" MACROMED="C:\Windows\system32\Macromed\" FLASH="C:\Windows\system32\Macromed\Flash\" INSTALLDIR="C:\Windows\system32\Macromed\Flash\" ROOTDRIVE="E:\" USERPROFILE="C:\Users\Admin\" EXECUTEACTION="INSTALL" ACTION="INSTALL" SOURCEDIR="C:\Users\Admin\Desktop\__Download\" USERNAME="Jasper" CLIENTPROCESSID="3940" CLIENTUILEVEL="0" CURRENTDIRECTORY="C:\Users\Admin\Desktop\__Download"  ADDLOCAL=FlashPlayerAXInstaller
                                                  MSI (s) (F8:E8) [22:33:48:493]: Running installation inside multi-package transaction C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
                                                  MSI (s) (F8:E8) [22:33:48:493]: Grabbed execution mutex.
                                                  MSI (s) (F8:C8) [22:33:48:493]: Resetting cached policy values
                                                  MSI (s) (F8:C8) [22:33:48:493]: Machine policy value 'Debug' is 0
                                                  MSI (s) (F8:C8) [22:33:48:493]: ******* RunEngine:
                                                             ******* Action: INSTALL
                                                  MSI (s) (F8:C8) [22:33:48:493]: Machine policy value 'DisableUserInstalls' is 0
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 13E07932B849E664386721423DF2FDC0
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 8B17357F59074B5F87FBCDE4D112027B
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: 9F268D25182F5B148860854DBA8B51E9
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: User non-assigned for product: BB6F3BEED8135EC489F91819CFFB5B87
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109110000000000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109110000000000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109440090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109440090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109510090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109510090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109511090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109511090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109610090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109610090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Setting cached product context: machine assigned for product: 00002109611090400100000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:493]: Using cached product context: machine assigned for product: 00002109611090400100000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109711090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109711090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109810090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109810090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109910090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109910090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A10090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A20000000100000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109A20090400100000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109B10090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109C20090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109E60090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F10090400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F100A0C00000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 00002109F100C0400000000000F01FEC
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: 4EA42A62D9304AC4784BF238120613FF
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: D430EE3D29B555A4AA20E2D6A0A669EE
                                                  MSI (s) (F8:C8) [22:33:48:508]: Setting cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
                                                  MSI (s) (F8:C8) [22:33:48:508]: Using cached product context: machine assigned for product: F60730A4A66673047777F5728467D401
                                                  MSI (s) (F8:C8) [22:33:48:508]: Machine policy value 'LimitSystemRestoreCheckpointing' is 0
                                                  MSI (s) (F8:C8) [22:33:48:508]: Note: 1: 1715 2: Adobe Flash Player 11 ActiveX (x64)
                                                  MSI (s) (F8:C8) [22:33:48:508]: Calling SRSetRestorePoint API. dwRestorePtType: 0, dwEventType: 102, llSequenceNumber: 0, szDescription: "Installed Adobe Flash Player 11 ActiveX (x64).".
                                                  MSI (s) (F8:C8) [22:34:43:743]: The call to SRSetRestorePoint API succeeded. Returned status: 0, llSequenceNumber: 394.
                                                  MSI (s) (F8:C8) [22:34:43:743]: File will have security applied from OpCode.
                                                  MSI (s) (F8:C8) [22:34:43:821]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi' against software restriction policy
                                                  MSI (s) (F8:C8) [22:34:43:821]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi has a digital signature
                                                  MSI (s) (F8:C8) [22:34:44:524]: SOFTWARE RESTRICTION POLICY: C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi is permitted to run at the 'unrestricted' authorization level.
                                                  MSI (s) (F8:C8) [22:34:44:524]: End dialog not enabled
                                                  MSI (s) (F8:C8) [22:34:44:524]: Original package ==> C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi
                                                  MSI (s) (F8:C8) [22:34:44:524]: Package we're running from ==> C:\Windows\Installer\869bf.msi
                                                  MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: Compatibility mode property overrides found.
                                                  MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                                  MSI (s) (F8:C8) [22:34:44:524]: APPCOMPAT: no matching ProductCode found in database.
                                                  MSI (s) (F8:C8) [22:34:44:524]: MSCOREE not loaded loading copy from system32
                                                  MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'TransformsSecure' is 0
                                                  MSI (s) (F8:C8) [22:34:44:524]: User policy value 'TransformsAtSource' is 0
                                                  MSI (s) (F8:C8) [22:34:44:524]: Note: 1: 2205 2:  3: MsiFileHash
                                                  MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisablePatch' is 0
                                                  MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'AllowLockdownPatch' is 0
                                                  MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisableLUAPatching' is 0
                                                  MSI (s) (F8:C8) [22:34:44:524]: Machine policy value 'DisableFlyWeightPatching' is 0
                                                  MSI (s) (F8:C8) [22:34:44:524]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
                                                  MSI (s) (F8:C8) [22:34:44:540]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: APPCOMPAT: no matching ProductCode found in database.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Transforms are not secure.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\Admin\AppData\Local\Temp\MSI78867.LOG'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Command Line: SECONDSEQUENCE=1 TARGETDIR=E:\ ALLUSERSPROFILE=C:\ProgramData\ MACROMED=C:\Windows\system32\Macromed\ FLASH=C:\Windows\system32\Macromed\Flash\ INSTALLDIR=C:\Windows\system32\Macromed\Flash\ ROOTDRIVE=E:\ USERPROFILE=C:\Users\Admin\ EXECUTEACTION=INSTALL ACTION=INSTALL SOURCEDIR=C:\Users\Admin\Desktop\__Download\ USERNAME=Jasper CLIENTPROCESSID=3940 CLIENTUILEVEL=0 CURRENTDIRECTORY=C:\Users\Admin\Desktop\__Download ADDLOCAL=FlashPlayerAXInstaller ACTION=INSTALL
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{56994055-C101-488E-A9CB-CF207652B759}'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Product Code passed to Engine.Initialize:           ''
                                                  MSI (s) (F8:C8) [22:34:44:540]: Product Code from property table before transforms: '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                                  MSI (s) (F8:C8) [22:34:44:540]: Product Code from property table after transforms:  '{5C804EBB-475F-4555-A225-1D6573F158BD}'
                                                  MSI (s) (F8:C8) [22:34:44:540]: Product not registered: beginning first-time install
                                                  MSI (s) (F8:C8) [22:34:44:540]: Product {5C804EBB-475F-4555-A225-1D6573F158BD} is not managed.
                                                  MSI (s) (F8:C8) [22:34:44:540]: MSI_LUA: Credential prompt not required, user is an admin
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Entering CMsiConfigurationManager::SetLastUsedSource.
                                                  MSI (s) (F8:C8) [22:34:44:540]: User policy value 'SearchOrder' is 'nmu'
                                                  MSI (s) (F8:C8) [22:34:44:540]: Adding new sources is allowed.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Package name extracted from package path: 'install_flash_player_11_active_x_64bit.msi'
                                                  MSI (s) (F8:C8) [22:34:44:540]: Package to be registered: 'install_flash_player_11_active_x_64bit.msi'
                                                  MSI (s) (F8:C8) [22:34:44:540]: Note: 1: 2262 2: AdminProperties 3: -2147287038
                                                  MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'DisableMsi' is 0
                                                  MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'AlwaysInstallElevated' is 0
                                                  MSI (s) (F8:C8) [22:34:44:540]: User policy value 'AlwaysInstallElevated' is 0
                                                  MSI (s) (F8:C8) [22:34:44:540]: Product installation will be elevated because user is admin and product is being installed per-machine.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Running product '{5C804EBB-475F-4555-A225-1D6573F158BD}' with elevated privileges: Product is assigned.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding SECONDSEQUENCE property. Its value is '1'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'E:\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\ProgramData\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\system32\Macromed\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'E:\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Users\Admin\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Jasper'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '3940'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Users\Admin\Desktop\__Download'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'FlashPlayerAXInstaller'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'da7e3209e9117142ada46c8feb786c33'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: RESTART MANAGER: Session opened.
                                                  MSI (s) (F8:C8) [22:34:44:540]: Engine has iefSecondSequence set to true.
                                                  MSI (s) (F8:C8) [22:34:44:540]: TRANSFORMS property is now:
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Deleting SOURCEDIR property. Its current value is 'C:\Users\Admin\Desktop\__Download\'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
                                                  MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming
                                                  MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Favorites
                                                  MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Network Shortcuts
                                                  MSI (s) (F8:C8) [22:34:44:540]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Documents
                                                  MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
                                                  MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Recent
                                                  MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\SendTo
                                                  MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Templates
                                                  MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\ProgramData
                                                  MSI (s) (F8:C8) [22:34:44:555]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Local
                                                  MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Pictures
                                                  MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                                  MSI (s) (F8:C8) [22:34:44:571]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                                                  MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
                                                  MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
                                                  MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
                                                  MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Users\Admin\Desktop
                                                  MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
                                                  MSI (s) (F8:C8) [22:34:44:586]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
                                                  MSI (s) (F8:C8) [22:34:44:586]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
                                                  MSI (s) (F8:C8) [22:34:44:602]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
                                                  MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
                                                  MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
                                                  MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\869bf.msi'.
                                                  MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\Admin\Desktop\__Download\install_flash_player_11_active_x_64bit.msi'.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'MsiDisableEmbeddedUI' is 0
                                                  MSI (s) (F8:C8) [22:34:44:602]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: PatchPackage
                                                  MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'DisableRollback' is 0
                                                  MSI (s) (F8:C8) [22:34:44:602]: User policy value 'DisableRollback' is 0
                                                  MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
                                                  MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding Preselected property. Its value is '1'.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: INSTALL
                                                  Action 22:34:44: INSTALL.
                                                  Action start 22:34:44: INSTALL.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Running ExecuteSequence
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: ISSetAllUsers
                                                  Action 22:34:44: ISSetAllUsers.
                                                  Action start 22:34:44: ISSetAllUsers.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Skipping action due to msidbCustomActionTypeFirstSequence option.
                                                  Action ended 22:34:44: ISSetAllUsers. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: AppSearch
                                                  Action 22:34:44: AppSearch. Searching for installed applications
                                                  Action start 22:34:44: AppSearch.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Skipping AppSearch action: already done on client side
                                                  Action ended 22:34:44: AppSearch. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: LaunchConditions
                                                  Action 22:34:44: LaunchConditions. Evaluating launch conditions
                                                  Action start 22:34:44: LaunchConditions.
                                                  Action ended 22:34:44: LaunchConditions. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: FindRelatedProducts
                                                  Action 22:34:44: FindRelatedProducts. Searching for related applications
                                                  Action start 22:34:44: FindRelatedProducts.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Skipping FindRelatedProducts action: already done on client side
                                                  Action ended 22:34:44: FindRelatedProducts. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Skipping action: CCPSearch (condition is false)
                                                  MSI (s) (F8:C8) [22:34:44:602]: Skipping action: RMCCPSearch (condition is false)
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: ValidateProductID
                                                  Action 22:34:44: ValidateProductID.
                                                  Action start 22:34:44: ValidateProductID.
                                                  Action ended 22:34:44: ValidateProductID. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: CostInitialize
                                                  Action 22:34:44: CostInitialize. Computing space requirements
                                                  Action start 22:34:44: CostInitialize.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Machine policy value 'MaxPatchCacheSize' is 10
                                                  MSI (s) (F8:C8) [22:34:44:602]: Baseline: Sorting baselines for {5C804EBB-475F-4555-A225-1D6573F158BD}.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Baseline: New baseline 11.2.202 from transaction.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Baseline: Sorted order Native: Order 0.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Baseline Data Table:
                                                  MSI (s) (F8:C8) [22:34:44:602]: ProductCode: {5C804EBB-475F-4555-A225-1D6573F158BD} Version: 11.2.202 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
                                                  MSI (s) (F8:C8) [22:34:44:602]: Baseline File Table:
                                                  MSI (s) (F8:C8) [22:34:44:602]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2262 2: Patch 3: -2147287038
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: MsiPatchHeaders
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: __MsiPatchFileList
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2228 2:  3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
                                                  MSI (s) (F8:C8) [22:34:44:602]: Delta compression fallback method for this product transaction is 'MSI 2.0 legacy obsolescence'
                                                  Action ended 22:34:44: CostInitialize. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: FileCost
                                                  Action 22:34:44: FileCost. Computing space requirements
                                                  Action start 22:34:44: FileCost.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: MsiAssembly
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: Class
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: Extension
                                                  MSI (s) (F8:C8) [22:34:44:602]: Note: 1: 2205 2:  3: TypeLib
                                                  Action ended 22:34:44: FileCost. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: IsolateComponents
                                                  Action 22:34:44: IsolateComponents.
                                                  Action start 22:34:44: IsolateComponents.
                                                  Action ended 22:34:44: IsolateComponents. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:44:602]: Doing action: CostFinalize
                                                  Action 22:34:44: CostFinalize. Computing space requirements
                                                  Action start 22:34:44: CostFinalize.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Condition
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Target path resolution complete. Dumping Directory table...
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: target paths subject to change (via custom actions or browsing)
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: TARGETDIR , Object: E:\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: USERPROFILE , Object: C:\Users\Admin\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: TempFolder , Object: C:\Users\Admin\AppData\Local\Temp\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: MACROMED , Object: C:\Windows\system32\Macromed\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: FLASH , Object: C:\Windows\system32\Macromed\Flash\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\system32\Macromed\Flash\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\ProgramData\
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: MsiAssembly
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: MsiAssembly 4:  SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`,  `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE  `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
                                                  Action ended 22:34:44: CostFinalize. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Doing action: SetARPINSTALLLOCATION
                                                  Action 22:34:44: SetARPINSTALLLOCATION.
                                                  Action start 22:34:44: SetARPINSTALLLOCATION.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                                  Action ended 22:34:44: SetARPINSTALLLOCATION. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Doing action: SetODBCFolders
                                                  Action 22:34:44: SetODBCFolders. Initializing ODBC directories
                                                  Action start 22:34:44: SetODBCFolders.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ODBCDriver
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ODBCTranslator
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
                                                  Action ended 22:34:44: SetODBCFolders. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Doing action: MigrateFeatureStates
                                                  Action 22:34:44: MigrateFeatureStates. Migrating feature states from related applications
                                                  Action start 22:34:44: MigrateFeatureStates.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Skipping MigrateFeatureStates action: already done on client side
                                                  Action ended 22:34:44: MigrateFeatureStates. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Doing action: InstallValidate
                                                  Action 22:34:44: InstallValidate. Validating install
                                                  Action start 22:34:44: InstallValidate.
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'da7e3209e9117142ada46c8feb786c33'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Feature: FlashPlayerAXInstaller; Installed: Absent;   Request: Local;   Action: Local
                                                  MSI (s) (F8:C8) [22:34:44:618]: Component: __ISRegistryComponent65; Installed: Null;   Request: Local;   Action: Local;   Client State: Null
                                                  MSI (s) (F8:C8) [22:34:44:618]: Component: ISRegistryComponent; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
                                                  MSI (s) (F8:C8) [22:34:44:618]: Component: InstallAX64.exe; Installed: Absent;   Request: Local;   Action: Local;   Client State: Unknown
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: BindImage
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: ProgId
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: PublishComponent
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: SelfReg
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Extension
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Font
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Shortcut
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: Class
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: TypeLib
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: _RemoveFilePath
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: MsiFileHash
                                                  MSI (s) (F8:C8) [22:34:44:618]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2727 2:
                                                  MSI (s) (F8:C8) [22:34:44:618]: Note: 1: 2205 2:  3: FilesInUse
                                                  MSI (s) (F8:C8) [22:34:44:743]: Note: 1: 2727 2:
                                                  Action ended 22:34:44: InstallValidate. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:743]: Doing action: RemoveExistingProducts
                                                  Action 22:34:44: RemoveExistingProducts. Removing applications
                                                  Action start 22:34:44: RemoveExistingProducts.
                                                  Action ended 22:34:44: RemoveExistingProducts. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:44:743]: Doing action: InstallInitialize
                                                  Action 22:34:44: InstallInitialize.
                                                  Action start 22:34:44: InstallInitialize.
                                                  MSI (s) (F8:C8) [22:34:44:743]: Machine policy value 'AlwaysInstallElevated' is 0
                                                  MSI (s) (F8:C8) [22:34:44:743]: User policy value 'AlwaysInstallElevated' is 0
                                                  MSI (s) (F8:C8) [22:34:44:743]: BeginTransaction: Locking Server
                                                  MSI (s) (F8:C8) [22:34:44:743]: Server not locked: locking for product {5C804EBB-475F-4555-A225-1D6573F158BD}
                                                  Action ended 22:34:48: InstallInitialize. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:727]: Skipping action: CallExeUninstaller (condition is false)
                                                  MSI (s) (F8:C8) [22:34:48:727]: Doing action: MakePropsAvailable
                                                  Action 22:34:48: MakePropsAvailable.
                                                  Action start 22:34:48: MakePropsAvailable.
                                                  MSI (s) (F8:C8) [22:34:48:727]: PROPERTY CHANGE: Adding RemoveFilesCA property. Its value is 'C:\Windows\system32\Macromed\Flash\'.
                                                  Action ended 22:34:48: MakePropsAvailable. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:743]: Doing action: AllocateRegistrySpace
                                                  Action 22:34:48: AllocateRegistrySpace. Allocating registry space
                                                  Action start 22:34:48: AllocateRegistrySpace.
                                                  Action ended 22:34:48: AllocateRegistrySpace. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:743]: Doing action: ProcessComponents
                                                  Action 22:34:48: ProcessComponents. Updating component registration
                                                  Action start 22:34:48: ProcessComponents.
                                                  MSI (s) (F8:C8) [22:34:48:743]: Note: 1: 2205 2:  3: MsiPatchCertificate
                                                  MSI (s) (F8:C8) [22:34:48:743]: LUA patching is disabled: missing MsiPatchCertificate table
                                                  MSI (s) (F8:C8) [22:34:48:743]: Resolving source.
                                                  MSI (s) (F8:C8) [22:34:48:743]: Resolving source to launched-from source.
                                                  MSI (s) (F8:C8) [22:34:48:743]: Setting launched-from source as last-used.
                                                  MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
                                                  MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\Admin\Desktop\__Download\'.
                                                  MSI (s) (F8:C8) [22:34:48:743]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{5C804EBB-475F-4555-A225-1D6573F158BD}'.
                                                  MSI (s) (F8:C8) [22:34:48:743]: SOURCEDIR ==> C:\Users\Admin\Desktop\__Download\
                                                  MSI (s) (F8:C8) [22:34:48:743]: SOURCEDIR product ==> {5C804EBB-475F-4555-A225-1D6573F158BD}
                                                  MSI (s) (F8:C8) [22:34:48:743]: Determining source type
                                                  MSI (s) (F8:C8) [22:34:48:743]: Source type from package 'install_flash_player_11_active_x_64bit.msi': 0
                                                  MSI (s) (F8:C8) [22:34:48:743]: Source path resolution complete. Dumping Directory table...
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: TARGETDIR , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: WindowsFolder , Object: C:\Users\Admin\Desktop\__Download\ , LongSubPath:  , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: USERPROFILE , Object: C:\Users\Admin\Desktop\__Download\UserProfile\ , LongSubPath: UserProfile\ , ShortSubPath: USERPR~1\
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: TempFolder , Object: C:\Users\Admin\Desktop\__Download\Temp\ , LongSubPath: Temp\ , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: System64Folder , Object: C:\Users\Admin\Desktop\__Download\System64\ , LongSubPath: System64\ , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: MACROMED , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\ , LongSubPath: System64\Macromed\ , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: FLASH , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: INSTALLDIR , Object: C:\Users\Admin\Desktop\__Download\System64\Macromed\Flash\ , LongSubPath: System64\Macromed\Flash\ , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: CommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\ , LongSubPath: Common\ , ShortSubPath:
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ISCommonFilesFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\ , LongSubPath: Common\InstallShield\ , ShortSubPath: Common\Instal~1\
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ISUpdateServiceFolder , Object: C:\Users\Admin\Desktop\__Download\Common\InstallShield\UpdateService\ , LongSubPath: Common\InstallShield\UpdateService\ , ShortSubPath: Common\Instal~1\UPDATE~1\
                                                  MSI (s) (F8:C8) [22:34:48:743]: Dir (source): Key: ALLUSERSPROFILE , Object: C:\Users\Admin\Desktop\__Download\All Users\ , LongSubPath: All Users\ , ShortSubPath: ALLUSE~1\
                                                  Action 22:34:48: GenerateScript. Generating script operations for action:
                                                  GenerateScript: Updating component registration
                                                  Action ended 22:34:48: ProcessComponents. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnpublishComponents
                                                  Action 22:34:48: UnpublishComponents. Unpublishing Qualified Components
                                                  Action start 22:34:48: UnpublishComponents.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: PublishComponent
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                                  Action ended 22:34:48: UnpublishComponents. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: MsiUnpublishAssemblies
                                                  Action 22:34:48: MsiUnpublishAssemblies. Unpublishing assembly information
                                                  Action start 22:34:48: MsiUnpublishAssemblies.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: MsiAssembly
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND (`Feature`.`Action` = 0 OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                                  Action ended 22:34:48: MsiUnpublishAssemblies. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnpublishFeatures
                                                  Action 22:34:48: UnpublishFeatures. Unpublishing product features
                                                  Action start 22:34:48: UnpublishFeatures.
                                                  Action ended 22:34:48: UnpublishFeatures. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: StopServices
                                                  Action 22:34:48: StopServices. Stopping services
                                                  Action start 22:34:48: StopServices.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ServiceControl
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
                                                  Action ended 22:34:48: StopServices. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: DeleteServices
                                                  Action 22:34:48: DeleteServices. Deleting services
                                                  Action start 22:34:48: DeleteServices.
                                                  Action ended 22:34:48: DeleteServices. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnregisterComPlus
                                                  Action 22:34:48: UnregisterComPlus. Unregistering COM+ Applications and Components
                                                  Action start 22:34:48: UnregisterComPlus.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: Complus
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
                                                  Action ended 22:34:48: UnregisterComPlus. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: SelfUnregModules
                                                  Action 22:34:48: SelfUnregModules. Unregistering modules
                                                  Action start 22:34:48: SelfUnregModules.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: SelfReg
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: SelfReg 4: Select `File`.`FileName`,`Component`.`Directory_`,`Component`.`Installed`, `File`.`Component_`,`SelfReg`.`File_`  From `SelfReg`, `File`, `Component` Where `SelfReg`.`File_` = `File`.`File` And `File`.`Component_` = `Component`.`Component` And `Component`.`Action` = 0
                                                  Action ended 22:34:48: SelfUnregModules. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: UnregisterTypeLibraries
                                                  Action 22:34:48: UnregisterTypeLibraries. Unregistering type libraries
                                                  Action start 22:34:48: UnregisterTypeLibraries.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: TypeLib
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Component`.`Action`=0)
                                                  Action ended 22:34:48: UnregisterTypeLibraries. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Doing action: RemoveODBC
                                                  Action 22:34:48: RemoveODBC. Removing ODBC components
                                                  Action start 22:34:48: RemoveODBC.
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCDataSource
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCTranslator
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2205 2:  3: ODBCDriver
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
                                                  MSI (s) (F8:C8) [22:34:48:836]: Note: 1: 2711 2: ODBCDriverManager
                                                  1: Removing ODBC components
                                                  MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2711 2: ODBCDriverManager64
                                                  Action ended 22:34:48: RemoveODBC. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:852]: Doing action: UnregisterFonts
                                                  Action 22:34:48: UnregisterFonts. Unregistering fonts
                                                  Action start 22:34:48: UnregisterFonts.
                                                  MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2205 2:  3: Font
                                                  MSI (s) (F8:C8) [22:34:48:852]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
                                                  Action ended 22:34:48: UnregisterFonts. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:868]: Doing action: RemoveRegistryValues
                                                  Action 22:34:48: RemoveRegistryValues. Removing system registry values
                                                  Action start 22:34:48: RemoveRegistryValues.
                                                  Action ended 22:34:48: RemoveRegistryValues. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterClassInfo
                                                  Action 22:34:48: UnregisterClassInfo. Unregister class servers
                                                  Action start 22:34:48: UnregisterClassInfo.
                                                  MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: Class
                                                  MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                                  Action ended 22:34:48: UnregisterClassInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterExtensionInfo
                                                  Action 22:34:48: UnregisterExtensionInfo. Unregistering extension servers
                                                  Action start 22:34:48: UnregisterExtensionInfo.
                                                  MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: Extension
                                                  MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                                  Action ended 22:34:48: UnregisterExtensionInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterProgIdInfo
                                                  Action 22:34:48: UnregisterProgIdInfo. Unregistering program identifiers
                                                  Action start 22:34:48: UnregisterProgIdInfo.
                                                  MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2205 2:  3: ProgId
                                                  MSI (s) (F8:C8) [22:34:48:883]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags` , `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                                  Action ended 22:34:48: UnregisterProgIdInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:883]: Doing action: UnregisterMIMEInfo
                                                  Action 22:34:48: UnregisterMIMEInfo. Unregistering MIME info
                                                  Action start 22:34:48: UnregisterMIMEInfo.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: MIME
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                                  Action ended 22:34:48: UnregisterMIMEInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveIniValues
                                                  Action 22:34:48: RemoveIniValues. Removing INI file entries
                                                  Action start 22:34:48: RemoveIniValues.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: IniFile
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
                                                  Action ended 22:34:48: RemoveIniValues. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveShortcuts
                                                  Action 22:34:48: RemoveShortcuts. Removing shortcuts
                                                  Action start 22:34:48: RemoveShortcuts.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: Shortcut
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, null, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Feature`.`Action`, `Component`.`Action` From  `Shortcut`, `Feature`, `Component` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND (`Feature`.`Action` = 0 OR (`Feature`.`Action` = 4 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)) OR ((`Feature`.`Action` = NULL OR `Feature`.`Action` = 3) AND `Component`.`Action` = 0 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2)))
                                                  Action ended 22:34:48: RemoveShortcuts. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveEnvironmentStrings
                                                  Action 22:34:48: RemoveEnvironmentStrings. Updating environment strings
                                                  Action start 22:34:48: RemoveEnvironmentStrings.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2205 2:  3: Environment
                                                  MSI (s) (F8:C8) [22:34:48:899]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
                                                  Action ended 22:34:48: RemoveEnvironmentStrings. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveDuplicateFiles
                                                  Action 22:34:48: RemoveDuplicateFiles. Removing duplicated files
                                                  Action start 22:34:48: RemoveDuplicateFiles.
                                                  Action ended 22:34:48: RemoveDuplicateFiles. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: RemoveFolders
                                                  Action 22:34:48: RemoveFolders. Removing folders
                                                  Action start 22:34:48: RemoveFolders.
                                                  Action ended 22:34:48: RemoveFolders. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: CreateFolders
                                                  Action 22:34:48: CreateFolders. Creating folders
                                                  Action start 22:34:48: CreateFolders.
                                                  CreateFolders: Folder: Creating folders
                                                  Action ended 22:34:48: CreateFolders. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: MoveFiles
                                                  Action 22:34:48: MoveFiles. Moving files
                                                  Action start 22:34:48: MoveFiles.
                                                  Action ended 22:34:48: MoveFiles. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:899]: Doing action: InstallFiles
                                                  Action 22:34:48: InstallFiles. Copying new files
                                                  Action start 22:34:48: InstallFiles.
                                                  MSI (s) (F8:C8) [22:34:48:915]: Dumping binary patch manager data...
                                                  MSI (s) (F8:C8) [22:34:48:915]: The file represented by File table key 'InstallAX64.exe' has no eligible binary patches
                                                  InstallFiles: File: Copying new files,  Directory: ,  Size:
                                                  MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiPatchOldAssemblyFile
                                                  MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE  `MsiPatchOldAssemblyFile`.`File_` = ?
                                                  MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiSFCBypass
                                                  MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiSFCBypass 4: SELECT `File_` FROM `MsiSFCBypass` WHERE `File_` = ?
                                                  MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: MsiPatchHeaders
                                                  MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2228 2:  3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
                                                  MSI (s) (F8:C8) [22:34:48:915]: Note: 1: 2205 2:  3: PatchPackage
                                                  Action ended 22:34:48: InstallFiles. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:946]: Doing action: NewCustomAction1
                                                  Action 22:34:48: NewCustomAction1.
                                                  Action start 22:34:48: NewCustomAction1.
                                                  NewCustomAction1:
                                                  Action ended 22:34:48: NewCustomAction1. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:946]: Doing action: PatchFiles
                                                  Action 22:34:48: PatchFiles. Patching files
                                                  Action start 22:34:48: PatchFiles.
                                                  Action ended 22:34:48: PatchFiles. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:946]: Doing action: DuplicateFiles
                                                  Action 22:34:48: DuplicateFiles. Creating duplicate files
                                                  Action start 22:34:48: DuplicateFiles.
                                                  Action ended 22:34:48: DuplicateFiles. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:946]: Doing action: BindImage
                                                  Action 22:34:48: BindImage. Binding executables
                                                  Action start 22:34:48: BindImage.
                                                  Action ended 22:34:48: BindImage. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:946]: Doing action: CreateShortcuts
                                                  Action 22:34:48: CreateShortcuts. Creating shortcuts
                                                  Action start 22:34:48: CreateShortcuts.
                                                  CreateShortcuts: Shortcut: Creating shortcuts
                                                  MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Shortcut
                                                  MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Shortcut 4: SELECT  `Shortcut`,`Name`, `FileName`, `Component`.`Directory_`, `Arguments`, `WkDir`, `Icon_`, `IconIndex`, `Hotkey`, `ShowCmd`, `Shortcut`.`Description`, `Shortcut`.`Directory_`, `Component`.`RuntimeFlags`, `Component`.`Action`, `Target`, `ComponentId`, `Feature`.`Action`, `Component`.`Installed`, `DisplayResourceDLL`, `DisplayResourceId`, `DescriptionResourceDLL`, `DescriptionResourceId` From `Shortcut`, `Feature`, `Component`, `File` WHERE `Target` = `Feature` AND `Shortcut`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
                                                  Action ended 22:34:48: CreateShortcuts. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterClassInfo
                                                  Action 22:34:48: RegisterClassInfo. Registering class servers
                                                  Action start 22:34:48: RegisterClassInfo.
                                                  MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Class
                                                  MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Class 4: SELECT `BinaryType`, `CLSID`, `ProgId_Default`, `Class`.`Description`, `Context`, `Feature_`, `ComponentId`, `Component`, `Class`.`Attributes`, `AppId_`, `FileTypeMask`, `Icon_`, `IconIndex`, `DefInprocHandler`, `Argument`, `Component`.`RuntimeFlags`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action`, `Component`.`Attributes` FROM `Class`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                                  Action ended 22:34:48: RegisterClassInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterExtensionInfo
                                                  Action 22:34:48: RegisterExtensionInfo. Registering extension servers
                                                  Action start 22:34:48: RegisterExtensionInfo.
                                                  MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2205 2:  3: Extension
                                                  MSI (s) (F8:C8) [22:34:48:961]: Note: 1: 2228 2:  3: Extension 4: SELECT `Extension`, `BinaryType`, `ProgId_`, null, null, `MIME_`, `Feature_`, `ComponentId`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `Feature`.`Action` FROM `Extension`, `Component`, `File`, `Feature` WHERE `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                                  Action ended 22:34:48: RegisterExtensionInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:961]: Doing action: RegisterProgIdInfo
                                                  Action 22:34:48: RegisterProgIdInfo. Registering program identifiers
                                                  Action start 22:34:48: RegisterProgIdInfo.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ProgId
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ProgId 4: SELECT DISTINCT `BinaryType`, `ProgId`, `Class_`, `ProgId`.`Description`, `ProgId`.`Icon_`, `ProgId`.`IconIndex`, null, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `ProgId`, `Class`, `Feature`, `Component` WHERE `ProgId`.`Class_` = `Class`.`CLSID` AND `Class`.`Feature_` = `Feature` AND `Class`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                                  Action ended 22:34:48: RegisterProgIdInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterMIMEInfo
                                                  Action 22:34:48: RegisterMIMEInfo. Registering MIME info
                                                  Action start 22:34:48: RegisterMIMEInfo.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: MIME
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: MIME 4: SELECT `BinaryType`, `ContentType`, `Extension`.`Extension`, `MIME`.`CLSID`, `Component`.`RuntimeFlags`, `Component`.`Component`, `Component`.`Attributes` FROM `MIME`, `Extension`, `Feature`, `Component` WHERE `MIME`.`Extension_` = `Extension`.`Extension` AND `Feature_` = `Feature` AND `Extension`.`Component_` = `Component` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)) OR (`Feature`.`Action` = NULL AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND ((`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4))))
                                                  Action ended 22:34:48: RegisterMIMEInfo. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteRegistryValues
                                                  Action 22:34:48: WriteRegistryValues. Writing system registry values
                                                  Action start 22:34:48: WriteRegistryValues.
                                                  WriteRegistryValues: Key: Writing system registry values, Name: , Value:
                                                  Action ended 22:34:48: WriteRegistryValues. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteIniValues
                                                  Action 22:34:48: WriteIniValues. Writing INI file values
                                                  Action start 22:34:48: WriteIniValues.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: IniFile
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`. `Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
                                                  Action ended 22:34:48: WriteIniValues. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: WriteEnvironmentStrings
                                                  Action 22:34:48: WriteEnvironmentStrings. Updating environment strings
                                                  Action start 22:34:48: WriteEnvironmentStrings.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: Environment
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
                                                  Action ended 22:34:48: WriteEnvironmentStrings. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterFonts
                                                  Action 22:34:48: RegisterFonts. Registering fonts
                                                  Action start 22:34:48: RegisterFonts.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: Font
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
                                                  Action ended 22:34:48: RegisterFonts. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: InstallODBC
                                                  Action 22:34:48: InstallODBC. Installing ODBC components
                                                  Action start 22:34:48: InstallODBC.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2711 2: ODBCDriverManager
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2711 2: ODBCDriverManager64
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCDriver
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`, `Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCTranslator
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCTranslator 4: SELECT `Translator`,`Component`.`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileNam e`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: ODBCDataSource
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
                                                  Action ended 22:34:48: InstallODBC. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: RegisterTypeLibraries
                                                  Action 22:34:48: RegisterTypeLibraries. Registering type libraries
                                                  Action start 22:34:48: RegisterTypeLibraries.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2205 2:  3: TypeLib
                                                  MSI (s) (F8:C8) [22:34:48:977]: Note: 1: 2228 2:  3: TypeLib 4: SELECT `LibID`, `TypeLib`.`Version`, `TypeLib`.`Language`, `TypeLib`.`Directory_`, `FileName`, `Component`.`Directory_`, `Component`.`Action`, `Component`.`Installed`, `BinaryType`, `Component`.`Component`, `Component`.`Attributes`, `Component`.`RuntimeFlags` FROM `TypeLib`, `Component`, `File` WHERE `TypeLib`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND ((`Component`.`Action`=1 OR `Component`.`Action`=2) OR (`Component`.`Action` = null AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2)))
                                                  Action ended 22:34:48: RegisterTypeLibraries. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:977]: Doing action: SelfRegModules
                                                  Action 22:34:48: SelfRegModules. Registering modules
                                                  Action start 22:34:48: SelfRegModules.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: SelfReg
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: SelfReg 4: Select `FileAction`.`FileName`,`FileAction`.`Directory_`,`FileAction`.`Action`, `FileAction`.`Component_`,`SelfReg`.`File_` From `SelfReg`, `FileAction` Where `SelfReg`.`File_` = `FileAction`.`File`  And (`FileAction`.`Action` = 1 OR `FileAction`.`Action` = 2)
                                                  Action ended 22:34:48: SelfRegModules. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterComPlus
                                                  Action 22:34:48: RegisterComPlus. Registering COM+ Applications and Components
                                                  Action start 22:34:48: RegisterComPlus.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: Complus
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: Complus 4: SELECT `ComponentId`,  `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed`  FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
                                                  Action ended 22:34:48: RegisterComPlus. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Doing action: InstallServices
                                                  Action 22:34:48: InstallServices. Installing new services
                                                  Action start 22:34:48: InstallServices.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Detected older ServiceInstall table schema
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: ServiceInstall
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: ServiceInstall 4: SELECT `ServiceInstall`,`Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrder Group`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Argume nts` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
                                                  Action ended 22:34:48: InstallServices. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Doing action: StartServices
                                                  Action 22:34:48: StartServices. Starting services
                                                  Action start 22:34:48: StartServices.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: ServiceControl
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
                                                  Action ended 22:34:48: StartServices. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterUser
                                                  Action 22:34:48: RegisterUser. Registering user
                                                  Action start 22:34:48: RegisterUser.
                                                  RegisterUser: Registering user
                                                  Action ended 22:34:48: RegisterUser. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Doing action: RegisterProduct
                                                  Action 22:34:48: RegisterProduct. Registering product
                                                  Action start 22:34:48: RegisterProduct.
                                                  RegisterProduct: Registering product
                                                  MSI (s) (F8:C8) [22:34:48:993]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
                                                  Action ended 22:34:48: RegisterProduct. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Doing action: PublishComponents
                                                  Action 22:34:48: PublishComponents. Publishing qualified components
                                                  Action start 22:34:48: PublishComponents.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2205 2:  3: PublishComponent
                                                  MSI (s) (F8:C8) [22:34:48:993]: Note: 1: 2228 2:  3: PublishComponent 4: SELECT `PublishComponent`.`ComponentId`, `PublishComponent`.`Qualifier`, `PublishComponent`.`AppData`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `PublishComponent`, `Component`, `Feature`  WHERE `PublishComponent`.`Component_` = `Component`.`Component` AND `PublishComponent`.`Feature_` = `Feature`.`Feature` AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
                                                  Action ended 22:34:48: PublishComponents. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:48:993]: Doing action: MsiPublishAssemblies
                                                  Action 22:34:49: MsiPublishAssemblies. Publishing assembly information
                                                  Action start 22:34:49: MsiPublishAssemblies.
                                                  MSI (s) (F8:C8) [22:34:49:008]: Note: 1: 2205 2:  3: MsiAssembly
                                                  MSI (s) (F8:C8) [22:34:49:008]: Note: 1: 2228 2:  3: MsiAssembly 4: SELECT null, null, `Component`.`Component`, `Feature`, `Component`.`ComponentId`, `Component`.`RuntimeFlags` FROM `MsiAssembly`, `Component`, `Feature`  WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Feature_` = `Feature`.`Feature` AND `MsiAssembly`.`File_Application` = null AND ((`Feature`.`Action` = 1 OR `Feature`.`Action` = 2)  OR (`Feature`.`Action` = 4 AND `Feature`.`Installed` = 0) OR (`Feature`.`Action` = 3 AND (`Feature`.`Installed` = 1 OR `Feature`.`Installed` = 2 OR `Feature`.`Installed` = 4)))
                                                  Action ended 22:34:49: MsiPublishAssemblies. Return value 0.
                                                  MSI (s) (F8:C8) [22:34:49:008]: Doing action: PublishFeatures
                                                  Action 22:34:49: PublishFeatures. Publishing product features
                                                  Action start 22:34:49: PublishFeatures.
                                                  PublishFeatures: Feature: Publishing product features
                                                  Action ended 22:34:49: PublishFeatures. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:49:008]: Doing action: PublishProduct
                                                  Action 22:34:49: PublishProduct. Publishing product information
                                                  Action start 22:34:49: PublishProduct.
                                                  1: Publishing product information
                                                  Action ended 22:34:49: PublishProduct. Return value 1.
                                                  MSI (s) (F8:C8) [22:34:49:024]: Skipping action: ScheduleReboot (condition is false)
                                                  MSI (s) (F8:C8) [22:34:49:024]: Doing action: InstallFinalize
                                                  Action 22:34:49: InstallFinalize.
                                                  Action start 22:34:49: InstallFinalize.
                                                  MSI (s) (F8:C8) [22:34:49:024]: Running Script: C:\Windows\Installer\MSI7D49.tmp
                                                  MSI (s) (F8:C8) [22:34:49:024]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
                                                  MSI (s) (F8:C8) [22:34:49:024]: Machine policy value 'DisableRollback' is 0
                                                  MSI (s) (F8:C8) [22:34:49:086]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
                                                  MSI (s) (F8:C8) [22:34:49:086]: Executing op: Header(Signature=1397708873,Version=500,Timestamp=1082963033,LangId=1033,Platform=589824, ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProductInfo(ProductKey={5C804EBB-475F-4555-A225-1D6573F158BD},ProductName=Adobe Flash Player 11 ActiveX (x64),PackageName=install_flash_player_11_active_x_64bit.msi,Language=1033,Version=184680 650,Assignment=1,ObsoleteArg=0,ProductIcon=ARPPRODUCTICON.exe,,PackageCode={56994055-C101- 488E-A9CB-CF207652B759},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymen tFlags=3)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: DialogInfo(Type=0,Argument=1033)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: DialogInfo(Type=1,Argument=Adobe Flash Player 11 ActiveX (x64))
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetBaseline(Baseline=0,)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetBaseline(Baseline=1,)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
                                                  Action 22:34:49: ProcessComponents. Updating component registration
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProgressTotal(Total=2,Type=1,ByteEquivalent=24000)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ComponentRegister(ComponentId={6EF6969F-DD13-4E22-AA5B-47F75A5D7633},KeyPath=C:\Windows\s ystem32\Macromed\Flash\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=1)
                                                  1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6EF6969F-DD13-4E22-AA5B-47F75A5D7633} 3: C:\Windows\system32\Macromed\Flash\
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ComponentRegister(ComponentId={6962420C-65FE-4F17-8BAF-8E36FC85EF6F},KeyPath=C:\Users\Adm in\AppData\Local\Temp\InstallAX64.exe,State=3,,Disk=1,SharedDllRefCount=1,BinaryType=1)
                                                  1: {5C804EBB-475F-4555-A225-1D6573F158BD} 2: {6962420C-65FE-4F17-8BAF-8E36FC85EF6F} 3: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
                                                  Action 22:34:49: RemoveODBC. Removing ODBC components
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ODBCDriverManager(,BinaryType=0)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ODBCDriverManager(,BinaryType=1)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
                                                  Action 22:34:49: CreateFolders. Creating folders
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: FolderCreate(Folder=C:\Windows\system32\Macromed\Flash\,Foreign=0,,)
                                                  CreateFolders: Folder: C:\Windows\system32\Macromed\Flash\
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1],  Directory: [9],  Size: [6])
                                                  Action 22:34:49: InstallFiles. Copying new files
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: ProgressTotal(Total=8767136,Type=0,ByteEquivalent=1)
                                                  MSI (s) (F8:C8) [22:34:49:102]: Executing op: SetTargetFolder(Folder=C:\Users\Admin\AppData\Local\Temp\)
                                                  MSI (s) (F8:C8) [22:34:49:118]: Executing op: SetSourceFolder(Folder=1\Temp\)
                                                  MSI (s) (F8:C8) [22:34:49:118]: Executing op: ChangeMedia(MediaVolumeLabel=DISK1,MediaPrompt=Please insert the disk: 1,MediaCabinet=Data1.cab,BytesPerTick=65536,CopierType=2,ModuleFileName=C:\Windows\Instal ler\869bf.msi,,,,,IsFirstPhysicalMedia=1)
                                                  MSI (s) (F8:C8) [22:34:49:118]: Executing op: FileCopy(SourceName=INSTAL~1.EXE|InstallAX64.exe,SourceCabKey=InstallAX64.exe,DestName=In stallAX64.exe,Attributes=16384,FileSize=8767136,PerTick=65536,,VerifyMedia=1,,,,,CheckCRC= 0,Version=11.2.202.228,Language=1033,InstallMode=58982400,,,,,,,)
                                                  MSI (s) (F8:C8) [22:34:49:118]: File: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe; To be installed; Won't patch; No existing file
                                                  MSI (s) (F8:C8) [22:34:49:118]: Source for file 'InstallAX64.exe' is compressed
                                                  InstallFiles: File: InstallAX64.exe,  Directory: C:\Users\Admin\AppData\Local\Temp\,  Size: 8767136
                                                  MSI (s) (F8:C8) [22:34:49:290]: Executing op: CacheSizeFlush(,)
                                                  MSI (s) (F8:C8) [22:34:49:290]: Executing op: ActionStart(Name=NewCustomAction1,,)
                                                  Action 22:34:49: NewCustomAction1.
                                                  MSI (s) (F8:C8) [22:34:49:290]: Executing op: CustomActionSchedule(Action=NewCustomAction1,ActionType=3090,Source=C:\Users\Admin\AppDat a\Local\Temp\InstallAX64.exe,Target=-install -msi,)
                                                  CustomAction NewCustomAction1 returned actual error code 1032 (note this may not be 100% accurate if translation happened inside sandbox)
                                                  MSI (s) (F8:C8) [22:34:57:066]: Note: 1: 1722 2: NewCustomAction1 3: C:\Users\Admin\AppData\Local\Temp\InstallAX64.exe 4: -install -msi
                                                  Info 2835.The control ErrorIcon was not found on dialog SetupError.
                                                  • 23. Re: trouble Flash 11
                                                    UnFlash Level 1
                                                    Now it worked!! Just reapplied the steps again. Thank you for the help!
                                                    • 24. Re: trouble Flash 11
                                                      Darkmoon2010 Level 1
                                                      i just used the link that carl provided to run the installer . My flash sucessfully installed and everything works fine now. Thank you everyone
