Last night I was using flashbuilder; then went I went to bed I started encoding with Media Encoder; when I woke up this morning my computer (winXP) was turned off; now flashbuilder will not start.
Here is a log generated from double-clicking the flashbuilder icon on my desktop:
!SESSION 2012-04-06 18:46:50.984 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2012-04-06 18:46:53.062
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4109)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)
at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)
at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)
at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)
at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)
at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java:159)
at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265)
at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86)
at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:798)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
any ideas?
thanks
Jon, thanks for responding ...
I 'fixed' it last night (2AM)
FIRST: I tried re-installing flashbuilder, but without uninstalling first ... did not work
SECOND: I used winxp add/remove programs to uninstall flashbuilder, then I re-installed flashbuilder ... worked
I should note that my eclipse was working all the while. I know that they are separate softwares, but nevertheless I figured that I would mention it.
Also, because my flashbuilder is basically out-of-the-box new, un-installing was acceptabl
...Copy link to clipboard
Check post #7 here:
http://forums.adobe.com/message/4044057#4044057
Also, this looks like a generic Eclipse bug, not only Flash Builder. So googling
eclipse "no more handles"
may yield more relevant results.
Also, because my flashbuilder is basically out-of-the-box new, un-installing was acceptable. But for someone who has added plugins, or done some customized configurations to their flashbuilder, un-installing would NOT be a good idea.
Unless FB has been installed into an existing Eclipse installation they are seperate installs. So one Eclipse may be working, but FB's may not. A reinstall often fixes the problem, but is rather a sledgehammer approach. Often simply rebuilding a workspace or removing temporary files will help.
Anyway, glad you fixed it.
