13 Replies Latest reply on Apr 10, 2012 12:03 PM by acresofgreen
    Which tools or tutorials do you recommend for this?
    pat agonia Level 1
      Complete novice & on CS5.
      Dangerous combination!
      I need to add some 20% extra sky on top of an image to balance the shot.
      Nothing in the sky as such but different tonal range as you go noth as it should get darker, but I am having problems blending the copied sky above and in some way blending it well.
      I had considered a grad filter, though, again, I'd need to watch a tutorial 1st!
      I did say I was a novice.
      I copied the sky up by adding 20% move canvass, clicking on the area which became a boxed in with marching ants with the Magic Wand thingy and copying the sky via the Clone Stamp tool.
      It did not look right at all.
      Any pointers would be greatly appreciated.
        • 1. Re: Which tools or tutorials do you recommend for this?
          Jeff Arola Adobe Community Professional
          You might be able to get away with stretching the sky, adding a gradient overlay adjustment layer with foreground to transparent
          with reverse, some cloning and adding some noise with the filter>add noise (gaussian-monochromatic) on a new layer set to softlight and filled with a neutral background color.
          (set your toolbox colors to default by pressing D before add the gradient layer)
          • 2. Re: Which tools or tutorials do you recommend for this?
            pat agonia Level 1
            Thanks.
            I'll unpick this and see how I get on.
            Far superior to my efforts!
            I've another question that I'll post up shortly as the initial results of taking someone out from the background.
            Cheers and have a good Easter holiday.
            • 3. Re: Which tools or tutorials do you recommend for this?
              pat agonia Level 1
              "get away with stretching the sky"
              I've no idea what to do?
              How can you stretch the sky?
              • 5. Re: Which tools or tutorials do you recommend for this?
                Trevor.Dennis Adobe Community Professional
                I don't know, but would guess at:
                • Extend canvas vertically
                • Use the rectangle Marquee tool to select that bit of sky above the oblisque
                • Feather the selection (how much depends on image pixel size)
                • Use Free Transform to stretch the selection to fit the expanded canvas.
                • Personally I would select the oblisque and copy it to a new layer (Ctrl Cmd j)
                • Create a new layer between the background and oblisque layers
                • sample foreground colour from near the horizon, and background colour from the top of the sky
                • Run a gradient down the image in the blank layer.
                • Add a layer mask and mask out the bottom section of that layer.
                • 6. Re: Which tools or tutorials do you recommend for this?
                  pat agonia Level 1
                  Thanks.
                  It's indicative of my ignorance that I have not the first idea what each of these steps means!
                  "Feather" - what with?
                  "sample the foreground" and from two places, with what and how?
                  I'll have a look in Google and Youtube but I'm once again losing the will to carry on with this work.
                  Thanks, but I think I'd better get someone other than myself to do these tasks (if Google can't shed some light on fathering and such like) as there are several of these images and I have not the faintest idea of what any of these terms or steps mean!
                  How I wish I did not have to struggle and fail so monumentally with digital work flow. It's the sole reason I am selling all my kit and getting the Hell-out of photography, once I had 5 free lancers working for me taking pictures, now, I have not the first idea what to do in Photoshop and fail as soon as an image needs work doing to it. I can't even run some of the functions of CS5 I'm now told as I have only 32 bit processing and 4RAM. Why did I waste such a lot of money I wonder?!
                  • 7. Re: Which tools or tutorials do you recommend for this?
                    pat agonia Level 1
                    Hi.
                    Content Aware doesn't work in Vista's 32bit 4MB RAM enviroment I'm just been told.
                    My  PC says there's not enough RAM to run any Content Aware tasks.
                    • 8. Re: Which tools or tutorials do you recommend for this?
                      OK Pat.  We'll do it in easy stages.
                      • select the Lasso tool and draw round the oblesque.  (Hold down the Alt key while clicking on each corner in turn)
                      • Ctrl J will make a copy of the oblesque on a new layer.
                      • Hold down the Ctrl key while you click on 'make a new layer' at the bottom of the layers palette.  (this should place that layer between the background, and copy of the oblesque layers.
                      • Select the background layer, and the paint brush (b)
                      • Alt click on the sky near the bottom of the image (close to the horizon.
                      • swap fore ground background colour (x) and Alt click on the sky at the top of the image.
                      Your foreground and background colours should respectively match the sky at its lightest and darkest tones.
                      • Select the Gradient tool (behind the Paint bucket) and select the empty layer between the background and copied oblisque layers.
                      • Click somewhere near the top of the image, and hold down the Shift key while clicking again near the horizon.  (If the gradient is the wrong way round, undo (Ctrl z) and do it again but start at the bottom this time.)
                      • With the gradient layer still sellected, click on Add Layer mask icon at the bottom of the layers palette.
                      • Paint with black in the layer mask to hide the gradient where it covers the forground.  Do this with a large soft brush so you get a nice feathered interface where your gradient intersects with the background layer.
                      I hope this is OK.  A few of those steps could be improved upon, but I tried to make it as straight forward as possible.
                      • 9. Re: Which tools or tutorials do you recommend for this?
                        acresofgreen Level 4
                        Pat, don't lose heart!  Anyone starting out with Photoshop would have the same issues and I can clearly remember being in the same situation.  There is a sharp learning curve (so many functions, so many technical terms to describe the tools and how they work) but I guarantee that if you stick with it you won't regret it.  Trevor has done a great job detailing the steps, but if some are still challenging, just report the steps you are having problems with and screenshots can be provided.
                        I find it hard to believe that Content-aware fill won't work on a Windows Vista 32 bit system, because I don't see any mention of that in the System Requirements.
                        http://www.adobe.com/products/photoshop/tech-specs.html
                        I assume you have 4 GB RAM and not 4 MB RAM as you state in post #7.  I have a 4 GB RAM Windows 7 64 bit system and everything runs just fine.  Maybe someone who knows more about the system requirements can chime in and comment.
                        • 10. Re: Which tools or tutorials do you recommend for this?
                          pat agonia Level 1
                          Hi there.
                          Thanks - just come across your email as it had gone straight to Spam!
                          I'll see how I get on.
                          Cheers!
                          • 11. Re: Which tools or tutorials do you recommend for this?
                            pat agonia Level 1
                            Hi there.
                            Thanks.
                            I found your eamil in the Spam box - so apologies for not getting back sooner.
                            The local pc shop said it needs to be a 64bit enviroment for this stuff to run and my 4GB 32 bit systems x2 won't entertain the Content Aware tool, so I assume he's correct. That's 2x tools thus far that need 64bit that I've encountered.
                            Tim
                            • 12. Re: Which tools or tutorials do you recommend for this?
                              pat agonia Level 1
                              Thanks for the info on the forum.
                              It seems I've had a number of respondents all of whose emails went straight to Spam.
                              Just as well I don't trust the PC and thus check the Spam folder weekly.
                              I'll see how I get on as yesterday, Monday, such was the situation that I
                              pretty much lost the will to do anything - a waste of a day, actually a
                              waste of the whole bank holiday 'cept for the postings on the web site and watching hours of Photoshop vid's on Youtube. I now know more than I did last week but am probably more confused!
                              I'll follow the advice given in more details and see how I get on.
                              Tim
                              • 13. Re: Which tools or tutorials do you recommend for this?
                                I still don't think you need a 64 bit environment for content aware fill if you have 4 GB RAM.
                                Take a look at this Adobe article which sounds like the error you are getting.  There are some troubleshooting steps.   http://helpx.adobe.com/photoshop/kb/error-enough-memory-content-aware.html
                                Good luck!
