11 Replies Latest reply on Apr 6, 2012 12:53 PM by Jonathan Fortis
    Query was empty - just added if statements?
    Jonathan Fortis Level 1
      i have added two if stat
        • 1. Re: Query was empty - just added if statements?
          sorry posted by mistake..
          ok i added two if statements to check if a password is correct
          if($POST['password'] == $_POST['password2'])
                    if($_POST['email'] == $_POST['email2'])
          and when i add the above it return a query is empty.
          the full code is below
          $editFormAction = $_SERVER['PHP_SELF'];
          if (isset($_SERVER['QUERY_STRING'])) {
            $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
          if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form4"))
            $insertSQL = sprintf("INSERT INTO think_signup (FirstName, Surname, password, email, ContactMethod, TeleNumber, SalaryReq, PositionReq, skills_offered, cv, location) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
                                 GetSQLValueString($_POST['FirstName'], "text"),
                                 GetSQLValueString($_POST['Surname'], "text"),
                                 GetSQLValueString($_POST['password'], "text"),
                                 GetSQLValueString($_POST['email'], "text"),
                                 GetSQLValueString($_POST['ContactMethod'], "text"),
                                 GetSQLValueString($_POST['TeleNumber'], "text"),
                                 GetSQLValueString($_POST['SalaryReq'], "text"),
                                 GetSQLValueString($_POST['PositionReq'], "text"),
                                 GetSQLValueString($_POST['skills_offered'], "text"),
                                 GetSQLValueString($_POST['cv'], "text"),
                                 GetSQLValueString($_POST['location'], "text"));
          and the inputs are here
                        <td nowrap="nowrap" align="right">Password:</td>
                        <td><input type="text" name="password" value="" size="30" /></td>
                      </tr>
                      <tr valign="baseline">
                        <td nowrap="nowrap" align="right">Confirm Password</td>
                        <td><input type="text" name="password2" value="" size="30" /></td>
                      </tr>
                        <td nowrap="nowrap" align="right">Email:</td>
                        <td><input type="text" name="email" value="" size="30" /></td>
                      </tr>
                        <td nowrap="nowrap" align="right">Confirm Email</td>
                        <td><input type="text" name="email2" value="" size="30" /></td>
          • 2. Re: Query was empty - just added if statements?
            bregent Most Valuable Participant
            Typo in your POST variable.
            • 3. Re: Query was empty - just added if statements?
              tried this
              if($POST['password'] == $_POST['password2'] && $POST['email'] == $_POST['email2'])
              but returned the same query is empty
              • 4. Re: Query was empty - just added if statements?
                You still have the same typo. There is no $POST variable assigned on your page. You need to use $_POST.
                This is why I hate loosely typed languages.
                • 5. Re: Query was empty - just added if statements?
                            if($_POST['password'] == $_POST['password2'] && $_POST['email'] == $_POST['email2'])
                  still same error?
                  • 6. Re: Query was empty - just added if statements?
                    >still same error?
                    You're getting an error?
                    • 8. Re: Query was empty - just added if statements?
                      OK, please post the entire page code. You're probably just missing curly braces or a line terminator.
                      • 9. Re: Query was empty - just added if statements?
                        <?php
                        if (!function_exists("GetSQLValueString")) {
                        function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
                          if (PHP_VERSION < 6) {
                            $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
                          $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
                          switch ($theType) {
                            case "text":
                              $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
                              break;
                            case "long":
                            case "int":
                              $theValue = ($theValue != "") ? intval($theValue) : "NULL";
                              break;
                            case "double":
                              $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
                              break;
                            case "date":
                              break;
                            case "defined":
                              $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
                              break;
                          return $theValue;
                          $insertSQL = sprintf("INSERT INTO think_signup (FirstName, Surname, password, email, ContactMethod, TeleNumber, SalaryReq, PositionReq, skills_offered, cv, needCV, otherComments, location) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
        GetSQLValueString(isset($_POST['needCV']) ? "true" : "", "defined","'Y'","'N'"),
        GetSQLValueString($_POST['otherComments'], "text"),
                          mysql_select_db($database_hostprop, $hostprop);
                          $Result1 = mysql_query($insertSQL, $hostprop) or die(mysql_error());
                          $insertGoTo = "signup-complete.php";
                            $insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
                            $insertGoTo .= $_SERVER['QUERY_STRING'];
                          header(sprintf("Location: %s", $insertGoTo));
                        $query_rsReg = "SELECT * FROM think_signup";
                        $rsReg = mysql_query($query_rsReg, $hostprop) or die(mysql_error());
                        $row_rsReg = mysql_fetch_assoc($rsReg);
                        $totalRows_rsReg = mysql_num_rows($rsReg);
                                <form action="<?php echo $editFormAction; ?>" method="post" name="form4" id="form4">
                                  <table width="500" align="center">
                                      <td nowrap="nowrap" align="left"><p>FirstName:
                                        </p>
                                        <p>
                                          <input type="text" name="FirstName" value="" size="30" />
                                      </p></td>
                                      <td><p>
                                        <input type="text" name="cv" value="" size="32" />
                                      </p>
                                      <p>                Cv </p></td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>Surname
                                        </p>
                                        <p>
                                          <input type="text" name="Surname" value="" size="30" />
                                      </p></td>
                                      <td><p>
                                        <input type="checkbox" name="needCV"/>
                                      </p>
                                      <p>need cv </p></td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>Password
                                        </p>
                                        <p>
                                      </p></td>
                                      <td rowspan="2">
                                        <p>
                                          <textarea name="otherComments"cols="20" rows="5"></textarea>
                                        </p>
                                        <p>other comments</p>
                                      <p>  </p></td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>Confirm Password
                                        </p>
                                        <p>
                                      </p></td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>Email
                                        </p>
                                        <p>
                                      </p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>Confirm Email
                                        </p>
                                        <p>
                                      </p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>ContactMethod
                                        </p>
                                        <p>
                                          <input type="text" name="ContactMethod" value="" size="30" />
                                      :</p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>TeleNumber
                                        </p>
                                        <p>
                                          <input type="text" name="TeleNumber" value="" size="30" />
                                      :</p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>SalaryReq
                                        </p>
                                        <p>
                                          <input type="text" name="SalaryReq" value="" size="30" />
                                      :</p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>PositionReq
                                        </p>
                                        <p>
                                          <input type="text" name="PositionReq" value="" size="32" />
                                      :</p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p>Skills_offered
                                        </p>
                                        <p>
                                          <input type="text" name="skills_offered" value="" size="32" />
                                      :</p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"><p> </p>
                                        <p>
                                    :</p></td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left">Location
                                        <input type="text" name="location" value="" size="32" />
                                      :</td>
                                      <td> </td>
                                    </tr>
                                      <td nowrap="nowrap" align="left"> </td>
                                      <td><input type="submit" value="Insert record" /></td>
                                    </tr>
                                  </table>
                                  <input type="hidden" name="MM_insert" value="form4" />
                                </form>
                        • 10. Re: Query was empty - just added if statements?
                          Your new IF statement is missing curly braces. Add them and see what happens.
                          • 11. Re: Query was empty - just added if statements?
                            its working now,. thanks for your help
