8 Replies Latest reply: Jul 23, 2012 7:27 AM by engravedbeauty2578 RSS
    Changing active state of spry menu
    engravedbeauty2578
      So, I'm a newbie in the world of development (I'm a designer, not a coder) and a student who has a web project due in 2 days. I can't figure out how to get the active page's menu button to be a different color than the rest of the menu bar. I've successfully changed the rollover states and background colors, but the ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus doesn't change the active state like I thought I would. Please help!
        • 1. Re: Changing active state of spry menu
          Nancy O. ACP/MVP
          Persistent Page Indicator on Menus
          http://alt-web.com/Articles/Persistent-Page-Indicator.shtml
          ()__()
          (")_(")
          Nancy O.
          Alt-Web Design & Publishing
          Web | Graphics | Print | Media  Specialists
          http://alt-web.com/
          • 2. Re: Changing active state of spry menu
            BenPleysier CommunityModerator
            Nancy'e solution is a really good and solid way to show the current menu item and if I did not have another way of doing the same, I would most certainly use Nancy's solution.
            So, here is the solution that I use.
            the JS
            <script src="SpryAssets/SpryDOMUtils.js"></script>
            <script>
            function InitPage(){
            Spry.$$('#MenuBar1 li').forEach(function(node){
                var a=node.getElementsByTagName("a")[0]; // finds all a elements inside the li, but we only want the first so [0]
                if(a.href == window.location){
                    Spry.Utils.addClassName(node,"activeMenuItem");
            Spry.Utils.addLoadListener(InitPage);
            </script>
            and the CSS
            <style>
            .activeMenuItem a {
                background: yellow !important;
                color: red !important;
                text-decoration: underline;
            </style>
            The difference between the two solutions is in the way the the current menu item is identified. In Nancy's solution each body and each menu item tag needs to have a class attached to it. In my solution the identification is made by comparing the URL of the page with the menu item link, thus no extra markup is needed.
            Both of the above solutions assume that you are using a template system such as DWT or SSI.
            If you are not using a template system and are repeating the menu structure on each page, you are better off ignoring both of the above and merely adding the activeMenuItem class to the corresponding menu item as in
            <li class="activeMenuItem"><a href="about.html">ABOUT US</a></li>
            Gramps
            • 3. Re: Changing active state of spry menu
              PKTstudio
              I have just come upon the SAME ISSUE; also a designer and not a coder. did you ever solve this one? I was doing the exact same thing as you were, per instructions on the help.adobe.com site ...  Does not work.(!)
              • 4. Re: Changing active state of spry menu
                Nancy O. ACP/MVP
                What doesn't work?  What have you tried?  Please post a link to your problem page and explain what you expect to happen that isn't.
                Nancy O.
                • 5. Re: Changing active state of spry menu
                  PKTstudio Community Member
                  I was referring to the original post; sorry i'm kind of a novice at this forum.  I have my spry menu on the template, from which i've created all the other pages on the website.
                  Per the original post, engravedbeauty2578 posted:
                  "..I can't figure out how to get the active page's menu button to be a different color than the rest of the menu bar. I've successfully changed the rollover states and background colors, but the ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus doesn't change the active state like I thought I would...."
                  I also have blue type in the menu bar when the pages first load. I have successfully changed the "hover" color to red, but once the new page becomes active, its tab color reverts back to blue. So i specified the "a:focus" color to red but nothing happened.  I was assuming that "focus" referred to the active page's tab.  I probably assumed wrong, right?
                  • 6. Re: Changing active state of spry menu
                    Nancy O. ACP/MVP
                    a:hover = on mouse over.
                    a:active = on click.
                    a:focus = when tab key is on the menu item.
                    To create a "you are here" state on your site-wide menus, see persistent menu highlighting:
                    Nancy O.
                    http://alt-web.com/
                    http://twitter.com/altweb
                    http://alt-web.blogspot.com/
                    • 7. Re: Changing active state of spry menu
                      Nancy, thanks for the link re: persistent-page-indicator; i've read it and headed over to the Dreamweaver help PDF on "editable tag attributes in a template".  It will take me some time but I think i should be able to solve it. Appreciate your help!
                      • 8. Re: Changing active state of spry menu
                        engravedbeauty2578 Community Member
                        PKTstudio,
                        Sorry this is late, but here's what I did: http://www.dreamweaverresources.com/tutorials/spry-currentpage-indicator/
                        super easy. I put the #current {...} style within my normall .css sheet though, not the spry menu. Also, make sure to make a css rule using the #current name before you start, otherwise it won't work.
