1 Reply Latest reply on Apr 8, 2012 7:22 AM by Frustrated in AZ
    Reading ebooks from an external hard drive with ADE
    kayseekaysee Level 1
      I have ADE installed on a netbook [an Acer with a relatively tiny hard drive] and I have found that since I started downloading my ebooks to it the performance on the computer [not surprisingly] has become rather slow.  The obvious solution to me would be to transfer all my current ebooks and download all future acquisitions to a 500 GB external hard drive.  However, I haven't been able to figure out 1) whether this is even possible or 2) how to go about it if it is indeed possible.  Given some of the [IMO ridiculous] restrictions placed on ADE readable ebooks, and some of the horror stories I've seen online, I have been reluctant to experiment, lest my currently perfectly accessible ebooks somehow become permanently off-limits and thereby unreadable.
      Is there some solution to my problem?  I have considered:
      - simple transfer of my current ebook file folder to the relevant external hard drive [ but have been unable to figure out how to "point" ADE to that location so the ebooks can be read]
      - transfer of both ADE and all ebooks to the relevant external hard drive [but am not sure if ADE will work if it's not resident on the main hard drive; additionally can see problems with my authorization if I just pick up everything via cut / past - would it screw up my authorization?]
      I'd really like a way to free up the GBs of hard drive space which I used to be able to use for cache purposes but which are now clogged up by these ADE-required files.
      TIA for any help.
        • 1. Re: Reading ebooks from an external hard drive with ADE
          Level 4
          My 'handle' is a result of similar "frustration".  I also happen to use an
          Acer laptop built in the mid-'90's.
          ADE was built in the 1990's, with a design approach that is a bit obsolete
          today.  So, the product has some limitations.  First, and probably worst,
          is that it makes you use your C:\ drive for critical files and the My
          Digital Editions folder, which manages the ebooks.
          You can have ebooks located elsewhere.  Just download the ebook to
          a location, then open ADE and use the 'Add Item To Library' function.  That
          process allows you to tell ADE where the ebook is located.
          [BTW: my local computer guru was able to upgrade the hard drive on my Acer
          to 100Gb.  That solved many, many problems.]
