0 Replies Latest reply on Apr 9, 2012 7:23 AM by saariko
    help downgrade a php script generated by FB back to the old Mysql way
    saariko Level 1
      hey all
      i am a Flex developer who has written server side stuff with php scripts that were auto-generated by Flash Builder. These scripts use the Mysqli extention, which is not avilable on my shared hosting server. These scripts implement simple CRUD functions to a MySql database. Anyone who has used the data wizard will recognize these scripts.
      Just before i pay more bucks and move to a VPS server in order to enable Mysqli, is there anyone out there who can help me translate this script BACK to the old mysql way?
      much appriciated, Saar
      <?php
      class ClientService {
          var $username = "******";
          var $password = "******";
          var $server = "localhost";
          var $port = "3306";
          var $databasename = "rtdbcbx_saar";
          var $tablename = "clients";
          var $connection;
           * The constructor initializes the connection to database. Everytime a request is
           * received by Zend AMF, an instance of the service class is created and then the
           * requested method is invoked.
          public function __construct() {
              $this->connection = mysqli_connect(
                                      $this->server,
                                      $this->username,
                                      $this->password,
                                      $this->databasename,
                                      $this->port
              $this->throwExceptionOnError($this->connection);
           * Returns all the rows from the table.
           * Add authroization or any logical checks for secure access to your data
           * @return array
          public function getAllClient() {
              $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename");
              $this->throwExceptionOnError();
              mysqli_stmt_execute($stmt);
              $rows = array();
              mysqli_stmt_bind_result($stmt, $row->ClientID, $row->First, $row->Last, $row->Phone, $row->Email, $row->Chain, $row->Branch, $row->Kiosk, $row->SubmitDate);
              while (mysqli_stmt_fetch($stmt)) {
                $row->SubmitDate = new DateTime($row->SubmitDate);
                $rows[] = $row;
                $row = new stdClass();
              mysqli_stmt_free_result($stmt);
              mysqli_close($this->connection);
              return $rows;
           * Returns the item corresponding to the value specified for the primary key.
           * Add authorization or any logical checks for secure access to your data
           * @return stdClass
          public function getClientByID($itemID) {
              $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename where ClientID=?");
              mysqli_stmt_bind_param($stmt, 'i', $itemID);
              if(mysqli_stmt_fetch($stmt)) {
                return $row;
              } else {
                return null;
           * @return stdClass
          public function createClient($item) {
              $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (First, Last, Phone, Email, Chain, Branch, Kiosk, SubmitDate) VALUES (?, ?, ?, ?, ?, ?, ?, ?)");
              mysqli_stmt_bind_param($stmt, 'ssssssss', $item->First, $item->Last, $item->Phone, $item->Email, $item->Chain, $item->Branch, $item->Kiosk, $item->SubmitDate->toString('YYYY-MM-dd HH:mm:ss'));
              $autoid = mysqli_stmt_insert_id($stmt);
              return $autoid;
           * Updates the passed item in the table.
           * @param stdClass $item
           * @return void
          public function updateClient($item) {
              $stmt = mysqli_prepare($this->connection, "UPDATE $this->tablename SET First=?, Last=?, Phone=?, Email=?, Chain=?, Branch=?, Kiosk=?, SubmitDate=? WHERE ClientID=?");
              mysqli_stmt_bind_param($stmt, 'ssssssssi', $item->First, $item->Last, $item->Phone, $item->Email, $item->Chain, $item->Branch, $item->Kiosk, $item->SubmitDate->toString('YYYY-MM-dd HH:mm:ss'), $item->ClientID);
           * Deletes the item corresponding to the passed primary key value from
           * the table.
           * @return void
          public function deleteClient($itemID) {
              $stmt = mysqli_prepare($this->connection, "DELETE FROM $this->tablename WHERE ClientID = ?");
           * Returns the number of rows in the table.
          public function count() {
              $stmt = mysqli_prepare($this->connection, "SELECT COUNT(*) AS COUNT FROM $this->tablename");
              mysqli_stmt_bind_result($stmt, $rec_count);
              mysqli_stmt_fetch($stmt);
              return $rec_count;
           * Returns $numItems rows starting from the $startIndex row from the
           * table.
           * @return array
          public function getClient_paged($startIndex, $numItems) {
              $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename LIMIT ?, ?");
              mysqli_stmt_bind_param($stmt, 'ii', $startIndex, $numItems);
              $rows = array();
                $rows[] = $row;
              return $rows;
           * Utility function to throw an exception if an error occurs
           * while running a mysql command.
          private function throwExceptionOnError($link = null) {
              if($link == null) {
                  $link = $this->connection;
              if(mysqli_error($link)) {
                  $msg = mysqli_errno($link) . ": " . mysqli_error($link);
                  throw new Exception('MySQL Error - '. $msg);
