11 Replies Latest reply on May 15, 2017 4:34 PM by Mick835
    How do I hide rejected images while showing all others?
    macdls Level 1
      I want to set the filter to display only unrated and rated images so that rejected images disappear from the view as soon as I type "X" and move on to the next image.  Then I want go through my rejects to make sure they are all duds before deleting them permanently, and i don't want to see them again until I do that.  I can display one star or greater, but I can't figure out how to display unrated or greater  Surely this is user error and not poorly designed filtering.
      DLS
        • 1. Re: How do I hide rejected images while showing all others?
          Jim Wilde Adobe Community Professional
          I think you're getting confused between flags and ratings. 'Reject' is a flag, so when you have your images all together in the grid, set the Flag attributes for 'Flagged' and 'Unflagged' (click on the first two flag icons)....this will leave all the images in the grid, but as soon as you hit 'X' to reject one it will disappear from the grid as it no longer meets the filter criteria.
          Then change the Flag attribute to Rejected only, to see the rejects. The flag status choices are toggle on/off, so you click on all three....the first two turn 'flagged' and 'unflagged' off, and the last one will turn 'Rejected' on.
          • 2. Re: How do I hide rejected images while showing all others?
            Bob Gates Level 2
            Using the filter bar right above the filmstrip at the bottom, you can choose to show any combination of rated, unrated, rejected.  In your case, you choose rated and unrated (click on each until it is highlighted).  Then do X as you suggest.  Then you unclick rated and unrated, and only click/select rejected.  As soon as you change any one of them to rated or unrated it will disappear from your filtered selection of rejects. Then you can select all the rejects and delete them.
            If this filtering option does not show up on that bar, start by clicking next to "Custom Filter" and choose ratings to show up.
            • 3. Re: How do I hide rejected images while showing all others?
              dorin_nicolaescu Level 5
              Rating equal to zero ang flag is unflagged.
              • 5. Re: How do I hide rejected images while showing all others?
                JohnnyPhotoshop Level 1
                This is a very confusing piece of UI. Not only does the "rejected" flag look like a flag with a plus sign on it rather than an "x", but the flags are all grey. Whether they are less gray "active" or more gray "inactive" can only be discerned by repeatedly clicking them on and off and watching for the change. In addition, there is nothing about the button block to make you think that more than one can be active at the same time. The subtlety of the active vs. inactive greys compounds the confusion.
                • 6. Re: How do I hide rejected images while showing all others?
                  mark4pros Level 1
                  I agree with JohnnyPhotoshop. Why is there not an option to hide rejected images.  SIMPLE HIDE THE REJECTS. Should not require ten people to answer this question.
                  "Using the filter bar right above the filmstrip at the bottom, you can choose to show any combination of rated, unrated, rejected.  In your case, you choose rated and unrated (click on each until it is highlighted).  Then do X as you suggest.  Then you unclick rated and unrated, and only click/select rejected.  As soon as you change any one of them to rated or unrated it will disappear from your filtered selection of rejects. Then you can select all the rejects and delete them.
                  If this filtering option does not show up on that bar, start by clicking next to "Custom Filter" and choose ratings to show up."
                  Really? how about "hide rejects"  two words one mouse click. no BS.    I know that some ppl will say oh there's a learning curve. That is not an excuse to me for this kind of complication. Filter "hide rejects"  is not an option. please refer to the ten step process above. Grrr
                  • 7. Re: How do I hide rejected images while showing all others?
                    mark4pros Level 1
                    OK i get it. basically it seems to work like this. all images are imported as un-flagged, the default. which is the middle flag on the filter bar. Then you can select P for pick the flag on the left, X for rejected the flag to the right. Important  clicking the flag icon toggles on or off and not between P or X. Hovering over the flag with the cursor help says filter based on flag status. which means nothing. You have to figure out that it's a toggle and figure out what the icons mean because there are no clues.  Which brings me back to the original question, why is there not a preset for hiding the rejects?
                    • 8. Re: How do I hide rejected images while showing all others?
                      NicHamilton Level 3
                      Who knows...but it's very easy to make one, that's what I did and called it "All not rejected" so it was top of the list.
                      1. Click the "Flagged" and  "Unflagged" flags (ie: the left and centre one).
                      2. "Flagged and Unflagged" will show briefly on the screen.
                      3. Click on the Preset arrows (to the far right of the flag icons)
                      4. Select "Save current settings as new Pre-set"
                      5. Give the Pre-set a memorable and informative name.
                      • 9. Re: How do I hide rejected images while showing all others?
                        ianm53814505 Level 1
                        I think this problem is due to the confusing references to flags.
                        In my Lightroom library I reject the poor photos and I leave the remaining good photos as they are (i.e. I don't flag them or rate them). This is what happens with the various filters...
                        • Flagged Only : No photos are displayed. This suggests that the Rejected setting is not actually a flag.
                        • Flagged and Unflagged Photos : Displays all photos except those that were rejected.
                        • Unflagged Photos Only :  Displays all photos except those that were rejected. This is confusing since it suggests that the Rejected setting is a flag.
                        • Rejected Photos Only : Displays only REJECTED photos
                        • Unflagged and Rejected Photos : Displays ALL photos.
                        • Any Flag Status : Displays ALL Photos.
                        I created 3 custom filters based on these settings...
                        .ALL Photos (i.e. Any Flag Status)
                        .GOOD Photos (i.e. Flagged and Unflagged Photos)
                        .REJECTED Photos (i.e. Rejected Photos Only)
                        I put a dot before the filter name so that they appear at the top of the filter list.
                        Cheers
                        Ian
                        • 10. Re: How do I hide rejected images while showing all others?
                          dnakakihara Level 1
                          Just right-click one of the flags and choose Rejected Photos Only from the menu. Done.
                          If you'd like to understand the Flag filter more, I wrote a post about it on my blog. It's simple once you understand how they work, but honestly we shouldn't have to try so hard.
                          http://www.seriouslytrivial.com/2016/09/02/making-sense-of-lightroom-flag-filters-and-how- to-show-just-non-rejected-phot…
                          • 11. Re: How do I hide rejected images while showing all others?
                            Mick835 Level 1
                            What if your rated/unrated tool is missing?
