8 Replies Latest reply on Feb 8, 2013 8:41 AM by marsh1979
    CQ 5.4 - "Server not ready, browser not launched" Error
    MatheusOliveira
      Greetings,
         Sometimes when I try to startup my CQ 5.4 instance, after a few seconds "waiting for server startup...", I got the message "Server not ready, browser not lauched".
      The most annoying thing is that if I keep trying, eventually it works.
        Following the stderr.log contents, if anyone can help me I thanks a lot. :
      Loading instance properties:/quickstart/quickstart-cq5.properties
      Not forking JVM as -nofork option is set
      Using 64bit VM settings
      The JVM reports a heap size of 494 MB, meets our expectation of 384 MB +/- 20
      CHILD process: will shutdown if '250' (+ line end) is received on standard input
      The JVM MBean:Perm Gen reports a maximum size of 128 MB, meets our expectation of 128 MB +/- 20
      Setting system properties from filename 'file:/C:/CQ5/CQ%205.4/cq5-5.4.0.20110218-generic.jar'
      System property 'sling.jcrinstall.folder.name.regexp' set to '.*/(install|config)(.author)?$' from filename cq5-5.4.0.20110218-generic.jar
      System property 'sling.run.modes' set to 'author' from filename cq5-5.4.0.20110218-generic.jar
      System property 'server.ready.url.1' set to '900/120/0 http://localhost:$PORT$/login.html .*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*' from filename cq5-5.4.0.20110218-generic.jar
      System property 'server.ready.url.2' set to '300/40/0 http://localhost:$PORT$/libs/cq/core/content/systemready.txt .*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*' from filename cq5-5.4.0.20110218-generic.jar
      System property 'com.day.crx.launchpad.filters.CRXLaunchpadLicenseFilter.waitForContentPath' set to '/bin/login.html?src=CRXLaunchpadLicenseFilter' from filename cq5-5.4.0.20110218-generic.jar
      Verbose option not active, closing stdin and redirecting stdout and stderr
      Redirecting stdout to C:\CQ5\CQ 5.4\crx-quickstart\logs\stdout.log
      Redirecting stderr to C:\CQ5\CQ 5.4\crx-quickstart\logs\stderr.log
      Exception in shutdown polling thread, giving up: java.io.IOException: Stream closed
      Shutdown polling thread ends
      Quickstart startup at Tue Apr 10 14:03:39 BRT 2012
      crx.quickstart.build.number=5.4.0.20110218
      DiskSpaceUtil.getMaxOpenFiles() reports a maximum of 2147483647 open files, meets our requirement (8192)
      PortSelector: Selecting server port from supplied list: 4502,8080,8081,8082,8083,8084,8085,8888,9362,random
      PortSelector: Trying port 4502
      PortSelector: Successfully bound to port 4502, will use it
      PortSelector: Selected port 4502
      Build number not changed, software update not needed
      PreserveExistingFiles: no files to restore from pre-upgrade backup
      System property crx.quickstart.info.jar.name set to file:/C:/CQ5/CQ%205.4/cq5-5.4.0.20110218-generic.jar
      System property crx.quickstart.info.work.dir set to C:\CQ5\CQ 5.4\crx-quickstart
      System property crx.quickstart.info.server.dir set to C:\CQ5\CQ 5.4\crx-quickstart\server
      System property crx.quickstart.info.server.port set to 4502
      C:\CQ5\CQ 5.4\crx-quickstart\server\etc\server.xml exists, assuming CRX is already setup
      Processing updates...
      Updates source: C:\CQ5\CQ 5.4\crx-quickstart\repository\patches\new
      RunJarOnce INFO: RunJarOnce created, srcFolder=C:\CQ5\CQ 5.4\crx-quickstart\repository\patches\new, doneFolder=C:\CQ5\CQ 5.4\crx-quickstart\updates\history
      No update jars executed
      Done processing 0 updates
      sling.repository.url not set, empty in instance properties
      Starting CQSE on port 4502, interface=null...
      Work dir: C:\CQ5\CQ 5.4\crx-quickstart
      CQSE arguments: [-p, 4502]
      System property server.ready.url.1 defines WaitUrlParams, url=http://localhost:4502/login.html, regexp=.*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*, times=900/120/0
      System property server.ready.url.2 defines WaitUrlParams, url=http://localhost:4502/libs/cq/core/content/systemready.txt, regexp=.*(QUICKSTART_HOMEPAGE|CRX_LICENSING_PAGE).*, times=300/40/0
      Waiting for http://localhost:4502/crx (0/60) ...
      Waiting for server startup...
      Retrying http://localhost:4502/crx (ConnectException) (2/60)...
      Retrying http://localhost:4502/crx (ConnectException) (4/60)...
      Retrying http://localhost:4502/crx (ConnectException) (6/60)...
      Retrying http://localhost:4502/crx (ConnectException) (8/60)...
      Retrying http://localhost:4502/crx (ConnectException) (10/60)...
      Retrying http://localhost:4502/crx (ConnectException) (12/60)...
      log4j:WARN No appenders could be found for logger (com.day.commons.httpclient.impl.ProxySelector).
      log4j:WARN Please initialize the log4j system properly.
      Retrying http://localhost:4502/crx (ConnectException) (14/60)...
      Retrying http://localhost:4502/crx (ConnectException) (17/60)...
      Retrying http://localhost:4502/crx (ConnectException) (19/60)...
      Retrying http://localhost:4502/crx (ConnectException) (21/60)...
      Retrying http://localhost:4502/crx (ConnectException) (23/60)...
      Retrying http://localhost:4502/crx (ConnectException) (25/60)...
      Retrying http://localhost:4502/crx (ConnectException) (27/60)...
      Retrying http://localhost:4502/crx (ConnectException) (29/60)...
      Retrying http://localhost:4502/crx (ConnectException) (31/60)...
      Retrying http://localhost:4502/crx (ConnectException) (33/60)...
      Retrying http://localhost:4502/crx (ConnectException) (35/60)...
      Retrying http://localhost:4502/crx (ConnectException) (37/60)...
      Retrying http://localhost:4502/crx (ConnectException) (39/60)...
      Retrying http://localhost:4502/crx (ConnectException) (41/60)...
      Retrying http://localhost:4502/crx (ConnectException) (43/60)...
      Retrying http://localhost:4502/crx (ConnectException) (45/60)...
      Retrying http://localhost:4502/crx (ConnectException) (47/60)...
      Retrying http://localhost:4502/crx (ConnectException) (49/60)...
      Retrying http://localhost:4502/crx (ConnectException) (51/60)...
      Retrying http://localhost:4502/crx (ConnectException) (56/60)...
      Retrying http://localhost:4502/crx (ConnectException) (60/60)...
      http://localhost:4502/crx timed out after 60 seconds
      Did not get expected content at server URL, server might still be starting up
      Please try http://localhost:4502/crx again later
      (69 seconds since startup)
      CHILD process: shutdown hook
      CHILD process: exiting
