0 Replies Latest reply on Apr 11, 2012 9:30 AM by Riccardo Vecchiato
    Problems with PDF generator (PLT file to convert)
    Riccardo Vecchiato Level 1
      Hello everybody,
      I'm having a (maybe) stupid problem trying to print a PDF file from a PLT.
      Here I write the steps I followed to do my test:
      1- download the example file from http://www.winline.com/evalpen_center.html (GL-C-F.plt)
      2- from the Administration Panel of Livecycle ES2 go to Services > LifeCycle PDF Generator ES2 > Convert 3D
      3- set as input the downloaded file and leave the default of the other parameters ("Create PDF", "Standard")
      4- try to generate the PDF.
      Here I have three different issues:
      - the first is that in the result page, if I click on the link of the PDF file generated, I obtain the message "File does not begin with '%PDF-'" and nothing happen;
      - if I click on it and I download the file, I can see it is a PS file, as if LifeCycle generates the PS but it doesn't print the PDF;
      - in the end if I convert the PS to PDF, I cannot see anything because the drawing is completly out of the page and too big to be displayed entirely.
      Could you suggest me any kind of solution or what I have to check in the parameters? I don't know what I can do now because I don't have any other idea.
      If I try to open the file in Adobe 3D Reviewer, I can do what I want, so I think it's not a problem due to compability.
      Riccardo
