2 Replies Latest reply on Apr 13, 2012 1:53 PM by josh_chunick
    FileIO question
    MAC800
      From http://www.deansdirectortutorials.com/
      To create a file use the following code
      In the message window type:
      createFile (scribe, "Multimedia.txt")
      What if you want the file to be created to have the date and time as part of the file name
      Such as tFile201204111157am.txt
      So my question is how do you put the current date and time as part of the file name
      Thanks!
        • 1. Re: FileIO question
          Mister MUX Level 2
          There might be a much more simple solution, but this should work. Also there might be system settings on the local machine that cause this to break, I am not sure.
          Your question isn't really a fileIO quetion, it is more of a string manipulation question. There are date and time functions and a couple of "chunk":expression concepts (itemDelimiter and item) that can be used to produce the string you want. Look them up in the online help for more info.
          Here is a  script the should return the string in the format you are wanting. Put it in any movie script cast member.
          on getDateTime
            saveItemDelimiter = the itemDelimiter
            the itemDelimiter = "/"
            theDate = the short Date
            DateAndTime = theDate.item[3]
            if theDate.item[1].char.count = 1 then DateAndTime = DateAndTime & "0"
            DateAndTime = DateAndTime & theDate.item[1]
            if theDate.item[2].char.count = 1 then DateAndTime = DateAndTime & "0"
            DateAndTime = DateAndTime & theDate.item[2]
            the itemDelimiter = ":"
            theTime = the short Time
            if theTime.item[1].char.count = 1 then DateAndTime = DateAndTime & "0"
            DateAndTime = DateAndTime & theTime.item[1]
            theTime = theTime.item[2]
            the itemDelimiter = " "
            DateAndTime = DateAndTime & theTime.item[1] & theTime.item[2]
            the itemDelimiter = saveItemDelimiter
            return DateAndTime
          end
          You can test it by typing into the message window then press ENTER
               put getDateTime()
          which should return
               -- "201204110236PM"
          So now you can do this
          createFile (scribe, "Multimedia" & getDateTime() & ".txt")
          • 2. Re: FileIO question
            josh_chunick Level 1
            I wouldn't use the shortDate or the shortTime as they are most certainly affected by the user's OS date and time formatting. I would instead use the systemDate which returns something like this:
            d = date( 2012, 4, 13 )
            from which you can extract the date and time like this:
            year = string(d.year)
            month = string(d.month)
            if month.length = 1 then month = "0" & month
            day = string(d.day)
            if day.length = 1 then day = "0" & day
            hours = string(d.seconds / 3600)   -- this will return value between 0 and 23
            timeDay = AM
            if hours > 11 then timeDay = PM
            if hours > 12 then hours = hours - 12
            hours = string(hours)
            if hours.length = 1 then hours = "0" & hours
            minutes = string((d.seconds mod 3600) / 60)
            if minutes.length = 1 then minutes = "0" & minutes
            so then you would do this:
            fileName = year & month & day & hours & minutes & timeDay & ".txt"
            if you need seconds:
            seconds = d.seconds mod 60
            on getDateTime
              return DateAndTime
            end
                 put getDateTime()
            which should return
                 -- "201204110236PM"
