• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Why does RH 9 project get hung up in trial version?
New Here ,
Apr 11, 2012 Apr 11, 2012
Hi all,
I've been using RoboHelp 9 HTML and Internet Explorer 7 with no problems. However, our department is upgrading to IE 8 soon and asked that I test its compatibility with a trial version of RH 9 (on a different machine). When I opened up my existing project in the trial version, I experienced hang ups and had to close out several times due to a "not responding" status. I had similar problems when updating linked Word docs and viewing the primary layout. When I started a "blank" project, the response time was very fast and everything was smoother. I'm not sure if this is related to IE 8 or not. Any thoughts on why it would get hung up on my existing project?
Thanks!
Views
793
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Apr 11, 2012 Apr 11, 2012
Hi there
Where is the existing project located? If you say it's on a network drive, that's likely the cause. But if it's on a local C drive, odds are something else is afoot. Is source control involved?
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
LEGEND ,
Hi there
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
Report
Report
New Here ,
I work/save to my C:drive and copy to a network drive as a backup. Yes, the project I was trying to test was on the network drive. Forgot about this restriction. So, projects must always reside on the C:drive?
Votes
Translate
Translate
Report
Report
Community Expert ,
You seem to be confusing RH9 with the help output that RH can create - that's what you're interested in testing, right? Why would you need to get a RH9 trial, when you're already using RH9. You just want to take your WebHelp output and try it out with IE9 to see how it's going to behave.
Votes
Translate
Translate
Report
Report
New Here ,
Jeff,
I understand what you're saying. My department just wanted the "all clear" that we would not run into any problems between RH 9 and IE 8. So I wanted to generate and view the help output directly from RH. Yes, I could test with the WebHelp output. The reason I have to use a trial version is the dept. only allows IE 8 on a select group of machines, and mine (with RH 9 installed) is not currently one of them. I appreciate your input.
Votes
Translate
Translate
Report
Report
Community Expert ,
(a) don't trust the view directly from RH after generating - it can be non-representative of what a client will see
(b) just copy your WebHelp folder from the project's \!SSL!\ folder to the machine that's running whatever browser you want - you're not locked down to having to have RH9 on the same machine
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks for your input--I appreciate it.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
