3 Replies Latest reply on Apr 12, 2012 8:26 AM by Net & Storage Solutions
    Get Object for position
      My question is rather simple,
      is there any functionality that returns an object by x and y pos?
      E.g. I click on 120x and 250y, and on that coördinate there is a textframe,
      is it possible to fetch that object just by giving the x and y ?
      (Via scripting, or java, whatever is possible)
      Kind regards
        • 1. Re: Get Object for position
          Manish-Sharma Employee Moderator
          This feature is not present in the Indesign, may be some script can do it for you...
          • 2. Re: Get Object for position
            Scripting can't help you, because a script cannot determine if the user clicked anywhere, lest on what position.
            (A crude way to do this would be to pop up a dialog, asking for the coordinates. If the coordinates are known, it's easy to get a list of objects that are under that position. But note: objects, plural. As always, this has to be thought about ahead. The OP only mentions 'an object'; what if there are more than one? What about a group -- return the group itself, or "the" object (or objects) inside the group? What about items on a master page?
            As always, it would help if the OP could clarify what would be done with the object(s) after 'finding' them at a certain location. Surely this would serve a deeper purpose, other than "just to see what is there"?)
            • 3. Re: Get Object for position
              Net & Storage Solutions Level 1
              Well I know how to get the input done,
              I just don't know how to get the object or objects under that position. So that is my biggest question.
              After I know that I will figure out how to deal with the return(s) I will get.
              E.g if I get an object that contains another object and then a textframe, I would handle upon that.
              Same goes if I encounter another kind of frame or object.
              Thanks in advance!
