0 Replies Latest reply on Apr 12, 2012 3:42 PM by karenehartley
    Error on actionscript state change using RemoveChild
    karenehartley
      I have an actionscript component (a View) with a number of states defined in the following manner:
      var stateDefault:State = new State();
      stateDefault.name = "DefaultState";
      stateDefault.overrides = new Array();// array of IOverride
      states.push(stateDefault);
      stateDefault.overrides.push(new RemoveChild(btn_MatterPicker_Search));
      When attempting to run the line
           currentState = "DefaultState";
      the error below occurs.  I'm hoping that someone has a simple solution to this - the only thing I can think of at the moment is to write my own state change handler that adds and removes the appropriate items from each state manually.  Does anyone have a more elegant solution?  (The code needs to remain as actionscript, can't switch to mxml.)
      Here's the error:
      Error: removeChild() is not available in this class. Instead, use removeElement() or modify the skin, if you have one.
          at spark.components::Group/removeChild()[E:\dev\4.y\frameworks\projects\spark\src\spark\comp onents\Group.as:2136]
          at mx.states::RemoveChild/apply()[E:\dev\4.y\frameworks\projects\framework\src\mx\states\Rem oveChild.as:150]
          at mx.core::UIComponent/applyState()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\UI Component.as:10741]
          at mx.core::UIComponent/commitCurrentState()[E:\dev\4.y\frameworks\projects\framework\src\mx \core\UIComponent.as:10487]
          at mx.core::UIComponent/setCurrentState()[E:\dev\4.y\frameworks\projects\framework\src\mx\co re\UIComponent.as:10323]
          at mx.core::UIComponent/set currentState()[E:\dev\4.y\frameworks\projects\framework\src\mx\core\UIComponent.as:6425]
          at com.chromeriver.components.matter::MatterSearchBar/setDefaultState()...MatterSearchBar.as :288]
