0 Replies Latest reply on Apr 13, 2012 1:14 AM by 9roove04
    How to trace to output console?
    9roove04
      I use
           - window 7 (64bit)
           - Flash builder 4.6
           - Ant
           - flash debugger player10
      I complied with mxmlc and ant. Then i excuted swf.
      But trace() didn't work.
      Any idea what to do?
      [ant tag]
      <target name="SimpleTest_compile">
        <mxmlc file="${test.dir}/objProxy_Test.as" output="${web.dir}/SimpleTest.swf">
         <debug>true</debug>
         <incremental>false</incremental>
         <default-size width="300" height="300" />
         <default-frame-rate>60</default-frame-rate>
         <actionscript-file-encoding>UTF-8</actionscript-file-encoding>
         <default-background-color>0xFFFFFF</default-background-color>
         <load-config filename="${flex4sdk.home.dir}/frameworks/flex-config.xml" />
         <static-link-runtime-shared-libraries>true</static-link-runtime-shared-libraries>
         <source-path path-element="${src.dir}" />
         <source-path path-element="${test.dir}" />
         <compiler.include-libraries dir="${basedir}/web/" append="true">
           <include name="Testt.swc" />
         </compiler.include-libraries>
        </mxmlc>
      </target>
      <target name="SimpleTest_run">
        <exec executable="${flashDebugPlayer.exe}">
         <arg line="${web.dir}/SimpleTest.swf" />
        </exec>
      </target>
