2 Replies Latest reply on Apr 14, 2012 10:06 AM by Julie Cloutier
    ClickTAG and Link can't have both ?
    Julie Cloutier
      Hi, I have a problem when inserting a click tag and a link. I read that the clickTAG must be on the top layer of the animation, so I put right below it on another layer a button with a link to a website. When I click on the image, the click tag work but the redirection to the website does not.
      Any idea on how to make a link work while inserting a click tag ?
      Should I put this code on the same button ?
      on (release) {
      getURL (_level0.clickTAG, "_blank");
      on (release) {
          getURL("http://www.mywebsiteaddressblablabla.com", "_blank");
        • 1. Re: ClickTAG and Link can't have both ?
          KalebW-gl44HL
          Easy — just use one button with one on (release) and a simple conditional...
          on (release) {
               if (_level0.clickTag) {
                    getURL(_level0.clickTag, "_blank");
               } else {
                  getURL("http://www.adobe.com", "_blank");
          You should only use one "release" event handler per button, and don't bother stacking two buttons on top of each other. The purpose of the clickTag is to go to a URL specified by the ad server. A clickTag is just a URL string passed to a flash banner using a flash var in the object/embed tag of an html page, so that conditional statement above (the if/else) checks if the clickTag exists; if it does, it navigates to the URL specified by the clickTag. If it does not exist, it goes to the backup URL.
          • 2. Re: ClickTAG and Link can't have both ?
            Julie Cloutier Level 1
            Thank you so much for this answer, it clarify everything about the clickTAG.
            I have one more question though.
            All of this work only with CS 4 right ? This is Action script 2.0 and it won't work if I save my file using CS5.5 format ?
