Word 2007 Crashes with the error seen below, when using the Convert to PDF button on the Acrobat ribbon in Word. The document may have footnotes. I can convert other docuemnts to pdf in this fashion. Is there an issue converting Word Docuements to PDF if they have foot notes? I saw a post where someone had a table in a docuemnt that was causing Word to crash when it was converted to PDF in this fashion.
Problem Event Name: BEX
Application Name: WINWORD.EXE
Application Version: 12.0.6545.5000
Application Timestamp: 4c653e57
Fault Module Name: wwlib.dll
Fault Module Version: 12.0.6545.5000
Fault Module Timestamp: 4c653fe2
Exception Offset: 00cd18bc
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7600.2.0.0.256.4
Locale ID: 1033
I convert several Word documents having footnotes to PDF using Acrobat X and it works fine. Is it possible for you to share your Word file in which you are seeing this issue so that I can investigate? You can send me the file @ lbisht@adobe.com.
Love Bisht
