3 Replies Latest reply on Apr 14, 2012 6:18 PM by Peter Spier
    Text flow in new document
    Jack Level 1
      Am creating a new document containing mostly text and some graphics. Master is set with 3/4" margins. Threee footnotes have been added at bottom of first page. Text exceeding capacity of first page does not flow to new page. It just "disappears" at end of first page. What is going on here? Missed settings? A bit surprising they do not edxist by default.
        • 1. Re: Text flow in new document
          Are you importing the text, or typing it in?
          • 2. Re: Text flow in new document
            Jack Level 1
            Have tried both methods. First 3/4 of first page was previously imported via copy/paste. For the last 1/4 of the first page, there are two paras. When I pasted both, the second para disappeared until I deleted the first (which, in itself, exceeded the remaining space on the first page). When entering text manualhy, after page was filled, any further typing was not echoed to current or next page.
            • 3. Re: Text flow in new document
              When typing or pasting, that's the way it works unless you have Smart Text Reflow enabled (I can't stand it so I leave it off). The text that does not fit is called "overset" and is inidacted by a red plus sign in the Out Port of the text frame. If you click the plus sign with the selection tool it will pick up the overset and you can place it into an new frame (which will be threaded to the original). Holding the shift key when placing the text will flow all that there is, making new frames and pages as required to accomodate it.
              This is basic function of the program. You should spend some time reading the help files on working with text, or pick up a good beginners's book, like Sandy Cohen's Visual Quickstart Guide to InDesign.
