3 Replies Latest reply on Apr 20, 2012 9:34 AM by YogeshUpadhyay
    Startup issues with CQ on VPN connection
    DavidMcCarty
      Anyone had issues when starting up a personal instance of CQ when running a VPN connection?
      I assume this is having to do with CQ trying to start the cluster listener.  It seems to halt for some time after this statement,
      and then never start up...
      15.04.2012 12:13:34 *INFO * LocalFileSystem: LocalFileSystem initialized at path C:\DAY_HOME\author\
      crx-quickstart\repository\repository (LocalFileSystem.java, line 164)
      15.04.2012 12:13:35 *INFO * ClusterController: Node f44b37df-3b76-4fda-879e-64f67f7dc627 started the
      master listener, on address: H8440305020961/192.168.21.1:8088 force: false (ClusterController.java,
      line 804)
      Since this is a local dev instance we are running and we are not clustering, would there be a way to supress this and any other step
      that might need external connectivity. Or has someone had experience with another approach?
        • 1. Re: Startup issues with CQ on VPN connection
          anuumar Level 1
          How are you trying to start the instance and what is the error which is displayed on the UI.
          • 2. Re: Startup issues with CQ on VPN connection
            DavidMcCarty Level 1
            I am starting at the command line using server.bat.
            It stalls at this line, then gives this error: (essentially thinking VPN is shutting connectivity to be able to create connections to my host on a specific port and cluster listener complains)
            20.04.2012 11:19:59 *ERROR* RepositoryStartupServlet: RepositoryStartupServlet initializing failed:
            org.apache.jackrabbit.j2ee.ServletExceptionWithCause: Error while creating repository (RepositorySta
            rtupServlet.java, line 250)
                    at org.apache.jackrabbit.j2ee.RepositoryStartupServlet.initRepository(RepositoryStartupServl
            et.java:415)
                    at org.apache.jackrabbit.j2ee.RepositoryStartupServlet.startup(RepositoryStartupServlet.java
            :242)
                    at com.day.crx.j2ee.CRXRepositoryStartupServlet.startup(CRXRepositoryStartupServlet.java:147
                    at org.apache.jackrabbit.j2ee.RepositoryStartupServlet.init(RepositoryStartupServlet.java:21
            5)
                    at javax.servlet.GenericServlet.init(GenericServlet.java:211)
                    at com.day.crx.j2ee.CRXRepositoryStartupServlet.init(CRXRepositoryStartupServlet.java:126)
                    at com.day.j2ee.servletengine.ServletRuntimeEnvironment.doStart(ServletRuntimeEnvironment.ja
            va:113)
                    at com.day.j2ee.servletengine.ServletRuntimeEnvironment.start(ServletRuntimeEnvironment.java
            :93)
                    at com.day.j2ee.servletengine.WebApplication.loadStartupServlets(WebApplication.java:702)
                    at com.day.j2ee.servletengine.WebApplication.start(WebApplication.java:631)
                    at com.day.j2ee.servletengine.ServletContainer.start(ServletContainer.java:318)
                    at com.day.j2ee.servletengine.ServletEngine.start(ServletEngine.java:285)
                    at com.day.j2ee.server.Server.start(Server.java:227)
                    at com.day.j2ee.server.Server.main(Server.java:607)
                    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                    at java.lang.reflect.Method.invoke(Unknown Source)
                    at com.day.launcher.Bootstrap.run(Bootstrap.java:118)
                    at com.day.crx.quickstart.Quickstart.run(Quickstart.java:680)
                    at com.day.crx.quickstart.Main.<init>(Main.java:675)
                    at com.day.crx.quickstart.Main.main(Main.java:730)
                ... 21 more
            Caused by: java.io.IOException: Could not create a listener on any of the following ports: [8088, 8
            89, 8090, 8091, 8092, 8093], and could not connect to another cluster node
                at com.day.crx.core.cluster.ClusterController.start(ClusterController.java:679)
                at com.day.crx.core.cluster.ClusterController.register(ClusterController.java:833)
            at com.day.crx.core.data.ClusterDataStore$Skeleton.register(ClusterDataStore.java:611)
            • 3. Re: Startup issues with CQ on VPN connection
              Do your port list from
              8088, 889, 8090, 8091, 8092, 8093 are not open or in use ? Make sure that they are open. If in case they are in use (When many CQ instace is running on same machine), You can change this range using portList option. See http://wem.help.adobe.com/enterprise/en_US/10-0/core/administering/cluster.html for that.
              Yogesh
