1 Reply Latest reply on May 10, 2012 1:28 PM by Manny_Bhinder
    Problem printing assembled forms
    Phoenix_Guru Level 1
      I have 4 forms in the following sequence:
      Form 1 - 8.5x11 - Duplex - 4 pages
      Form 2 - 8.5x14 - Simplex - 1 page
      Form 3 - 8.5x14 - Duplex - 2 pagres
      Form 4 - 8.5x11 - Simplex - 1 page
      I am assembling these forms using invokeDDX. When I print the merged/assembled output directly using generatePrintedOutput, this package prints perfectly.
      Whereas when I print using generatePDFOutput, Form 3 starts printing on the backside of Form 2. Whereas Form 4 prints alright as a single page Simplex.
      What might be going wrong? The DDX that I have simply takes the XDPs and generates merged XDP.
      Please help.
      Phoenix
        • 1. Re: Problem printing assembled forms
          Manny_Bhinder
          Hello Phoenix_guru,
          I came accross this discussion but found the answer sheet empty.I'd like little help from you regarding how did you actually embeded duplex and simplex properties to different forms.
          I checked out the forms from workbench and in the designer (File-> FormProperties-> PDF Print Options-> select duplex mode). After saving and checking in and running the java code, the assembled PDF is still showing a property of Simplex. Could you please help me if you can, if there is any need to tweak java properties to set these printing options. I really appreciate your help.
          M
