6 Replies Latest reply on Apr 17, 2012 10:54 AM by logie2651
    EMBEDDING POSTSCRIPT FONTS INTO PDFS
    logie2651 Level 1
      Used Quark Xpress 3.31 on Windows 98/Millenium/2000, made ps file, distilled to PDF. Worked great. All fonts embedded in PDF. Files worked great for prepress. Can't update Quark because of maths program I use that won't work on later Quark versions and can’t get math program upgrade. Trying to update to Windows XP. With XP postscript fonts will not embed in PDFs via Quark 3.31/Acrobat Distiller 4. Fonts will only show in Courier on PDF, although using Word same fonts will distill and show in PDF preferences/fonts list – so fonts are working. Have tried Universal Document Converter 5.3 as straight PDF converter. Fonts show on PDF but not showing as fonts embedded in preferences/fonts in PDF. Trying Adobe Acrobat Pro 10 but does not seem to work either. I think it is an issue with Quark 3.31 and later Windows platforms. Any suggestions out there on problem/solution? I may have to be stuck in the middle ages with software. Thanks
        • 1. Re: EMBEDDING POSTSCRIPT FONTS INTO PDFS
          Steve Werner Adobe Community Professional & MVP
          People have the best experience when their application software, their OS software and their hardware are moving forward together. But you've pretty much just stuck with what you have for the past 16 years.
          I'd guess that the problem is that QuarkXPress 3.31 (which came out in 1996, according to Wikipedia) is probably incompatible with Windows XP (which came out in 2001).
          Either you stick with what you have or you'll have to replace all your software. Assuming you want to stick with QuarkXPress, you'll have to find new math software which works with a later version of QuarkXPress. This will then require you to probably upgrade your hardware and update your Windows software. Since you waited so long, this will take some work.
          • 2. Re: EMBEDDING POSTSCRIPT FONTS INTO PDFS
            Dov Isaacs Adobe Employee
            You might be best off contacting Quark Technical Support since QuarkXPress is not an Adobe product.
                      - Dov
            • 3. Re: EMBEDDING POSTSCRIPT FONTS INTO PDFS
              Daniel Flavin Level 4
              As I recall, XP may handle PS fonts in a unique folder; the OS sees the fonts but Distiller is only looking at the default OS fonts folder.
              Have you opened distiller and checked the font locations?
              Settings > Font Locations
              Browse and add c:\psfonts
              Something similair to this screen shot, Distiller 9
              • 4. Re: EMBEDDING POSTSCRIPT FONTS INTO PDFS
                logie2651 Level 1
                You are right. I have been burying my head in the sand for too long. I understand what you are saying and am sick and tired of doing workarounds because of my essential maths program. I hopefully have found one that will help me move forward, which means a total upgrade. Thanks.
                • 5. Re: EMBEDDING POSTSCRIPT FONTS INTO PDFS
                  logie2651 Level 1
                  I did that before without much help. Thanks.
                  • 6. Re: EMBEDDING POSTSCRIPT FONTS INTO PDFS
                    logie2651 Level 1
                    I have checked all that out and everything is in place. Thanks for advice. As I said to Steve, I don't think there is a fix for this one. Once I start to moving forward with one piece of software, another one is incompatible. I have been searching for a while and this latest episode of problems just compound everything. So, it's a major upheaval for me - and a sign of relief. Thanks Daniel
