2 Replies Latest reply on Apr 19, 2012 2:19 AM by cappelluti
    Customized menu doesn't work when inDesign restarted
    cappelluti Level 1
      I'm quite new to this forum. I'd like to customize my inDesign menu with the following script:
      var cartella_scripts = Folder(app.activeScript.path);
      app.menus.item("$ID/Main").submenus.add("Enzo's");
      //ADD INFO PUBBLICAZIONE
      nuova_voce = app.scriptMenuActions.add("SUBMENU1");
      myEventListener = nuova_voce.eventListeners.add("onInvoke", function(){
          cartella_scripts1=cartella_scripts
          app.doScript(File(cartella_scripts1 + '/INFO PUBBLICAZIONE.jsx'));
      mySampleScriptMenu = app.menus.item("$ID/Main").submenus.add("Enzo's");
      mySampleScriptMenuItem = mySampleScriptMenu.menuItems.add(nuova_voce);
      //ADD EVIDENZIA STILI
      nuova_voce = app.scriptMenuActions.add("SUBMENU2");
          cartella_scripts2=cartella_scripts
          app.doScript(File(cartella_scripts2 + '/EVIDENZIA STILI.jsx'));
      //ADD GESTISCO COPERTINE
      nuova_voce = app.scriptMenuActions.add("SUBMENU3");
          cartella_scripts3=cartella_scripts.parent + '/personal_folder'
          app.doScript(File(cartella_scripts3 + '/GESTISCI COPERTINE.jsx'));
      If I run this script, it works. So I can see, and use, the menu group (Enzo's) with it's submenus (SUBMENU1, SUBMENU2 and SUBMENU3).
      My problem is when I close and open again inDesign. If I don't run again the script I'll see the menu group (Enzo's) but I can't see the submenus.
      Can I avoid to run the script everytime I open inDesign?
      Thank you very much.
      Enzo Cappelluti
