6 Replies Latest reply on Apr 16, 2012 11:44 AM by Draco_DK
    Capturing Video8, quality = 3?
    Draco_DK
      I got som Video8 tapes that i want to transfere to my Mac.
      Bought a Grass Valley ADVC 110 http://www.grassvalley.com/products/advc110 and a Canon G20 H8/Hi8 camcorder PAL.
      Connected the camcorder via composite (Yellow video - Black to Audio L phono), the camera don't have stereo out and the tapes is from a Bauer VCC 830 camcorder bougt i 91' and don't think it records in stereo anyway, but the camara i long gone.
      On some danish sites it recomende to use S-video out rather than composite, there for i orderet a S-Video cable and will get the audio like with composite.
      My question goes on capturing the video in Premiere Pro CS5.
      When i capture i get af bitrate of 3.6MB/sec but under the Video data block the settings are Normal = 3 in quality.
      Is it possible to change this, for higher quality capture? (Im aware that it can't get any better the quality of the film)
      I was recomende to use DVCPRO50 when editing the capture film, because it has higer bitrate and more functions (colour boost) and since it dosent matter if i capture in a standard 48KHZ pal project or DVCPRO50, i think that the bit rate of 3.6Mb/sec i what the camara/film quality is.
      I want to capture my Video8 tape in best quality, for later use i Premiere Pro and export DVD copy's to famerly members.
        • 1. Re: Capturing Video8, quality = 3?
          It's not necessary to do so. In fact, it won't improve your video quality.
          If you're capturing your video through the AVDC into a FireWire connection on your computer, your captured video should look identical to the original -- except digital.
          • 2. Re: Capturing Video8, quality = 3?
            Draco_DK Level 1
            Steve => thanks for replying.
            Yes, im using the Firewire connection and use capture in Premiere Pro.
            Teh monitor on the camera is not very good, so i can't compare the film. but as you replyes it should be det same but digital.
            But im just wondering, where this Quality = Normal can be changed, i dont see any settings for the capture with this option.
            Do you know if S-video will give an video improvement? What I read (in danish) using Composite (Sinle phono yellow out), is the worst quality out put, and S-video is recomended if possible.
            • 3. Re: Capturing Video8, quality = 3?
              I don't know where you change the quality setting. But I'm sure if you post to the Community Forum at videomaker support site http://Muvipix.com you'll find someone who does. I know a number of people on that forum that use the Canopus unit.
              That said, I don't think it will make much difference if you capture your video as composite or S-video. Your results should look identical to the original footage either way. And you can't get better than that!
              • 4. Re: Capturing Video8, quality = 3?
                Draco_DK Level 1
                Steve => Thanks for your help.
                register at the muvipix.com and seached the forum and only found threads saying good things about canopus 110 and 300.
                regading composite vs S-Video, is because if composite offers more quality loss than S-Video, then S-Video must offer better or closer to the original quality.. the best should be component (Y-Cb-Cr (RGB) for analog signal, if is true what i read.
                • 5. Re: Capturing Video8, quality = 3?
                  Is there a reason you only searched and didn't ask on the Muvipix forums???
                  • 6. Re: Capturing Video8, quality = 3?
                    Draco_DK Level 1
                    Steve => I didn't got the time to formulate the question (im danish, and don't write much english, therefor it takes mere longer time to formulate my question) and right now its evening/night here.
                    Thats why i only seached the site, just to see if any already had a question/thread regarding the same problem/question like mine.
                    im sorry, if that made no senes
