5 Replies Latest reply on Apr 20, 2012 10:23 AM by Flex harUI
    ftp Security Sandbox Violation?
    EWN-CMI Level 1
      I have a crossdomain file and am trying to run the example at http://ntt.cc/2009/08/23/how-to-upload-files-in-flex-ftp.html but I keep getting a sandbox error.  All help is appreciated.  I am simply trying to allow users to upload images to a common folder, but I don't get permission to manage the folder unless the file is sent via ftp, so I am looking for a simple upload ftp client - which the test example looks like, using the ftp library - but can't get by the security.  The crossdomain file is below.  The common image folder is under the app folder.  Thanks.
      SecurityError–>Error #2048: Security sandbox violation: http://myDomain.org/TEST/FlexFTP/FTPflex.swf cannot load data from ftp.myDomain.org:21.
      The following statement is included in my Flex app.
      Security.loadPolicyFile('http://www.myDomain.org/crossdomain.xml');
      The crossdomain file:
      <?xml version="1.0"?>
      <!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
      <cross-domain-policy>
      <site-control permitted-cross-domain-policies="all"/>
      <allow-access-from domain="*.myDomain.org" to-ports="*" />
      <allow-access-from domain="ftp.myDomain.org" to-ports="*" />
      <allow-http-request-headers-from domain="*" headers="*"/>
      </cross-domain-policy>
        • 1. Re: ftp Security Sandbox Violation?
          Flex harUI Adobe Employee
          What is the url for the app and what url is it trying to access?
          • 2. Re: ftp Security Sandbox Violation?
            EWN-CMI Level 1
            The app is running at http://myDomain.org/TEST/FlexFTP/FTPflex.swf.
            The image folder is http://myDomain.org/TEST/FlexFTP/uploader
            The ftp path is ftp.myDomain.org  (there is an ftp folder at the level above "www/ftp"  versus "www/html" folder on the server - not sure on the permissions of this folder but don't think I get there before the security error)
            The full code is below.  The crossdomain.xml file is above.
            Thanks for looking. and the help.
            //   http://ntt.cc/2009/08/23/how-to-upload-files-in-flex-ftp.html/
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
            initialize="upLoad()" layout="vertical">
            <mx:Script>
            <![CDATA[
            import mx.utils.*;
            import mx.controls.Alert;
            private var fileRef:FileReference;
            private var fileSize:uint;
            private var fileContents:ByteArray ;
            //you need to initiate two scokets one for sending
            //commands and second for sending data to FTP Server
            //socket for sending commands to FTP
            private    var s:Socket
            //responce from FTP
            private    var ftpResponce:String;
            //socket for sending Data to FTP
            private    var dataChannelSocket:Socket;
            //responce from FTP when sending Data to FTP
            private    var dataResponce:String;
            //will hold the IP address of new socket created by FTP
            private    var dataChannelIP:String;
            //will hold the Port number created by FTP
            private    var dataChannelPort:int;
            private var user:String="userName";//FTP usernae
            private var pass:String="passWord";//FTP Password
            private function receiveReply(e:ProgressEvent):void{
            ftpResponce = s.readUTFBytes(s.bytesAvailable)
            var serverResponse:Number = Number(ftpResponce.substr(0, 3));
            if(ftpResponce.indexOf('227')>-1){
            //get the ip from the string response
            var temp:Object = ftpResponce.substring(ftpResponce.indexOf("(")+1
            ,ftpResponce.indexOf(")"));
            var dataChannelSocket_temp:Object = temp.split(",");
            dataChannelIP = dataChannelSocket_temp.slice(0,4).join(".");
            dataChannelPort = parseInt(dataChannelSocket_temp[4])*256+
            int(dataChannelSocket_temp[5]);
            //create new Data Socket based on dataChannelSocket and dataChannelSocket port
            dataChannelSocket = new Socket(dataChannelIP,dataChannelPort);
            dataChannelSocket.addEventListener(ProgressEvent.SOCKET_DATA, receiveData);
            //few FTP Responce Codes
            switch(String(serverResponse)){
                   case "220" :
                               //FTP Server ready responce
                              break;
                   case "331" :
                             //User name okay, need password
                             break;
                case  "230":
                              //User  logged in
                            break;
                case "250" :
                            //CWD command successful
                            break;
                   case "227" :
                                 //Entering Passive Mode (h1,h2,h3,h4,p1,p2).
                               break;
                  default:
            //for more please
            //http://http://www.altools.com/image/support/alftp/ALFTP_35_help/
            //FTP_response_codes_rfc_959_messages.htm
            traceData(ftpResponce);
            private function receiveData(e:ProgressEvent):void{
            dataResponce = dataChannelSocket.readUTFBytes(
            dataChannelSocket.bytesAvailable);
            traceData("dataChannelSocket_response—>"+dataResponce);
            private function showError(e:IOErrorEvent):void{
                   traceData("Error—>"+e.text);
            private function showSecError(e:SecurityErrorEvent):void{
                  traceData("SecurityError–>"+e.text);
            private function createRemoteFile(fileName:String):void{
            if(fileName!=null && fileName !=""){
            s.writeUTFBytes("STOR "+fileName+"\n");
            s.flush();
            private function sendData():void{
            fileContents=fileRef.data as ByteArray;
            fileSize=fileRef.size;
            dataChannelSocket.writeBytes(fileContents,0,fileSize);
            dataChannelSocket.flush();
            //initialize when application load
            private function upLoad():void {
            fileRef = new FileReference();
            //some eventlistener
            fileRef.addEventListener(Event.SELECT, selectEvent);
            fileRef.addEventListener(Event.OPEN, onFileOpen);
            //this fucntion connect to the ftp server
            connect();
            //send the usernae and password
            this.userName(user);
            this.passWord(pass);
            //if you want to change the directory for upload file
            //this.changeDirectory("/public_html/");   //directory name
            this.changeDirectory("/html/TEST/FlexFTP/uploader/");                  //directory name  sample shows /public_html/  show I am using my root path?????
            //enter into PASSV Mode
            s.writeUTFBytes("PASV\n");
            s.flush();
            private function onFileOpen(event:Event):void {
            private function traceData(event:Object):void {
            var tmp:String = "================================\n";
            ta.text +=event.toString()+ "\n" ;
            ta.verticalScrollPosition += 20;
            private function ioErrorEvent(event:IOErrorEvent):void{
            Alert.show("IOError:" + event.text);
            private function selectEvent(event:Event):void{
            btn_upload.enabled = true;
            filename.text = fileRef.name;
            fileRef.load();
            private function uploadFile():void {
            createRemoteFile(fileRef.name);
            sendData();
            private function connect():void{
            s = new Socket("ftp.myDomain.org",21);                                                  //Socket("ftp.anydomain.com",21);
            //s = new Socket("ftp.yourdomain.com",21);                                             //Socket("ftp.anydomain.com",21);
            s.addEventListener(ProgressEvent.SOCKET_DATA, receiveReply);
            s.addEventListener(IOErrorEvent.IO_ERROR, showError);
            s.addEventListener(SecurityErrorEvent.SECURITY_ERROR, showSecError);
            s.addEventListener(Event.CONNECT,onSocketConnect);
            s.addEventListener(Event.CLOSE,onSocketClose);
            s.addEventListener(Event.ACTIVATE,onSocketAtivate);
            private function onSocketConnect(evt:Event):void {
            //traceData("OnSocketConnect–>"+evt.target.toString());
            private function onSocketClose(evt:Event):void {
            //traceData("onSocketClose–>"+evt.target.toString());
            private function onSocketAtivate(evt:Event):void {
            //traceData("onSocketAtivate–>"+evt.target.toString());
            private function userName(str:String):void {
            sendCommand("USER "+str);
            private function passWord(str:String):void {
            sendCommand("PASS "+str);
            private function changeDirectory(str:String):void {
            sendCommand("CWD "+str);
            private function sendCommand(arg:String):void {
            arg +="\n";
            s.writeUTFBytes(arg);
            s.flush();
            </mx:Script>
            <mx:Panel id="up" horizontalAlign="left" width="100%" height="100%">
            <mx:Box width="100%" height="100%">
            <mx:VBox >
            <mx:Form  width="449" height="284">
            <mx:FormItem label="Selected File:">
            <mx:Label id="filename"/>
            </mx:FormItem>
            <mx:FormItem >
            <mx:Button width="80" label="Browse" click="fileRef.browse()" />
            <mx:Button width="80" label="Upload" id="btn_upload" enabled="false"
                click="uploadFile()" />
            <mx:Button width="80" label="Cancel" id="btn_cancel" enabled="false"
                click="fileRef.cancel()" />
                        </mx:FormItem>
            <mx:HRule width="100%" tabEnabled="false"/>
            <mx:FormItem label="Events:">
            <mx:TextArea id="ta" width="260" height="98" />
            </mx:FormItem>
            </mx:Form>
            </mx:VBox>
            </mx:Box>
            </mx:Panel>
            </mx:Application>
            • 3. Re: ftp Security Sandbox Violation?
              Spiix
              I have the exact same problem. I try to connect to an FTP server by using sockets, everything works perfectly locally but I get the same error when I deploy and run it on the server.
              SWF location is http://spiix.dommel.be/restaurant/RestaurantSite.swf
              FTP location is spiix.dommel.be  on port 21
              crossdomain.xml location is http://spiix.dommel.be/restaurant/crossdomain.xml
              I even added
              Security.allowInsecureDomain("*");
              Security.allowDomain("*");
              to the code, to no avail.
              error :
              Socket security error : Error #2048: Security sandbox violation: http://spiix.dommel.be/restaurant/RestaurantSite.swf cannot load data from spiix.dommel.be:21.
              Any help would be apreciated (even disabling the entire security thing completely, in my case it doesn't have to be secure AT ALL).
              • 4. Re: ftp Security Sandbox Violation?
                EWN-CMI Level 1
                I got around the issue by not using Flex, but am using php to handle the file/folder functions on the server.  My issue was that if I tried to create folders from Flex non-ftp that the permissions on the server were set to Apache which limited my access to manage any uploaded data.  If I create the folder through an ftp session then I can upload to that folder from Flex without issue and I am still the owner, so I just check to see if a folder needs to be created and if it does I use the php-ftp functions to create the folder before I process the Flex uploaded file.  Seems to be working fine.  I would have liked sockets to work but for this project no time to try to figure out the Security problem, when I thought my stuff was correct to start with.   Thanks to all, I would like to know what my problem was if anyone knows but now it's more for future reference.
                • 5. Re: ftp Security Sandbox Violation?
                  Did you follow the instructions on socket policy files?
                  FWIW, I’ve used AIR (which has different security rules).  I get occasional errors, but it works most of the time.
                  -Alex
