1. Re: UINewsstandApp=true FAIL UPON UPLOAD
uabmagazine Sep 6, 2012 6:51 PM (in response to oztoksoy)Did you ever find an answer to this question?
2. Re: UINewsstandApp=true FAIL UPON UPLOAD
Matthew_Meehan Sep 6, 2012 6:59 PM (in response to oztoksoy)Hi oztoksy
I've just recieved this message while trying to upload my app. Were you able to resolve this issue and if yes, how?
Thanks in advance.
3. Re: UINewsstandApp=true FAIL UPON UPLOAD
Isabel Work Sep 20, 2012 8:55 AM (in response to Matthew_Meehan)Having the same problem. Anyone else resolve this?
4. Re: UINewsstandApp=true FAIL UPON UPLOAD
Isabel Work Sep 20, 2012 10:05 AM (in response to Isabel Work)Nevermind, I followed this tutorial and it seemed to work!
5. Re: UINewsstandApp=true FAIL UPON UPLOAD
bleow Oct 10, 2013 4:40 AM (in response to oztoksoy)We're currently experiencing exactly the same error. There's an open case with Adobe at the moment to try and ascertain if it's DPS or iTunes Connect that's causing the problem. I'll update this thread as soon as I have more information.
UPDATE:
We've finally got some answers on this issue.
It isn't very clear from the Digital Publishing Suite marketing materials that you can only publish to Newsstand if you're a Professional or Enterprise DPS user.
Those who subscribe to CC can only produce single "Custom Viewer" apps outside of the Newsstand App. Hence the only way around the error above is to uncheck the 'Newsstand' option during the iTunes Connect part of the publishing workflow.
Hope this helps anyone else who comes across this rather unhelpful error message.
6. Re: UINewsstandApp=true FAIL UPON UPLOAD
ANSADV123 Sep 24, 2014 1:26 PM (in response to Isabel Work)Isabel,
What was it in the tutorial that you did different that helped you get through the issue?
Thanks.
-Jeff
7. Re: UINewsstandApp=true FAIL UPON UPLOAD
Neil Enns - Adobe Sep 24, 2014 9:33 PM (in response to ANSADV123)Don't indicate that your app supports Newsstand when you are in iTunes Connect unless you are a pro or enterprise DPS customer and have selected Newsstand support in App Builder.
Neil
