0 Replies Latest reply on Apr 17, 2012 10:07 AM by Johannalc40
    Script for Batch HDR with Surrelistic Presets
    Johannalc40
      I have the following script to Batch HDR. I am looking to add the Surrelistic Presets to all of my HDR. What is the script that I need to add to this? I am working in CS5
      // Batch Creation of HDR files
      // Opens a dialog box, asking for the container folder.
      // The container folder must have separate sub folders for each of the HDR image series
      // The output can be saved in a subfolder with an arbitrary name by
      // changing the options below.
      // example: to save hdr files as
      // C:\container\hdrseries1\myhdrfolder\myhdr.psd
      // change the options HDROutputFolder to "myhdrfolder"
      // and option HDRFileName to "myhdr"
      // Extensions of source image files
      var pictureExtensions = "*.jpg";
      // Sub-folder to save the resulting HDR file. This folder will be created if it does not exist.
      //var HDROutputFolder = "";  // disable subfolder like this
      // Filename for saved HDR file. Do not set the extension here, extension is set automatically according to saveResultAsEXR option.
      var HDRFileName = "HDR";
      // Save EXR file (requires EXR plugin) If set to "false" saves the HDR as a  .PSD file
      var saveResultAsEXR = false;
      // Overwrite existing HDR output files? If set to "false" skips creating HDR files for already created image sets.
      // This is useful for adding some new HDR sets into the container folder, and running the script again
      // to crate HDR files only for the newly added series.
      var overwriteExistingHDR = false;
      // --------------- End of settings ------------------- //
      var runMergeToHDRFromScript = true;// define and set to true before including Merge To HDR.jsx
      var g_ScriptFolderPath = app.path + "/"+ localize("$$$/ScriptingSupport/InstalledScripts=Presets/Scripts");
      var g_ScriptPath = File( g_ScriptFolderPath+'/Merge To HDR.jsx' );
      $.evalFile( g_ScriptPath );
      // function to manually save an EXR file. Requires EXR plugn to be installed
      function saveEXR(saveFile){
          var idsave = charIDToTypeID( "save" );
          var desc6 = new ActionDescriptor();
          var idAs = charIDToTypeID( "As  " );
          desc6.putString( idAs, "OpenEXR" );
          var idIn = charIDToTypeID( "In  " );
          desc6.putPath( idIn, saveFile );
          executeAction( idsave, desc6, DialogModes.NO );
      function main()
          var bracket_folders = [];
          var selected_folder = Folder.selectDialog ("/Users/johannalc40/Documents/HDR")
          if (selected_folder != null)
              // to process multiple container folders, uncomment following line and edit folder paths.
              //bracket_folders = [ Folder('/c/images/bracket5'), Folder('/c/images/bracket9')];
              bracket_folders = bracket_folders.concat(selected_folder);
              for (var f = 0; f < bracket_folders.length; f++)
                  var image_folders = bracket_folders[f].getFiles();
                  for (var g = 0; g < image_folders.length; g++)
                      var folder = image_folders[g];
                      if( ! (image_folders[g] instanceof Folder) ) continue;// only process folders
                      var filelist = image_folders[g].getFiles(pictureExtensions);
                      var photoshopHDRFolder = Folder(folder.absoluteURI + "/" + HDROutputFolder);
                      if (saveResultAsEXR) {
                          var extension = ".exr";
                      } else {
                          var extension = ".psd";
                      var photoshopHDRFile = File(photoshopHDRFolder.absoluteURI + "/" + HDRFileName + extension);
                      if (overwriteExistingHDR ==false && photoshopHDRFile.exists == true) {
                          continue;
                      mergeToHDR.useAlignment = true;
                      mergeToHDR.outputBitDepth= 32;
                      mergeToHDR.mergeFilesToHDR( filelist, true, -2 );
                      if (photoshopHDRFolder.exists == false) {
                          photoshopHDRFolder.create();
                          saveEXR(photoshopHDRFile);
                      } else {
                          activeDocument.saveAs(photoshopHDRFile );  // Use for PSD files
                      activeDocument.close(SaveOptions.DONOTSAVECHANGES);
