1. Re: Upgrading from 4 to 5.5 Questions Resizing
RodWard Apr 17, 2012 8:19 PM (in response to eLearner22)Bad news...If you have over 3000 files created with Captivate 4 being upgraded to Captivate 5.5 you have a LOT of work ahead of you. Cp5x changed the underlying technology used in text captions.
I suggest you set up Global Object Styles in Captivate 5 to specify preferred settings for Question Title, Question Answer, and Question Text caption objects. You need to set these up in Cp 5.5 with no project file open so that you are changing the Global style definitions, not definitions within only a project file. You can export these styles as a set and then reimport them into upgraded projects, using the option to overwrite styles of the same name so that your new definitions become active.
This method only works reasonably well for the objects on Question slides that are fairly unique. Even with all of this, you will face a lot of rework.
As regards all the captions in the rest of your project file, you'll need to develop more custom styles according to need and apply them to your captions individually. It's going to take quite a bit of experimentation to find the right settigns and then a long...long...time to apply them to all affected text captions. There is no way to apply all of these changes across all files as if you were using some universal style sheet.
