7 Replies Latest reply on May 28, 2012 8:10 PM by Curt Y
    Graphics Card spec
    John_Picton Level 3
      I am running Photoshop CS5 Extended and I am currently trying the Beta of CS6. I am currently using my onboard graphics card and whilst on the whole have been happy I realise that I am not using the system to the fullest. I am using a PC with a PCI-e slot. What sort of (low budget I am afraid) graphics card should I be looking for. Any suggestions (IE minimum ram etc - or even a product recommendation).
      Cheers
      John Picton
        • 1. Re: Graphics Card spec
          Noel Carboni Level 8
          I'm personally most fond of ATI as I believe they do a better job with releasing high quality drivers, but others like nVidia.  Personal experience figures a lot into recommendations.
          Right now I'd specifically recommend the VisionTek ATI Radeon HD 6670 1 GB DDR5, as it doesn't draw too much power and won't tax your computer's power supply, yet delivers quite fast performance.
          In general for Photoshop use I'd recommend getting a video card that has 1 GB of RAM or more and scores 1000 or higher on the PassMark benchmark:
          http://www.videocardbenchmark.net/
          -Noel
          • 2. Re: Graphics Card spec
            John_Picton Level 3
            Thanks for the input - that is very helpful.
            Regards
            John
            • 3. Re: Graphics Card spec
              Ashvin Ghisyawan Level 1
              Can I use CS5 on al Macbook Air (new one) with a i5 and Ati card?
              Do I have to upgrade my memory?
              Regards,
              Ashvin Ghisyawan
              www.totaalfotografie.nl
              • 4. Re: Graphics Card spec
                Trevor.Dennis Adobe Community Professional (Moderator)
                John, can you tell us a bit about the rest of your system?   You should probably be looking to create a balanced system where components more or less match each other.  You should also think about your operating system.    Windows 7 64bit with at least 6Gb RAM is a good start, and as Noel said, 1Gb of DDR5 in your graphics card.
                But tell us about the rest of your system first.
                BTW  I live about 30 kilometrea away from a town called Picton.
                • 5. Re: Graphics Card spec
                  John_Picton Level 3
                  Hi Trevor - If you live near Picton I am assuming you are in New Zealand. I have never been but my neighbor is from near there.
                  My system is an AMD processor running at 3.2 Ghz with a triple core. I have 4GB of memory installed. I am running Windows 7 professional 64 bit.
                  It isn't the best system in the world - my other computer (which doesn't have Photoshop on it - I use it almost exclusively for recording) is a quad core system with 8GB memory - but still a bog standard graphics card.
                  Any suggestions you can make would be much appreciated.
                  Kind regards
                  John
                  • 6. Re: Graphics Card spec
                    Dsel
                    I'm looking at the PNY Quadro2000 nVIDEA it is recommended for the GPU acceleration function of photoshop……….I was lead to believe only nVIDEA supports this.
                    I am not sure if a pro or workstation card is better than a gaming card.  Leadtek also produce a version of this card Quadro2000 nVIDEA……. No idea what differance between the PNy and the Leadtek is as they are both nVIDEA?
                    It is a 1GB card also.
                    • 7. Re: Graphics Card spec
                      Curt Y Level 7
                      PS CS6 uses Mecury Graphics Engine but not CUDA which I think you are refering to.
                      CUDA is used in some features with video in Premier Pro.
