9 Replies Latest reply on Apr 19, 2012 7:09 AM by the_wine_snob
    No audio when playing back videos in version 10
    Evertech Level 1
      I have installed version 10. I have version 9 still on my computer.
      When I add a video clip which contains audio it plays back fine in version 9 but not in version 10 (dead silence).
      When I drag a video clip to the time line in version 10 it pops up the following message to which I respond 'Yes'.
      David
        • 1. Re: No audio when playing back videos in version 10
          What model of camcorder is this video coming from and what format and resolution is it?
          Also, what are the project settings for your version 10 movie? (You can see them -- but not change them -- by going to the Edit menu and looking under Project Settings.) If you can post a screen capture of the video and audio settings screen, that would be best so we could have a good look at them.
          But it's most important to know where the original video is coming from and what format and resolution it is.
          • 2. Re: No audio when playing back videos in version 10
            Evertech Level 1
            Videos were captured with my old Casio EX-Z750
            Using MediaINFO:
            JPEGs
            Complete name                            : E:\Transfers\AsiaHoliday\CIMG1117.JPG
            Format                                   : JPEG
            File size                                : 301 KiB
            Format                                   : JPEG
            Width                                    : 1 000 pixels
            Height                                   : 750 pixels
            Chroma subsampling                       : 4:4:4
            Bit depth                                : 8 bits
            Compression mode                         : Lossy
            AVIs
            General
            Complete name                            : E:\Transfers\AsiaHoliday\CIMG1245.AVI
            Format                                   : AVI
            Format/Info                              : Audio Video Interleave
            File size                                : 11.8 MiB
            Duration                                 : 24s 900ms
            Overall bit rate                         : 3 965 Kbps
            Mastered date                            : 2012/01/02/ 13:51
            Writing application                      : CASIO EX-Z750
            Writing library                          : QVMI
            Video
            Format                                   : MPEG-4 Visual
            Codec ID                                 : M4S2
            Codec ID/Hint                            : Microsoft
            Duration                                 : 24s 892ms
            Bit rate                                 : 3 777 Kbps
            Width                                    : 640 pixels
            Height                                   : 480 pixels
            Display aspect ratio                     : 4:3
            Frame rate                               : 29.970 fps
            Color space                              : YUV
            Chroma subsampling                       : 4:2:0
            Bits/(Pixel*Frame)                       : 0.410
            Stream size                              : 11.2 MiB (95%)
            Audio
            Format                                   : ADPCM
            Codec ID                                 : 11
            Codec ID/Hint                            : Intel
            Bit rate mode                            : Constant
            Bit rate                                 : 176.4 Kbps
            Channel(s)                               : 1 channel
            Sampling rate                            : 44.1 KHz
            Bit depth                                : 4 bits
            Stream size                              : 538 KiB (4%)
            Interleave, duration                     : 47 ms (1.41 video frame)
            • 3. Re: No audio when playing back videos in version 10
              According to your report, these are MP4-AVIs from a Casio device? What model of camcorder is that?
              I also can not identify the audio codec. Is this video from a smart phone?
              • 4. Re: No audio when playing back videos in version 10
                the_wine_snob Level 9
                David,
                You state that you "captured," from the Casio EX-Z750. Does it shoot on miniDV tape, and did you do the Capture via FireWire in PrE, or did you perhaps Copy the files from a flash-memory card of some sort, and then Import the files into the Project?
                Good luck, and let us know a bit more, please.
                • 5. Re: No audio when playing back videos in version 10
                  Your screen shows AVI and mpeg4... I don't think that will work
                  H.264 NOT inside AVI http://forums.adobe.com/thread/854115
                  • 6. Re: No audio when playing back videos in version 10
                    Evertech Level 1
                    I have all the clips and images saved off the camera and stored on my hard disk.
                    • 7. Re: No audio when playing back videos in version 10
                      OK, that is officially referred to as "Import," and not "Capture," which is a procedure of using minDV tapes, Captured via FireWire/IEEE-1394a connection into PrE.
                      Now, as John T. points out, the H.264 wrapped in an AVI is not the norm, but some camera mfgrs. seem to want to muddy the waters. PrPro users have encountered such, and have found that either re-warpping the H.264 in either MOV, or MP4, has done a good job. Also, converting to something that PrE can edit smoothly, is also helpful.
                      • 8. Re: No audio when playing back videos in version 10
                        Evertech Level 1
                        One thing I would like to emphasise here.
                        I am talking about functionality that Adobe provided in version 9 which is  not repeatable in version 10.
                        David
                        • 9. Re: No audio when playing back videos in version 10
                          David,
                          Are you saying that you could Capture in PrE 8, from a non-tape camera?
                          Capturing has always been done, only from a tape-based camera, via FireWire. This is no other way to Capture.
                          Now, Importing is a different operation. That is where one Copies the files from flash memory, either with a card-reader, or a USB cable. Those files are then Imported into the Project. With most flash memory cameras, one will need to Copy the full folder structure from the card (or built-in memory) to the computer, and then Import the AV files from within that original folder structure. There are other files in those folders, that are not directly Imported, but are used by PrE, so they are necessary too. This depends on the camera, and the format/CODEC, that it shoots in.
