4 Replies Latest reply on Jun 17, 2012 2:05 PM by Jim Curtis
    Sorry a serious error has occured - adobe premiere cs 5.5
    Tomek Kaskow
      Hello
      This message has appear when I edited on Adobe Premiere cs 5.5 -
      I deleted a clip on timeline.
      First time this has come, when I make a frame from videoclip. I make successfully a jpg frame, and when I want delete clip on timeline, from which I created this frame adobe hung up..
      I think maybe hardisk is corrupt, or slow
      I have two samsung hardisk's
      HD103SI
      my configuration
      - ASUS P8Z68-V
      - intel 2600K 3.4 GHz
      - Corsair 16GB ( 4x4 GB ) / 1600 / Venegance
      - hdd Samsung 1 TB i 1,5 TB.. and Seagate 400 GB
      - nVidia GTX 570 / 1028 MB with Cuda
      - BlackMagic Design - Intensity Pro
      - universal card reader chieftec
      - Blu-Ray LG BH10 LS30
      - Windows 7 64 bit PRO OEM
      - Adobe Premiere cs 5.5
        • 1. Re: Sorry a serious error has occured - adobe premiere cs 5.5
          Jim_Simon Level 9
          You say "first time".  Has it happened more than once?  If not, I wouldn't worry about it.
          • 2. Re: Sorry a serious error has occured - adobe premiere cs 5.5
            Tomek Kaskow Level 1
            I mean.. that first time was, when I make still frame from clip.
            It happens again today from time to time - please read my text below.
            I eject one hard disk nine days ago and I search error by Victoria program to HDD.. and he found few errors, a some bad sectors.
            .. so one 1 TB disk left to video data, and system, and one 400 gb to final video data..
            I make new format and clean install Windows 7 and Adobe Premiere..
            9 days was with no error.. to this day..
            Message Sorry a serious error has occured.. appears today again when I editing videoclip..
            I search badsectors on second disk this 1 TB.. which left on computer.. I am coming to job now, so I check if any badsecors are now.
            I think that I must buy new fast disk, those two hard disk I bring to shop to guaranty (I buy 1 year ago).
            Sorry for my mistakes
            This is log from Victoria HDD
            13:11:23 : Starting Reading, LBA=0..1953525167, sequential access, timeout 10000ms
            13:17:03 : Warning! Block start at 73000192 = 484 ms
            13:17:05 : Warning! Block start at 73342464 = 516 ms
            13:17:06 : Warning! Block start at 73344256 = 516 ms
            13:31:10 : Warning! Block start at 245241344 = 485 ms
            13:36:07 : Warning! Block start at 305681152 = 219 ms
            13:55:18 : Warning! Block start at 529966336 = 218 ms
            13:56:53 : Warning! Block start at 547991552 = 1125 ms
            13:56:58 : Warning! Block start at 548703744 = 1000 ms
            14:03:52 : Warning! Block start at 625803008 = 203 ms
            14:36:55 : Warning! Block start at 988770304 = 500 ms
            14:36:55 : Warning! Block start at 988770816 = 484 ms
            14:36:56 : Warning! Block start at 988771840 = 453 ms
            14:37:01 : Warning! Block start at 989610752 = 484 ms
            14:48:07 : Warning! Block start at 1103695360 = 234 ms
            15:15:06 : Warning! Block start at 1365950720 = 375 ms
            15:17:14 : Warning! Block start at 1386163968 = 484 ms
            15:17:21 : Warning! Block start at 1387191552 = 406 ms
            15:17:22 : Warning! Block start at 1387198976 = 407 ms
            15:17:22 : Warning! Block start at 1387201792 = 390 ms
            15:19:34 : Warning! Block start at 1407164928 = 297 ms
            15:58:41 : Warning! Block start at 1739997696 = 469 ms
            15:58:51 : Warning! Block start at 1741284608 = 406 ms
            15:58:52 : Warning! Block start at 1741294592 = 203 ms
            15:58:52 : Warning! Block start at 1741295104 = 453 ms
            This is time in miliseconds to access sectors hard disk.
            Maybe this is fault why AP crashes.. or maybe not..
            Message was edited by: Tomek Kaskow
            • 3. Re: Sorry a serious error has occured - adobe premiere cs 5.5
              browntimmy Level 1
              I have similar specs on my computer and am getting this problem with cs5.5 too. It happens with any project I try to open. I also moved all the files to a new drive but I still get the serious error message. And it doesn't always occur when trying to do one specific thing, it seems to happen at any random moment within the first 5-10 minutes of opening the file. All my other Adobe programs, including After Effects, work fine.
              • 4. Re: Sorry a serious error has occured - adobe premiere cs 5.5
                Jim Curtis Level 3
                Well, there you go.  You should expect problems with your applications if you think you have drive corruption or other issues.  Fix them first, and then report back if you're having problems with Pr.
