2 Replies Latest reply on Apr 18, 2012 9:13 AM by ringen000
    cuda supported graphic card
    ringen000
      Hello!
      I just installed a trial version of Adobe Premiere Pro CS5.5.
      A popup window tells me to download a CUDA graphic driver for better rendering.
      In the list of supported graphic cards my card is not showing up.
      NVIDIA GeForce 9500 GT
      In the details section of this card it shows me the following: CUDA-Cores 32
      Does this mean now that it supports CUDA or not - do I have to install another driver for that - I'm confused . . .
      Btw. the system requirements recommend RAID 0 for uncompressed video.
      So far I'm using different fast HD's but no RAID 0. In which scenario will I be suffering?
      regards
        • 1. Re: cuda supported graphic card
          TradeWind Level 3
          Here's the list of supported GPUs: http://www.adobe.com/products/premiere/tech-specs.html
          The GeForce 9500 GT is not in the list of supported cards. Many cards that have CUDA are not supported by PPro CS5.5. It's not strictly CUDA that PPro is leveraging across the board...PPro requires a handful of specifications, of which CUDA is the most primary, but not the only one.
          Your card does satisfy most of the requirements of the software but only the cards that Adobe has actually tested and approved will be listed as supported cards. Only those cards are supported by default in the operation of PPro CS5.5.
          With all of that said, you can STILL try to have PPro utilize your GeForce 9500 GT GPU by utilizing the "hack" that many users have posted in the forum (I've never had to use it, nor do I know the link, but I think if you search the forum for "GPU hack" then you'll probably find it). The "hack" is NOT supported, and even if you successfully alter the necessary bits of code, it's not guaranteed that your GPU will work or that it will work well.
          Again, only the GPUs listed at the link above and stated by Adobe as "supported" are guaranteed to give you the results you want from Mercury Playback Engine.
          Regarding RAID 0 and uncompressed video.....are you using true uncompressed video? Many people never do, instead using formats like DV, HDV, AVCHD, DVCProHD, ProRes, etc. A RAID 0 is still possibly a good idea if you're running 5 simultaneous streams of video from the same drive, but that's really an entire topic altogether. If you're using UNCOMPRESSED video, then your hard drive setup and RAID are of chief importance for smooth playback. CPU becomes less important since there's nothing to "decompress." However, for formats like DV and AVCHD and similar, hard disk speed is relatively unimportant because the files are usually well below the throughput speeds of a standard drive (AVCHD averages around 17mbps to 25 mbps which is nothing). With those more compressed formats like AVCHD however, your CPU needs to be extremely beefy because it's doing all the work of decompressing the video for playback on the fly.
          Hope this helps!
          • 2. Re: cuda supported graphic card
            ringen000 Level 1
            Thank you so much for your reply! I feel much clearer now !
            And you guessed right I will be using AVCHD mostly.
            From here http://www.studio1productions.com/Articles/PremiereCS5.htm
            I got this information:
            "DO NOT buy a video card with DDR2 memory.  The DDR2 memory can cause performance problems with the Mercury Playback Engine.  If you have a video card with DDR2 memory, replace it."
            My card (GeForce 9500 GT) has DDR 2 RAM but in the mentioned link DDR 5 is recommended.
            It says: "9500 GT    32    350 watt    DDR2 or DDR3    128 Bit    550 Mhz    1400 Mhz    Not Recommend"
            Actually I am, to be honest, not much more than a hobby-editor so I guess I'l come around with my system so far . . . :-)
            Still I am curious to get some hints on which parts I could improve the machine for video editing.
            Here are the specs: (in german!)
            Mainboard:
            Asus P6X58D-E
            ATX, Sockel 1366, Intel X58 / ICH10R Chipsatz, DDR3-1600
            Hersteller      Asus
            Modellbezeichnung      P6X58D-E
            CPU Sockel      1366
            unterstützte Prozessoren      Intel Core i7, Core i7 EE, Xeon (Nehalem)
            Mainboard Chipsatz      Intel X58 / ICH10R
            BIOS Hersteller      AMI
            Formfaktor      ATX
            QuickPath Interconnect QPI (MT/s)      6400
            ATX 12V Anschluss (8polig)      1
            ATX 2.0 Anschluss (24polig)      1
            Arbeitsspeichertyp      DDR3
            Arbeitsspeicher maximal (MB)      24576
            Speichertakt (MHz)      1600/1333/1066 (2000* *OC)
            Speichersteckplätze      6
            Triple Channel Unterstützung      vorhanden
            PCI (32-Bit) Steckplätze      2
            PCIe x1 Steckplätze      1
            PCIe x16 2.0 Steckplätze      3
            SLI / Crossfire Unterstützung      2/3 Way SLI/Quad CrossFireX
            SATA Controller      Intel ICH10R + Marvell® 9128
            SATA Anschlüsse      6x SATAII + 2x SATAIII
            SATA Protokolle      SATAI-III
            Unterstützte RAID Level      0,1,5,10
            USB Protokolle      USB 3.0/2.0/1.1
            USB Anschlüsse extern      4x USB 2.0 intern + 4x USB 2.0 extern + 2x USB 3.0 extern
            Soundchip      Realtek® ALC889
            Audiokanäle      8
            SPDIF Ausgang      1x optisch, 1x koaxial
            LAN Chipsatz      Marvell 88E8056®
            LAN-Ports      1
            LAN-Transferrate (MBit)      10/100/1000
            Anschlüsse für Lüfter      5
            PS/2 Schnittstelle (Tastatur)      1
            PS/2 Schnittstelle (Maus)      1
            IEEE1394a Firewire Schnittstelle      1
            CPU:
            Intel Core i7 950 (3,06GHz)
            Sockel 1366, Box - inkl. Kühler
            Hersteller/Modellbezeichnung
            Hersteller      Intel
            Prozessor Modell      Core i7
            Sockeltyp
            Prozessor Typ - Taktfrequenz      950 (3,06GHz)
            CPU Modellnummer      BX80601950
            Sockel      1366
            Packungstyp      Box - inkl. Kühler
            Prozessorkern      Bloomfield
            Anzahl Kerne      4
            QuickPath Interconnect QPI (MT/s)      4800
            Cache
            Energieverbrauch
            L1 Cache (kB)      4 x 64
            L2 Cache (kB)      1024
            L3 Cache (kB)      8192
            Energieverbrauch (Watt)      130
            Herstellungsprozess (nm)      45
            Kühler      Original Intel Box Kühler
            RAM:
            6144MB DDR3 Kingston KVR1333D3N9K3/6G
            DDR3 - 1333 (PC3 - 10600)
            Hersteller      Kingston
            Herstellernummer      KVR1333D3N9K3/6G
            Technische Daten
            Kapazität (MB)      6144
            Kit bestehend aus      3 x 2048MB
            Speichertyp      DDR3
            Speicherstandard      DDR3 - 1333 (PC3 - 10600)
            Anschluss      DIMM 240-Pin
            Timings
            CAS Latency (CL)      9
            RAS-to-CAS-Delay (tRCD)      9
            RAS-Precharge-Time (tRP)      9
            Festplatte:
            1000GB Western Digital Caviar Black WD1002FAEX
            3,5", Serial-ATA/600 (6Gb/s), 64 MB Cache
            Hersteller      Western Digital
            Modellbezeichnung      Caviar Black WD1002FAEX
            Festplattenkapazität (GB)      1000
            Formfaktor (Zoll)      3,5
            Schnittstelle      Serial-ATA/600 (6Gb/s)
            Umdrehungen / Min.      7.200
            Geräuschentwicklung Betrieb (dB)      33
            Geräuschentwicklung StandBy (dB)      28
            Max. Transferrate (lesen) MB/s      keine Herstellerangaben verfügbar
            Max. Transferrate (schreiben) MB/s      keine Herstellerangaben verfügbar
            Zugriffszeit (ms)      4,2
            Cache (MB)      64
            Gewicht (g)      690
            Abmessungen (BxHxT) (mm)      101,6 x 25,4 x 147
            ARLT Garantie      Kein OEM. 5 Jahre Herstellergarantie. 3 Jahre ARLT Garantie davon 6 Monate Soforttausch bei Defekt
            wegen mehr Platz, größerem Cache, halber Zugriffszeit und SATA3-Schnittstelle, Transfer Rate (Buffer To Disk) 126 MB/s (Max) - sehr guter Wert !
            Brenner:
            LG GH22NS 22/22/48/32 DVD-Brenner, S-ATA
            Super Multi DVD-Brenner ? mit S-ATA Schnittstelle
            INTERNER 22x/22x Super Multi DVD-Brenner mit SecurDisk Unterstützung. Der perfekte Alleskönner für Ihren PC. Brennt nicht nur die gängigen Formate (DVD+R/+RW,-R/-RW) sondern auch DVD-RAM und ist außerdem durch die Double/Dual Layer Funktionalität für die Zukunft gerüstetHersteller      LG
            Modellbezeichnung      GH22NS40
            Farbe      schwarz
            Bauart      intern
            Formfaktor (Zoll)      5,25
            Medienaufnahme      Schublade
            Puffer (Kb)      2048
            Zugriffszeit CD-ROM (ms)      120
            Zugriffszeit DVD-ROM (ms)      140
            Zugriffszeit DVD-RAM (ms)      175
            Lesen CD-ROM      48
            Lesen DVD-ROM      16
            Lesen DVD-RAM      5
            Schreiben CD-R      48
            Schreiben DVD-R      22
            Schreiben DVD+R      22
            Schreiben CD-RW      32
            Schreiben DVD-RW      6
            Schreiben DVD+RW      8
            Schreiben DVD-R DL      10
            Schreiben DVD+R DL      10
            Schreiben DVD-RAM      12
            Betriebs-LED      vorhanden
            Grafikkarte:
            Gainward Geforce 9500GT
            1024MB, PCIe 2.0, DVI, VGA, HDMI
            Hersteller      Gainward
            Anschlussart      PCI-Express 2.0
            Stromversorgung
            Maximaler Verbrauch bei Volllast (Watt)      75
            GPU
            GPU Hersteller      NVIDIA
            GPU Bezeichnung      Geforce 9500GT
            GPU Takt (MHz)      550
            Kühlung      passiv
            DirectX Version      10
            Shader Model Version      4.0
            OpenGL Version      2.0
            HDCP Unterstützung      Ja
            NVIDIA CUDA-fähig      Ja
            Grafikspeicher
            Speicherkapazität (MB)      1024
            Speichertyp      DDR2
            Speichertakt (MHz)      800
            Speicheranbindung (Bit)      128
            RAMDAC (MHz)      400
            Dual-Link Unterstützung      ja
            unterstützte Auflösungen
            Max Auflösung (dpi)      2560x1600x32Bit 60 Hz (Dual Link)
            SLI / Crossfire Unterstützung      SLI
            Anschlüsse
            DVI Schnittstelle      1
            VGA D-Sub Schnittstelle      1
            HDMI Schnittstelle      1
            Unterstützte Betriebssysteme      Windows XP, Windows Vista
            Zubehör      Treiber CD
            Packungstyp      Retail
            Netzteil:
            550Watt, ARLT Netzteil, 12cm Lüfter, 20+4pin, schwarz
            Anschluß Mainboard
            ATX (20pin. + 4pin. Buchse)
            Anschlüsse Endgeräte
            8x 4 Pin Stromanschlüsse (HDD), 2x 4 Pin Stromanschlüsse (FDD), 2x SATA Stromanschlüsse, 1x 6 Pin Stromanschluss (VGA), 1x 4 Pin Stromanschluss (CPU)
            Eingänge
            230V Netz
            Leistung
            550Watt
            Lüfter
            1x 12x12cm silent
            Leistung
            Hersteller      Arlt
            Modellbezeichnung      LowNoise
            Watt      550
            Anschlüsse
            ATX 12V Anschluss (4polig)      1
            ATX Anschluss (20polig)      1
            S-ATA Stromanschlüsse      2
            3,5" Anschlüsse      2
            5,25" Anschlüsse      8
            Eingangsspannung (V)      230
            Sonstiges
            Bauform      ATX
            Lüfter (mm)      120
            CPU Kühler:
            Scythe Mugen 2 Rev. B, CPU Kühler für Sockel 1366/1156/775/478/754/939/AM2/AM2+/AM3/940
            Hersteller      Scythe
            Modellbezeichnung      Mugen 2 Rev. B
            Material Kühlkörper      Kupfer / Aluminium
            kompatible CPU Sockel      1366/1156/775/478/754/939/AM2/AM2+/AM3/940
            Freigegeben bis (MHz)      alle Taktraten
            Lüfterdrehzahl (U/Min)      1400
            Geräuschentwicklung Betrieb (dB)      26,5
            Abmessungen (BxHxT) (mm)      130 x 158 x 100
            Gewicht (g)      870
            Besonderheiten      bis zu 4 Lüfter verbaubar
            mitgeliefertes Zubehör      Backplates
            Schrauben
            Installationsanleitung
            Luftdurchfluss (m³/h)      126
            Kühlung      aktiv
            Cardreader:
            Apacer AE700, Kartenlesegerät 30-in-1
            intern, USB, Schwarz
            Hersteller      Apacer
            Modellbezeichnung      Embeded Card Reader AE700
            Kartenleser Typ      30-in-1
            Farbe (Gehäuse)      Schwarz
            Anschluss      USB
            Breite (mm)      101
            Höhe (mm)      25
            Tiefe (mm)      100
            lesbare Formate
            XD PictureCard      ja
            mini-/micro SD      ja
            SD Memorycard      ja
            MultimediaCard      ja
            Microdrive      ja
            MemoryStick      ja
            CompactFlash      ja
            OS:
            Windows 7 Professional 64-Bit System-Builder-Version
            Windows 7 Professional 64-Bit System-Builder-Version, EnglischHersteller      Microsoft
            Art der Software      Betriebssystem
            Datenträger      DVD
            Lizenz (Anzahl PC's)      1
            Softwareversion      OEM
            Produktaktivierung erforderlich      ja
            2 x eSATA als PCIe:
            Delock Controller Karte 2x eSATA, 2xSATA, 1x IDE
            2x intern SATA oder 2x eSATA Spezifikation
            1x intern PATA IDE Spezifikation
            Datentransferraten:
            SATA II bis zu 3 Gbps
            PATA bis zu 133 Mbps
            PCI Express x1 Standard
            Unterstützt PCI Express 1.0a Spezifikation
            Unterstützt bis zu 2 HDD am SATA, sowie 2 HDD am IDE Controller
            Unterstützt Native Command Queue (NCQ)
            Raid 0, 1
            Festplatte:
            2000GB Western Digital RE4-GP (WD2002FYPS)
            3,5", Serial-ATA/300 (3Gb/s), 64 MB Cache
            Modellbezeichnung      RE4-GP (WD2002FYPS)
            Festplattenkapazität (GB)      2000
            Bauart      intern
            Schnittstelle      Serial-ATA/300 (3Gb/s)
            Umdrehungen / Min.      5.400 - 7.200 (dynamisch je nach Auslastung)
            Geräuschentwicklung Betrieb (dB)      29
            Geräuschentwicklung StandBy (dB)      25
            Max. Transferrate (lesen) MB/s      110
            Zugriffszeit (ms)      8,9
            Cache (MB)      64
            MTBF (h)      1.200.000
            Gewicht (g)      730
            Abmessungen (BxHxT) (mm)      101,6 x 26,1 x 147
            Besonderheiten      Energiesparende Green Power Festplatte
            Please have a look at my system and give me ideas how I could eventuially improve it.
            regards
