4 Replies Latest reply on Apr 19, 2012 2:34 AM by BalboNicolas
    Problem with a script to remove graphics
    BalboNicolas
      Hello,
      I have tried to build a javascript to remove all graphics whose extension is not ".EPS" (with "EPS" really in upper cases, as it is for Mathtype equations in Word import).
      But It doesn't work and I can't understand why.
      Here is the script:
      //The script intend to remove all graphics whose extension is not ".EPS"
      var myGraphics = myDoc.allGraphics
      //Remove graphic if graphic extension is different from ".EPS"
      for (var p = 0; p < myGraphics.length; p++) {
          var myImage = myGraphics[p]
          if (CheckExtEps(myImage) != 0){
          myImage.remove ()
      //Compare graphic extension with ".EPS" and return myExtValue = 0 if it matches exactly
      function CheckExtEps(myImage) {
          var  myString = myImage.name
          myExt = myString.substr(myString.lastIndexOf( "." ))
          myExtValue = myExt.localeCompare(".EPS")
          return myExtValue
      When I run this script, ALL the graphics are removed, ".EPS" included.
      I do have ".EPS" graphics in my document and I expected them not to be removed.
      So there is something wrong somewhere, but I don't know what to change.
      Any ideas?
      By the way, I have a more generic question as a beginner:
      I am working with ExtendScript Toolkit. How can I do to check my script step by step?
      For exemple, how can I display my variables values as "myString", "myExt", "myExtValue" at each step?
      Actually, this script is a step for a bigger script I intend to build to deal with Mathtype equations in Word import.
      After not-EPS graphics beeing removed, I wish to relink all remaining equation prewiews to eps in a selected folder, by consecutive order.
      But this is a big piece of scripting to swallow for me, so I'm working slowly, step by step.
      TIA
      Best regards
      Nicolas
        • 1. Re: Problem with a script to remove graphics
          TᴀW Adobe Community Professional & MVP
          Well, I can't see any semicolons in your script. Maybe that's just the
          email interface, but there should be semicolons at the ends of lines.
          In the ESTK, you can step through a script a line at a time. Just click
          on the downwards pointing arrow instead of the "play" arrow. Each time
          you click, the script will advance one line. In the Console window
          (Windw>Console) you can then type the name of the variable you wish to
          examine.
          Ariel
          • 2. Re: Problem with a script to remove graphics
            BalboNicolas Level 1
            Hello Ariel
            Thank you very much for your help.
            1. I added semicolons at the end of lines, but the script result is the same.
            2. Running line by line, I could see in the Console where is the problem:
            variable "myString" is always undefined.
            Well, I have to get more inside my script...
            Thank's again
            Best regards
            Nicolas
            Nicolas BALBO
            balbon3@orange.fr
            22, rue d'Hauteville  75010 PARIS
            Tel : 33 (0)1 42 57 14 31
            created by Arïel in InDesign Scripting - View the full discussion
            examine.
            Ariel
            Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4344039#4344039
            To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4344039#4344039. In the Actions box on the right, click the Stop Email Notifications link.
            Start a new discussion in InDesign Scripting by email or at Adobe Forums
            For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
            • 3. Re: Problem with a script to remove graphics
              It's not myString that's undefined, but rather myImage.name. Try with myImage.itemLink.name instead; that will yield the *file* name: http://jongware.mit.edu/idcsjs5.5/pc_Image.html#itemLink
              • 4. Re: Problem with a script to remove graphics
                Yes, it work!
                Thank's a lot!
                For information, what is the difference between graphic.name and graphic.itemLink.name?
                I understood that the file name is yield by itemLink.name, but what is yield by .name alone?
                Nicolas BALBO
                balbon3@orange.fr
                created by in InDesign Scripting - View the full discussion
                It's not myString that's undefined, but rather myImage.name. Try with myImage.itemLink.name instead; that will yield the file name: http://jongware.mit.edu/idcsjs5.5/pc_Image.html#itemLink
                Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: http://forums.adobe.com/message/4344282#4344282
                To unsubscribe from this thread, please visit the message page at http://forums.adobe.com/message/4344282#4344282. In the Actions box on the right, click the Stop Email Notifications link.
