3 Replies Latest reply on Apr 18, 2012 12:23 PM by sinious
    Flash Pro CS 5.5 will only open when I open as Admin
    haknudsenwth Level 1
      For some reason Flash Pro CS 5.5 will only open when I open as Admin.  If I try to open it normaly or by clicking on a fla nothing happens except a program called WerFault.exe and Flash.exe show up in my Task Manager then close.  I get no report that something is wrong though I know werfult is window's problem reporting program.  When I open as admin Flash Pro works fine so I do not understand what is going on.  It worked fine yesterday and I have made no installations or updates since then.
      Any suggestions?
        • 1. Re: Flash Pro CS 5.5 will only open when I open as Admin
          sinious Most Valuable Participant
          Sounds like you installed it for standard users, you use a standard user account and you changed something while you were logged on as an admin. If you did anything as an admin to make a file Flash writes (configs, etc) then they can become unable to be utilized again by anything other than the administrator.
          As administrator, you can right-click on a folder, open up properties, use the security tab, advanced at bottom, owner tab at top, edit button, select your username, check "Replace owner on all subcontainers and objects" then apply and keep hitting apply/ok. That will reset ownership of all the files back to the user you designate which shouldn't require administrator privs.
          Additionally, as administraotor, you can go in properties->security tab->edit button, select your user and make sure they have full control permissions.
          • 2. Re: Flash Pro CS 5.5 will only open when I open as Admin
            I'm not even sure how to log in as administrator, but when I right-click on Flash.exe and select properties, then security, it shows Users (computername\Users) have Full Control permissions.
            • 3. Re: Flash Pro CS 5.5 will only open when I open as Admin
              That's just one file. If you didn't explicitly make an admin user then you ARE the administrator.
              Forget about logging in as Administrator and just do the same process to set the "owner" of the whole folder to yourself, incase something weird happened.
