6 Replies Latest reply on Sep 26, 2012 11:20 AM by PECourtejoie
    Installation adobe première CS5 échoue
    tatchou30 Level 1
      Bonjour, j'ai un problème quand je tente d'installer la version d'évaluation de Adobe Première CS5 j'ai ce message d'érreur:
      "Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 57 error(s), 53 warning(s)
      ----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
      ERROR: Error 1327.Invalid Drive: X:\
      ERROR: Install MSI payload failed with error: 1603 - Erreur irrécupérable lors de l'installation.
      MSI Error message: Error 1327.Invalid Drive: X:\
      WARNING: DW036: Payload cannot be installed due to dependent operation failure
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050: - Adobe ExtendScript Toolkit CS5.5: Install failed
      ERROR: DW050: - Microsoft_VC90_ATL_x86: Install failed
      ERROR: DW050: - Microsoft_VC90_CRT_x86: Install failed
      ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed
      ERROR: DW050: - AdobePDFL x64 CS5: Install failed
      ERROR: DW050: - DynamiclinkSupport: Install failed
      ERROR: DW050: - Microsoft_VC80_MFCLOC_x86_x64: Install failed
      ERROR: DW050: - Adobe After Effects CS5.5 Support: Install failed
      ERROR: DW050: - Adobe XMP Panels CS5: Install failed
      ERROR: DW050: - Pixel Bender Toolkit: Install failed
      ERROR: DW050: - Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
      ERROR: DW050: - Photoshop Camera Raw: Install failed
      ERROR: DW050: - Camera Profiles Installer: Install failed
      ERROR: DW050: - Adobe Extension Manager CS5.5: Install failed
      ERROR: DW050: - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
      ERROR: DW050: - AdobeColorCommonSetRGB: Install failed
      ERROR: DW050: - Microsoft_VC80_CRT_x86_x64: Install failed
      ERROR: DW050: - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
      ERROR: DW050: - AdobeMotionPicture CS5.5: Install failed
      ERROR: DW050: - Photoshop Camera Raw (64 bit): Install failed
      ERROR: DW050: - Microsoft_VC90_MFC_x86: Install failed
      ERROR: DW050: - Adobe Media Encoder CS5.5 X64: Install failed
      ERROR: DW050: - AdobeTypeSupport CS5: Install failed
      ERROR: DW050: - Adobe CSXS Infrastructure CS5.5: Install failed
      ERROR: DW050: - Adobe After Effects CS5.5_AdobeAfterEffects10.5fr_FRLanguagePack: Install failed
      ERROR: DW050: - AdobeHelp: Install failed
      ERROR: DW050: - Required Common Fonts Installation x64: Install failed
      ERROR: DW050: - Microsoft_VC90_ATL_x86_x64: Install failed
      ERROR: DW050: - Adobe Story: Install failed
      ERROR: DW050: - Microsoft_VC90_CRT_x86_x64: Install failed
      ERROR: DW050: - Microsoft_VC80_CRT_x86: Install failed
      ERROR: DW050: - Adobe Device Central CS5.5_DeviceCentral3.5LP-fr_FR: Install failed
      ERROR: DW050: - AdobeCMaps x64 CS5: Install failed
      ERROR: DW050: - AdobeTypeSupport x64 CS5: Install failed
      ERROR: DW050: - Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed
      ERROR: DW050: - Adobe After Effects CS5.5 Third Party Content Wrapper: Install failed
      ERROR: DW050: - Microsoft_VC90_MFC_x86_x64: Install failed
      ERROR: DW050: - AdobeOutputModule: Install failed
      ERROR: DW050: - Microsoft_VC90_MFCLOC_x86: Install failed
      ERROR: DW050: - AdobePDFL CS5: Install failed
      ERROR: DW050: - AdobeCMaps CS5: Install failed
      ERROR: DW050: - Adobe After Effects CS5.5 Presets: Install failed
      ERROR: DW050: - Microsoft_VC80_MFC_x86_x64: Install failed
      ERROR: DW050: - Adobe After Effects CS5.5: Failed due to Language Pack installation failure
      ERROR: DW050: - AdobeColorVideoProfilesAE CS5.5: Install failed
      ERROR: DW050: - Adobe Player for Embedding x64 3.1: Install failed
      ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
      ERROR: DW050: - Microsoft_VC80_MFC_x86: Install failed
      ERROR: DW050: - Adobe Player for Embedding 3.1: Install failed
      ERROR: DW050: - Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR: DW050: - AdobeJRE: Install failed
      ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed
      ERROR: DW050: - Adobe Bridge CS5.1: Install failed
      ERROR: DW050: - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
      Impossible de l'installer j'ai voulu chercher sur le site d'abobe ou ils expliquent comment résoudre le problème mais je ne comprends pas car c'est anglais et surtout ça à l'air compliqué et pas clair est-ce que quelqu'un à déjà eu ce problème ou connait la solution ? C'est vraiment très important car j'en ai besoin pour monter des films amateurs et ça fait 3 jours que je m'arrache les cheveux...
      Merci d'avance
      EDIT: je suis sous windows 7 64 bits
